Registered Cruiser
jorian's Avatar
Angry 3.2 Starting issue
Car won't start. I usually crank 1-2 seconds and it fires right up. Drove the Auto-X on the weekend with no issues but I did notice a the engine bog twice during the day when I got the throttle.
Car has always had a bit of a hunting idle but not enough for me to fix. Could the ICV havbe packed it in? O2 sensor? CHT sensor?
Just trying to get an idea of what I can do myself before I drag it to a shop.
Thanks in advance!
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 08-31-2006, 12:24 PM
charlesbahn's Avatar
New DME relay (under the driver's seat) and clean the plug in sockets.
"Igneous Aquam et Laudi semper"
Carl Muckley
Old 08-31-2006, 01:06 PM
Bog and hunting idle usually indicates an over rich condition. Might be as simple as having your mixture checked and adjusted.
Old 08-31-2006, 03:26 PM
DW SD's Avatar
I'm thinking you may have a fuel issue. Maybe your filter is plugged or your pump crapped out. If you don't have full fuel pressure it will bog, instantly as if the ignition were turned off.
My pump died once and it wouldn't start. Try a shot of ether (carefully) before cranking and see if it starts and then dies. Do not try to run it on ether, just a spray before cranking. You can also crack a fuel line at the fuel rail and see if there is pressure (not cranking) and immediately after cranking. OR have a friend grab the pump and see if it vibrates during cranking.
Doug
1971 RSR - interpretation
Old 08-31-2006, 04:51 PM
