Send a message via AIM to Fahrvergnuugen
Where to get a clutch centering tool?
I see a 17 piece clutch centering tool set in the pelican catalog. I just need one for centering the clutch on a 3.2 motor.
Old 10-15-2006, 06:55 PM
lally911's Avatar
Pelican catalog has this
Clutch Alignment Tool, 911 (1972-86)
PEL-TOL-CA2 $8.85
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 10-15-2006, 06:56 PM
Never needed one. Eye ball it, or use a long socket to help you center it.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-15-2006, 06:59 PM
I'll give it a shot. I'd rather not have to wait for the tool to get shipped...
thanks guys.
Old 10-15-2006, 07:03 PM
Zeke's Avatar
You sure a VW one won't fit? I've never tried one, but one never knows about these German cars. I've also eyeballed it many times in the old VW days, but there wasn't much to loose. Anyway, with the trans out on the ground, it should be easy to check out your alignment. If it doesn't slide in freely, at least you don't have to lower the engine and back it out of the car to realign. Do that a couple of times and you either get good at eyeballing or buy the damn tool.
I'll bet you could put the toilet paper holder in the drill press and come up with something. He Heh.
Old 10-15-2006, 07:10 PM
47silver's Avatar
wooden dowel rods
i helped a guy put a clutch in a mercedes years ago. we could not eye ball it and worked hours on it.....i went to a hardware store and bought some wooden dowels. one fit into the center bearing and used a larger one for the clutch hole....drilled a hole in the larger one, put the smaller dowel into it, and you have a centering tool.
1975 911S Targa
Silver Anniversary Edition
Old 10-15-2006, 07:30 PM
Zeke's Avatar
Re: wooden dowel rods
And when that's done, you can put it in the toilet paper holder to replace the one you messed up.
Good thinking on that one, silver.
Old 10-15-2006, 07:36 PM
jevvy's Avatar
you can also get it to work by loosley doing up the pressure plate bolts, slide the box on and then tighten up a few of the pplate bolts through the access holes, slide the box off again then tighten all the bolts to the right pressure - wotks like a treat.
Remember you might have to twist the axel stubs as you slide the box on, this helps align the splines.
Good luck.
'89 3.2/3.6 coupe
Old 10-16-2006, 12:21 AM
Grand Am/IMSA Data Guy
Porsche84's Avatar
I believe that the tool is the same as Ford so look for it locally. Take the clutch disc with you and try the tool in the spline. They make cheap plastic ones that work very well
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 10-16-2006, 02:59 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
for the money and time saved, i think the easiest way to do this is with the plastic tool, mine is made by ford...$5 and easy to get
Scott Kinder
kindersport @ gmail.com
Old 10-16-2006, 03:20 AM
19 years and 17k posts...
azasadny's Avatar
I went to my local Auto Zone and paid less than $5 for a plastic "clutch alignment tool" marked "Ford" and it worked perfectly...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-16-2006, 04:03 AM
