Throw it on the ground!
Adding 3 cooling fans to rear A/C condenser
Working on my wiring plan for a three 7.5" Spal pull fan add to the underside of my rear A/C condenser. Three 7.5" fans will cover the entire surface area & will fit in this tight space. Will be adding relays wired directly to the + on the comperssor to turn the fans on/off. Planning on running a new hot lead direct from the battery to power the fans with inline fuses. Each fan is rated at 7.5amps and pull 440 CFM.
Need suggestions for getting power to the fans.
Best route to run a positive lead from the battery to the engine compartment?
If I run a cable into/through the cabin, can I get to the engine compartment through the tunnel opening on the floor between the rear seats?
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 11-01-2006, 07:59 PM
Anyone have any experience running a new Pos lead from the battery to the engine compartment?
Thanks!
Mark
1987 911 Coupe
Old 11-02-2006, 09:44 AM
I did a similar project on my '89 and used one of the empty slots in the fuse box in the engine compartment....no need to run a dedicated wire all the way to the battery itself.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 11-02-2006, 10:11 AM
Great idea. I've got three open fuse slots, but didn't know if it would be OK to use. Glad I asked. Problem solved.
Thanks!
Mark
1987 911 Coupe
Old 11-02-2006, 10:14 AM
BReyes's Avatar
Are you running barrier hoses? Have you thought about a pro-cooler (front ac condensor) to lower your vent temps?
My 69 has fans on the rear condensor too.
Bernard
Old 11-02-2006, 10:28 AM
scottb's Avatar
How are you going to fit the fans? Do you have a turbo tail?
Have you considered switching the fans off of the same wire that switches the compressor?
1984 Targa
Old 11-02-2006, 11:17 AM
You do realize that there's a huge fan sucking air through the condenser, right. The only time the three fans are likely to help is when you are at idle.
Old 11-02-2006, 11:26 AM
scottb's Avatar
I'd love to see some empirical data on whether fans on the rear condenser actually help. Some on this BBS swear that they help. I'm skeptical.
1984 Targa
Old 11-02-2006, 11:29 AM
AvonGil's Avatar
I agree if anything, the one in the middle would probably be a waste even at idle.
95' Mercedes E300 Diesel (Azure+Sodalith Blue)
88' Porsche 911 Targa (FOR SALE) (Guards Red)
Old 11-02-2006, 11:49 AM
No barrier hoses, although I replaced two of the three hoses this summer along with the rear condenser, drier, ft condenser motor and evaporater motor. $1,900 later I got my vent temps down to the mid 30's to low 40's. I'm convinced that the greater the airflow created through the undersized and poorly placed condensers, the better.
And, yea I've got tail! ....with the notched condenser for the rear wiper.
Mark
1987 911 Coupe
Old 11-02-2006, 11:54 AM
scottb's Avatar
IMHO, your time and money would be better spent putting a condenser and fan in the front left fender.
1984 Targa
Old 11-02-2006, 01:19 PM
If you've got a tail then you are getting even more air at speed than a car with no tail. So you are getting temps in the 30s and that's not enough. I'm guessing that you need another condenser.
Old 11-02-2006, 01:24 PM
I'm thinking my stock A/C system that is now fully operational will be OK. But with a little tweeking (i.e. relatively low cost fan add) I can improve its efficiency. In stop and go traffic my vent temps go from the mid 30's to the low-mid 40's at a standstill then back down when I get moving and get air flow back up. I'm hoping the fans will lower the high end of my vent temp range. Make sense?
Mark
1987 911 Coupe
Old 11-02-2006, 01:36 PM
Sure, like I said, the only time the fans will help is when in stop and go. Is the fan for your front condenser working?
Old 11-02-2006, 01:45 PM
Steve, this car is my daily driver. Call me a little obsessed but very unpleasant memories from this summer linger (trying to get my system working). I'm sure you can relate. The only city I've lived in hotter and more humid than Atlanta or Tampa is Houston.
Mark
1987 911 Coupe
Old 11-02-2006, 01:48 PM
Yep, front condenser motor and evap motor were both fried and were replaced.
Mark
1987 911 Coupe
Old 11-02-2006, 01:51 PM
Funny, I've lived in Tampa too, so yes, I understand about heat. At least you have an '87 so you have the updated vents. Something needs to be done to the center vents to allow them to both point at the driver, and the far left vent should be closed. I'd guess that the fans should definitely help in stop and go. Good luck.
Old 11-02-2006, 02:04 PM
Install a trinary pressure switch in the discharge line of the compressor. In addition to having high and low pressure cutouts (opening contacts) it has an extra set of contacts that close at intermediate pressures (such as when the deck lid condenser loses effectiveness due to lack of air flow). This extra set of contacts can be used to energize either the fans directly or through a relay.
Vent air temperatures below 35F are not really very useful as they indicate the evaporator is at or below 32F and it will ice up and block air flow. If you're at 40F or below and need more "cooling", work on improving the air flow through the evaporator, dash and around the interior of the car.
Old 11-02-2006, 04:13 PM
Administrator
Jack Olsen's Avatar
What's your source on the fans?
Old 11-02-2006, 04:52 PM
Jack, my fan source is The Fan Man......$53 each for 7.5" spals. Best pricing I found.
http://www.the-fan-man.com/shop/size-pull-part-0358-p-179.html?cPath=33
Thanks!
Mark
1987 911 Coupe
Old 11-02-2006, 05:33 PM
