LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Toxic
derkpitt's Avatar
only one
I only have one elec fan added under my rear condenser and I believe it helps. But the three fans your talking about will be a very tight fit.
I live in the ATL and get low-mid 30 after improving the air flow from the evap box. There's much to be improved there.
Bruce
88 Carrera Coupe, 12 Dodge Ram Hemi,
69 Barracuda Fastback, 68 Barracuda Convertible 5spd
The only substitute for cubic inches is cubic dollar$.
Old 11-02-2006, 05:58 PM
Throw it on the ground!
Jim thanks for the suggestions. What's your opinion on mounting a small fan at the evaporater intake opening behind the passenger floorboard. I recall seeing a post where a guy mounted a computer muffin fan. This fan would be totally ineffective IMO but I like the idea. Spal makes a 4" Motorcycle/ATV fan that moves 124 CFM. I don't know the CFM rating of the evaporator fan. I'm no engineer but I would seem to me that "assist" fan at the intake might improve the efficiency of the evap fan. I also recently ran across an evap fan upgrade with a HD fan boasting a 50% improvement in CFM from the OEM fan (got me thinking)
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 11-02-2006, 05:59 PM
Derk, what did you do to improve your evap airflow? I haven't looked but wouldn't be surprised if my evap box is a dirty mess.
Mark
1987 911 Coupe
Old 11-02-2006, 06:17 PM
"I recall seeing a post where a guy mounted a computer muffin fan."
That would be me; the computer "muffin" fan will make an airflow through the evaporator and ducting even without the main blower running so it does move air. The more delta P there is, the more air is moved. Plus it is pushing air directly into the evaporator core. A further advantage of that computer fan is that it draws a "whopping .45 of a watt" and is quiet. A bigger, high output fan in the passenger foot well likely will make increased noise which may grow tiresome. If it has never been done since the car was made, removing the evaporator core and cleaning it can be helpful as can fitting seals between the evaporator core and the housing to reduce air bypassing the core. Also consider installing a modern evaporator and a higher output fan. Note that higher output fans may be noisier than stock if the higher output is achieved by running them at higher rotational speeds. Cheers, Jim
Modern evaporator core and expansion valve fitted into OEM (factory A/C) evaporator/blower housing. Note the additional foam sealing on the sides to reduce the bypassing of inducted air.
Old 11-02-2006, 06:24 PM
Jim, small world. I hope my comment about the muffin fan didn't offend you....my only point was that I did not think they move much air. You're spot on with the noise issue....my concern also with a larger fan.
What's involved in cleaning out the evap box. Does it require disconnecting and recharging the system? I had to do that twice alreay this summer in my repair fiasco....fix one leak and create another, etcetera, etcetera! Can I clean and re-seal without disconnecting any hoses?
Mark
1987 911 Coupe
Old 11-02-2006, 06:29 PM
I'm not offended; I too was surprised how much air flow the "muffin" fan produced.
"Can I clean and re-seal without disconnecting any hoses?"
Not too likely, unless for some reason there is a lot of slack in the refrigerant hoses going to and from your evaporator.
Old 11-02-2006, 06:42 PM
scottb's Avatar
Jim: I know that several vendors have the modern evaporators and expansion valves, but where does one get a higher output fan that will fit?
Thanks.
1984 Targa
Old 11-02-2006, 06:47 PM
ScottB, I found the link that I ran across the other day for the high output evap fan that fits the stock evap box. Has anyone tried one of these?
http://www.mrjaguar.com/porsche/porsche911carreraac.html
Scroll down to:
"Replace that "wimpy" OE Blower Motor with a more powerful 3 speed motor that allows you to lose the Resistor A/C intake restriction and add more Blower speed control. Will give you up to 50% more CFM as compared to OE!"
Mark
1987 911 Coupe
Old 11-02-2006, 07:50 PM
Detached Member
Hugh R's Avatar
I did this with muffin fans on my ROW 84 Targa. I still get crap for air flow from the vents, but its better. My A/C and vent plumbing is very different from the US cars I've seen. For example, I get A/C out of the windshield, dash and under dash vents, which is nice for defogging, and I don't have the bowtie thingie. Its some kind of aftermarket system for a car that originally came without A/C. But in 95-100 degree LA summer days, I get mid 30s on the dash vent temps, just not a lot of CFM, and thats with R-134a and a Jim Sims subcooler.
Hugh
Old 11-02-2006, 09:07 PM
Toxic
derkpitt's Avatar
Here's one of my favorites,
evap box
I've also replace the evap fan with one from Grainger, but haven't written anything up on this yet.
I believe the air flow has improved.
Bruce
Old 11-03-2006, 04:31 AM
I followed Jim's idea here. I was happy with my A/C before, but this improved it some more.
Brian
Old 11-03-2006, 05:52 AM
I like the idea of moving air in the cabin to the evaporator inlet. Unfortunately, I think our cars suffer from 'short cycling'. The cool air is sucked right back into the system. A better solution would be an air return that uses the center tunnel and draws are from the rear of the cabin via ducts under the seats.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 11-03-2006, 07:51 AM
For the factory A/C cars which have an evaporator/blower housing which inducts air from both the passenger foot well area and the tunnel this could be accomplished by louvering the cover plate over the shift coupler and mounting a muffin type booster fan within the nozzle that leads from the tunnel to the evaporator/blower housing. I seem to recall that there were some shift coupler cover plates that came from the factory louvered but these may have been for the cars equipped with the front gasoline fueled auxiliary heater.
Old 11-03-2006, 10:43 AM
My '68 912 had the louvered transmission connection cover. PET's picture for 65-69 911-912 shows louvered. It must have been some time later when the solid covers started showing up. I swapped my solid one for a louvered one when I installed A/C in my '80 Euro SC, and I had to make a cutout in the solid carpet that covered the plate.
Old 11-03-2006, 05:14 PM
I recommend fans and posted on this some time ago
Ac
1991 GP White 965
Old 11-04-2006, 04:55 AM
OK, here is a picture of the fans laid out on a cardboard template of the rear condenser. Three 7.5" fans appear to maximize the surface area of the condenser without any overhang as there is no room for any overhang. Waiting for three sets mounting feet to arrive before getting started. Will attach to underside of condenser using nylon push through fastners.
Thanks all for your comments and ideas!
Mark
1987 911 Coupe
Old 11-07-2006, 05:46 PM
"using nylon push through fasteners"
This mounting method has caused problems (tearing through the fins and channel leaks) when used to mount electric fans to vertical radiators. The deck lid condenser may be robust enough and your fans small enough that it may be okay in this case.
Old 11-07-2006, 06:21 PM
Checked with my source on that very issue (The Fan Man) and he stated that push throughs are not recommended for radiators but should be OK for this application. Sounds like you are in agreement Jim ?
Mark
1987 911 Coupe
Old 11-07-2006, 06:27 PM
Don't have any data on the Porsche condenser use but they are thicker than many modern radiators, some of which seem to only be 10 mm thick. I guess you (or rather your car) gets to be the "guinea pig." Did the "Fan Man" know your condenser is tilted and not vertical?
Old 11-07-2006, 06:35 PM
