For me (so far, & I hope forever) it was putting an early 'road racer' style transmission in my '73 (attached to a 3.2L motor).
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
19 years and 17k posts...
I thought the clutch cable replacement would be the hardest project I ever attempted, but it was easy compared to some of the other things I've done on the car.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Replacing the heater/defroster levers on the dash and attaching and running new cables under the dash into the trunk.
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
Milt,
The glass has etched lines either into or on the glass. But the current is carried by a conductor that is placed on the glass at the factory. After 32 years and many washes, I guess, the conductor had been removed. There is a repair kit that can be found on the internet. It is meant to repair and not to completely redo the grid lines. I had to tape and repaint or re-brush (the brush looks like a finger nail paint brush) the grid lines. As for why would you doubt it? I can't say. Perhaps to be a smart a$$? Mark
Mark Isaak 1974 Carrera Targa - Light Yellow, Being driven 1974 Carrera Targa - Orange, Being restored 1974 Carrera Targa - Lime Green, Being pampered 2017 Macan |
Diss Member
Replacing rear banana arm bushings without removing the engine/tranny. I have a later G50 car and I just wanted little monoballs in there.
BZZZZZT thankyouforplaying...
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Getting the dust boot on the AL front calipers and getting stuck pistons out calipers.
_____________________________ 1972 911 2.4S Black on Black, Recaro's, SSI, MFI, dual pipe exhaust, currently running in after engine rebuild! |
What?
How does the "washer and screwdriver" technique work? I searched but didn't find that method. I tried to spread out the spring but nothing I tried worked and I gave up. I'd really like to get the spring installed this winter while the car is stored. Thanks!
Also, trying to reconnect the throttle linkage to the pedal cluster after it fell down into the tunnell with all the other linkages and fuel lines running thru there!
EarlyS 1017 RGruppe 663 73 911T 3.2 01 Ducati S4 Monster 00 Ducati 996 |
rear wheel bearings can be tough.
front hood shock retaining clip was a pita. after messing with it for an hour i had my brother try and he had it on in 30 seconds!
Front fuel pump is a messy job especially with a full tank of fuel and original rubber fuel line
82 SC , 72 914 |
Here's a funny one!!
After putting on the cam carriers with the engine on the stand, watching a washer fall down the oil return tube into the case!! Then spending 2 hours fishing it out.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
So far, the alternator shroud is the worst.... But the hood shocks are in my future
Tom 88 Targa - Mostly stock except cat bypass, SW Chip. 06 Audi A4 2.0t Quattro 02 Saab 9-3, 06 VW Passat, 06 Chevy Cobalt |
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
1. Convincing the wife to let me buy one.
2. Saving up $17k to buy one. (Accomplished first, on track for fall of this year with second!) Cheers, Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
durn for'ner
Silly but never the less the most frustrating moment so far in my short DIY career: Replacing number six spark plug. That little bugger drove me crazy.
Markus Resident Fluffer Carrera '85 |
No, I wasn't being a smart ass. If you read what I said carefully, you will see that I inferred that I doubted that there was a viable brush on solution to failed lines on the glass rather than your ability or desire to fix them. So, I asked if there was such a product expressing my doubt that there was. As I need to get away from this addiction(Pelican forums), this will help. Thanks. |
In the shop at Pelican
cam timing
rear wheel bearings |
MAGA
Engine rebuild.....compared to many other types of auto and aircraft engines I have rebuilt, the flat six is definitely the fussiest.
Headliner is not too difficult, just time consuming.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Re: What?
pedal cluster clutch spring tip
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD |
Replacing the cabriolet top on mine. It almost drove me nuts
. It took me several days to do it correctly. I now know why the places charge so much for an entire Cab Top replacement(the front fabric and rear window sections) and I decided that I would never do it again. MAJOR PITA!!!!
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
