How about the first oil change?
Seems like everyone screws that one up one way or another.
Andy 83 911SC Targa |
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S. www.TheLolaRegistry.com "When you think you are in full control, you're just not going fast enough." Last edited by Gearbox; 01-02-2007 at 12:34 PM.. |
He's a LOT better at it than that!I actually wondered the same question when I read your response. I figured there MIGHT be some sort of a paintable patch but you wrote that you repainted them which sounded like a full repaint job... struck me as, "Why would anyone do that?" So, add me into the smartass category....old-timers division
Dan in Pasadena '76 911S Sahara Beige/Cork |
Replacing the dome light switch on the drivers side trying to feed the new wire from under the dash to the back of the switch is nearly impossible
Welding the new engine mounts for the short block Chevy engine.
JK
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
chasing any electrical gremlin...I still have a few
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
#29 SCWDP (muhaahhh!!)
Try pulling the engine wiring harness back into the engine compartment thru that little hole! Loads of fun!
IslandmanFL SOLD...78 911SC (ROW) cabriolet/widebody hear BEBE purr!! 92 325is Now living in Sunny West Palm Beach FL! |
Slumlord
1. Clutch spring. Yes the washers help, it still ain't easy.
2. Rear ride height. (Front is easy) 3. I will see your Cab top and raise you a rear seal. Oval Case+round seal=big leak. I had to bore it out (assembled), make a 0.010" ring shim and install a new seal. I took the engine out three time before I figured this out. Pictures to prove it... Who can top this? |
83SC black on black 01 Chevy S10 08 Buick Enclave |
Rear Wheel Bearings
'78 Targa Sold! '84 Carrera Sold! '01 996 Wrecked |
Milt,
Sorry if I misintepreted your tone. It is hard to gauge the written word some times. I think everyone here benefits from your addiction to the Board, so don't let my mistake change that. Mark
Mark Isaak 1974 Carrera Targa - Light Yellow, Being driven 1974 Carrera Targa - Orange, Being restored 1974 Carrera Targa - Lime Green, Being pampered 2017 Macan |
19 years and 17k posts...
Re: Re: What?
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Mark,
you have a PM. Ron
Throw it on the ground!
Allan, thanks for the hot water tip on the hood badge gasket! I'll give it a try.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Czar of C.R.A.P.
Everything I have touched in the last year.
I also vote for CV joints - just plain nasty. Most frustrating however has to be when any of the million or so allen heads on the car round out. Especially the ones on the head studs. Oh yeah and checking your perfect "runs like a top" engine while you have it out so you can post about how great your leak down numbers are only to find to bad valves - very very frustrating.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Virginia Rocks!
Things that sucked and I haven't blocked out of my memory:
- Attaching the little retaining clip on the accelerator linkage in the engine compartment. - Squeezing that O gasket for the shift rod through the metal bracket. - Bashing the clutch helper spring off the rod (came off in layers). - Trying to attach a targa bar cover from a different car when the powdercoater ruined mine. I have a *long* list of unpleasant 944 jobs
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
gas tank flap spring
Nut's
replacing the gas tank flap spring while the newly painted fender is on the car.
_____________________ Mark 911 T 1972 Black almost done! |
1. Trying unsucessfully to mate the engine back to the tranny after a clutch job. After two days of back-breaking struggling, discovering the flywheel sent to me was wrong-it was a for a 964.
2. Removing the fuel injection hoses for replacement on a 3.2 without dropping the engine. My sanity was tested and my back nearly crippled on that one.
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) Last edited by plymouthcolt; 01-03-2007 at 03:00 PM.. |
