clock fix if anybody is interested
Kind of remember reading that a lot of clocks aren't working, as mine wasn't for 10 years till I told myself its already not working so I took it apart and fixed my clock in about 45 min total on a 73, very easy and quick if anybody is interested I'll post pics and instructions
Old 05-22-2007, 03:20 AM
gumby's Avatar
Great ! please do.
Ron
73.5 T
74 R90/6 (Tupelo Honey)
86 Carrera (Plan B)
1987 BMW K100RS Motorsport
Old 05-22-2007, 03:32 AM
Throw it on the ground!
Toby, my clock works but white second hand does not. Any ideas?
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 05-22-2007, 03:34 AM
fanof911's Avatar
Hi
Yep please do , I'm also interested in your fix
Fanof
911SC 83
132kmiles
Black, Turbo tail
Black leather interior
Old 05-22-2007, 03:40 AM
Thanks!
Oops....a search on this subject indicates white hand is not a second hand - it is an elapsed time marker (which explains why I can move it manually). Guess my clock working properly.
Mark
1987 911 Coupe
Old 05-22-2007, 03:59 AM
well first i took out the clock, then the three little nuts on the back one has a lock on it I just broke that little piece so the nut could come off, then there are three more nuts on the inside back took those off. Basically its a wind up clock that rewinds every 20 sec or so with a magnet on a spring and a set of points that gives it power to wind. All that was broken on mine was the lead from the power in to the coil. Just tinned the points, soldered on a piece of metal from a resister and clipped it. resprung the little clicker when putting it back together and tick tick first two picks are were the wire was gone next two with resister soldered on. No pics of clipping it but you can figure that out and last two clock jumpered on battery and moving. Also in near the middle of the back a little to the right and up is a adjuster in case its running slow or fast and my second hand dosn't move but the clock moves. Haven't figured that one out yet Hope this helps some of ya
Old 05-22-2007, 04:17 AM
makes sense on the white hand now i don't have to worry about it thanks
Old 05-22-2007, 04:19 AM
Semper drive!
rcecale's Avatar
Toby,
Great fix! Thanks for the pics.
Now I just gotta figure out how to keep my clock from becoming all blurry once I do the repair!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 05-22-2007, 04:51 AM
dlagerstrom's Avatar
The point you soldered is basically meant to be a fuse. They originally used a low temp solder so that if it got too hot it would pop open. If you use standard solder, you run the risk of melting your clock. I put a really small diode in instead as I couldn't find the low temp solder.
I seem to be able to blow up small diodes with enough current so I thought it would be a good substitute for a fuse.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 05-22-2007, 05:56 AM
KCinBR's Avatar
Thanks, I too was wondering why the second hand (lil white hand) was not moving
Just too phreaking simple
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 05-22-2007, 06:06 AM
Thanks for the heads up on the low temp solder, think i'll leave the metal from the resister with reg solder and just put a .75 amp in line fuse before the clock. Maybe make it easier next time if it blows the fuse.
Old 05-22-2007, 06:30 AM
There was a guy selling a clock in classifieds about a week ago... said it worked except the second hand.
Old 05-22-2007, 12:03 PM
3.2 CAB's Avatar
I had a clock in mine, it worked fine..., just as long as the engine was running??????? Just as soon as you turned off the car, the clock would go into "REST MODE" and not do a thing until I started the engine again. I guess it would have been a great hour meter of sorts, but you could not tell time. I picked up a used one from Oklahoma Foreign, was about $30.00 at the time. I removed the old clock, plugged in the "new" clock, it has been working perfectly ever since. I never could find out from anyone why the original one was acting like it was. I can't even remember the amount of times I took it out and checked it, but it never did work, except when the engine was running. I am very happy now that I can see what time it is, and the old one is in the box, I guess for parts if ever needed. Just my .02 on this subject.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 05-22-2007, 12:18 PM
Okay, that is really wierd. At first, I thought you must have had a switched power connection that went off when the ignition was off. But if you replaced with another clock and didn't change any wiring, how does the new one work?
The coil that pulls the winder represents an inductive load. Is it possible the battery didn't have enough voltage to kick the coil and with the engine running, the alternator did have enough? Any EEs want to speculate?
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 928
Old 05-22-2007, 02:27 PM
3.2 CAB's Avatar
Has worked great ever since. I still have no idea what the deal was. I did not change anything other than to remove old clock and plug in "new" clock. As far as the voltage as being a problem, the car always started and never had any low battery symtoms. It is still a mystery to me???
Newest additions-
others...
Old 05-24-2007, 07:27 PM
Originally posted by toby1 73t
magnet .........All that was broken on mine was the lead from the power in to the coil.
Did I hear the words "Magnet" and "Coil"?
If someone has a coil that has actually failed, I'll bet you I can fix it.
I would need a broken clock, or at least the coil, to dissasemle and examine. Count the turns of wire, the winding pitch, and the wire guage..
Mount the Coilform to this, and wind away...
The blood of my life:
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 05-24-2007, 07:42 PM
Not as it seems
juanbenae's Avatar
are you guys kidding on the white hand?
i assumed it was a rallye inspired thing? if you pull the knob out you can move it around the face and "mark" a time. as an enduro rider from way back time and distance can reveal average speed.
you guys really are joking about the white hand right? my take may suck,,, but i had one.
T$
Old 05-24-2007, 09:28 PM
slodave's Avatar
My clock stops every winter - like clockwork. Then when it warms up, it works fine again. It also works in winter, after the car is started or if I move the hands. Living in SoCal, so I'm not talking sub freezing temps here. I have been lazy to take it apart, but looks simple enough. Tomorrow's project.
Dave
Old 05-24-2007, 10:06 PM
3.2 CAB's Avatar
Sounds like the old lube is gumming up in the cooler weather. Probably it just needs cleaning and new lube.
Newest additions-
others...
Old 05-25-2007, 11:56 AM
Crusty Conservative
silverc4s's Avatar
Dave
Over the years the clock's lubricant hardens and is the primary reason that the fuse link blows and the clock stops. If you are making on run again, you should clean and re oil it before repalcing the fuse link, or you might eventually get an unwanted electrical event behind your instrumnet panel...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 05-25-2007, 12:40 PM
