Zeke's Avatar
Can you think of what else to unplug before welding?
DME, DME relay, wires to coil, three sensors.
How 'bout the plug(s) at the rear relay board?
Where is the speedo pick up?
Old 09-29-2007, 12:19 PM
DUK DUK is offline
DUK's Avatar
Milt, our rule is anything that pertains to charging system and ignition. So Battery (at least the ground), alternator, coil, distributor, dme, etc.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 09-29-2007, 12:27 PM
Zeke's Avatar
OK, I didn't forget the battery here, just on my post.
Any way to disconnect the alt externally?
On second thought, I'm welding on the muffler. I think I'll remove the muffler instead.
Old 09-29-2007, 12:30 PM
Zeke's Avatar
...waiting for the PB Blaster to do its magic.
Anyway, this stuff is good to know. This ol' '88 is a lot more complicated electrically and electronically than my '71.
Old 09-29-2007, 12:56 PM
Early_S_Man's Avatar
Porsche Crest
Milt,
Factory alarm module is famous for dying at the paint & body shop, and rendering the car un-startable!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-29-2007, 05:28 PM
Zeke's Avatar
Originally Posted by Early_S_Man View Post
Milt,
Ouch. Glad I just removed the muffler instead. And, I found the hanger was broken, so I got a little extra repair in.
Gonna take a ride tomorrow!.
Thanks, Warren.
Old 09-29-2007, 06:58 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Yet another convincing argument to go with carburetors.
Black Cars Matter
Old 09-29-2007, 07:30 PM
Zeke's Avatar
Not really. You still have the 14 pin connector, the dizzy (especially the tach lead on early cars), the battery, the CDI and maybe some more. All these cars are different.
But the later ones can get harmed easily, IMO
Old 09-29-2007, 08:58 PM
Crotchety Old Bastard
RarlyL8's Avatar
Wouldn't proper grounding take care of any non-computer issues?
I've been welding on my car for years with no problems.
Old 09-29-2007, 09:07 PM
I've done quite a bit of welding on my '85 and other than disconnecting my battery I've done nothing special. Never had a problem as a result. Luck perhaps?
Warren & Ron, may you rest in Peace.
Old 09-29-2007, 09:16 PM
BertBeagle's Avatar
I have welded on lots of cars - call me crazy - but never unplugged anything and never a problem. I just put the ground clamp directly on the part I was welding which was almost always something on the exhaust system. Some of those cars had some very sophisticated electronics.
Old 09-29-2007, 09:34 PM
rnln's Avatar
I have taken my cars to exhaust shop many times. As BertBeagle said, they never unplug anything even when I requested to unplug the batery neg cable.
Fat butt 911, 1987
Old 09-29-2007, 10:07 PM
Zeke's Avatar
Well, I guess there are two sides to a story. But, if something goes wrong, or you touch something you shouldn't in the darkness of the helmet, then it could be a problem. Someone recently blew their CDI (actually an MSD unit) by just touching and grounding the battery cable at the starter.
Old 09-30-2007, 11:53 AM
rnln's Avatar
It's always good to be extra careful isn't it.
Fat butt 911, 1987
Old 09-30-2007, 01:11 PM
Clamp the welding ground cable close to the weld area (to ground). Since electric welding is a form of resistance welding (the welding tip creating the air gap resistance), the closer the ground clamp to the weld area, the shorter the current path. That's why welding a muffler is pretty safe and welding close to an ECU isn't. It's still a good idea to disconnect the ground cable, just in case.
Sherwood
Old 09-30-2007, 04:03 PM
