Another option for 911 roll bars.
This is what I have been working on at work for the last few days. It's a weld-in roll bar system for non-sunroof coupes, and sunroof coupes (possible for Targa's too but I haven't confirmed this yet). This roll bar is perfect for the enthusiasts who are serious about track events, and want more performance than bolt-in bars offer. This bar is extremely tight fitting to allow the most head-room and body clearance possible. It is also upgradable to a full cage later on so your chassis can evolve as your driving skills and and commitment to racing increases. The bars are constructed using American made DOM steel tubing. The main hoops are made from .120 wall 1.75" tubing, and everything else is .095 1.5" tube. They are completely TIG welded with top-notch fabrication and attention to detail. They are going to be sold through my employer (I need to get permission before I give the name out) as soon as we are done with the first production run and crunch some numbers to get a price. I can say that they will be competitively priced, and available in bare metal, or powder coated with the base plates left bare for welding. Let me know if you have any questions, and PM me if you want to secure one from the first production run. Right now, we are doing 5 sunroof coupe bars, and 5 non-sunroof coupe bars. Just to be clear, I'm not personally selling these, I am just getting the word out for my employer.
The first 5 non-sunroof bars lined up...
Some shots of how they fit in the car (the car pictured was a sunroof car that is getting a fiberglass roof skin and full cage)...
Here you can see some examples of the tight tollerences that are kept with every notch before final welding. This insures the very best weld quality and strength...
Finished bar ready to be removed from the fixture...
Old 11-30-2007, 07:49 PM
JMatta's Avatar
Nice...my roll bar/cage was built by Fabcar some years ago. Can't beat good quality!
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 11-30-2007, 08:42 PM
Price?
Old 11-30-2007, 08:55 PM
Registered Cruiser
jorian's Avatar
Nice welds.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 11-30-2007, 09:02 PM
PRO Motorsports
Tyson Schmidt's Avatar
Very nice!
That'd also be a great starting place for a full cage as well.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 11-30-2007, 09:04 PM
Originally Posted by JP911 View Post
Price?
The price hasn't been worked out yet because I'm not done with the first production run. I should have a price nailed down for your guys by next week.
Old 11-30-2007, 09:07 PM
PRO Motorsports
Only one criticism though. Most club rules state that all main (required) tubes must be of the same diameter.
2004 GT3
Old 11-30-2007, 09:08 PM
Originally Posted by Tyson Schmidt View Post
Very nice!
That was the plan with this roll bar/cage. We wanted to make something that was part of an expandable system. There are a lot of enthusiasts who start their racing "careers" by taking their street car through the driver's education process. This usually mandates a racing seat and harness to keep your body planted in position so you can use your arms and legs for for operating the controls instead of keeping your butt in the seat With those key items comes the need for some kind of roll bar/harness bar, and with some sanctioning bodies, a seat back support. A harness bar is really not adequate for this kind of performance driving. With this roll bar, the owner can still retain the street-ability of their favorite car, and if they decide to continue to the next level, their existing roll bar is easily converted to a full cage.
Old 11-30-2007, 09:20 PM
Tom '74 911's Avatar
kcpaz -
I might be interested in a sunroof coupe version. I will send you a PM.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 11-30-2007, 09:33 PM
A lot of the regulations for cages are determined by vehicle weight. Any potential buyers should check the specific rules for the sanctioning body that they are planning on participating with. If the rear hoop support bars need to be made from 1.75" tubing to be within regulation, then that is a substitution that can be made when ordering.
Here are the 2007 PCA rules for roll cages taken from their web site...
Roll Bars and Cages: The roll bar/roll cage must be securely mounted with the mounting plates at the
bottom of the hoops mounted directly to the floor and/or longitudinal members of the unibody and make
metal to metal contact. Any padding, carpet, upholstery, etc. must be removed to satisfy this requirement.
The mounting area of bolt-in roll bar/roll cage must be backed by a plate of a size equal to that of the upper
mounting plate with a minimum thickness of 3/16”. Bolts must be grade 5 or higher. The roll bar/ roll cage
must be full cockpit width, except as originally supplied by the factory for open racecars, and have two
fore/aft braces of tubing size equal to the main hoop. The braces must be mounted as near to the top of the
main hoop as possible at an included angle of at least 30 degrees. Additionally, the assembly must contain a
transverse (left to right side) brace. Roll bar/roll cage tubing in the Stock/ Prepared Classes must remain
within the passenger compartment. The removal of the driver’s side door panel and glass to facilitate side
impact protection is allowed in all classes.
Roll Bars: All provisions for Roll bars and cages apply. Note that roll bars without terminal mounting plates
braced on the frame either on or parallel to the floor are not acceptable. The top of the main hoop must be
at least 2" above the driver’s helmet when the driver is seated in the normal driving position.
Roll Cages: If a full cage is required, the top of the front hoop and the top of the main hoop must form a
plane that is 2” above the driver’s head in both closed and open top cars.
An inspection hole 3/16" in diameter must be provided in a non-critical area for verification of tube
thickness. Any portion of the assembly which may come in contact with the driver’s helmet must be
covered with high density foam 1" thick held securely in place with zip ties, electrical tape or duct tape.
Foam must be equivalent to SFI 45.1 or FIA 8857 standards for hardness.
Minimum Roll Bar Tubing Sizes Car Weight without Driver
Under 1500 lbs Over 1500 lbs
Mild Steel 1.5" x .120" 1.75" x .120"
Alloy Steel 1.375" x .090" 1.625" x .095"
Minimum Roll Cage Tubing Sizes
For cars with roll cages, the main and front roll hoops must have the following minimum
diameters and wall thicknesses:
Under 2500 lbs Over 2500 lbs
Mild Steel 1.50" x .095" 1.75" x .095” or 1.50" x .120”
Alloy Steel 1.375 x .095" 1.50" x .095"
Factory Roll Cages with documentation (matching serial number to certificate) are allowed.
Old 11-30-2007, 09:34 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
sub'd
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 12-01-2007, 09:51 AM
Driving member
jester911's Avatar
Very nice work. Keep us informed on price and new developments.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 12-01-2007, 10:49 AM
Just got a PM from a concerned member....
"I am not a moderator or affiliated with Pelican other than being a member, however, you might consider approaching Wayne at Pelican about selling stuff on his site, possibly in competition with him. The classified section is usually for selling used stuff that does not conflict with his business."
My response to this was...
"Thanks for the tip. I realize that using public forums for advertising is a slippery slope. I'm trying to be careful not to use this forum for this. I'm simply trying to expose people to a new product for their cars. I will be sure to contact Wayne before posting any prices of buisness names. Thanks."
Just to be clear. I do value this forum and I don't want to burn any bridges. Moderators please let me know if I have crossed any lines so I can adjust the thread accordingly. Thanks
Old 12-01-2007, 11:13 AM
We really need a bar for the early sunroof 911s.
Richard
Old 12-01-2007, 12:39 PM
Could one also request the diagonals to fix to the main hoop on the other side (for RHD car.)?
Old 12-01-2007, 12:52 PM
Richard
I'll look into that. I think we may have a 70' sunroof coupe in the shop but I'm not 100% sure. To be honest, I'm not even sure what the difference is between late and early sunroof cars. Maybe someone can educate me on this.
Old 12-01-2007, 12:56 PM
That shouldn't be a problem at all. Everyone just needs to keep in mind that custom requests like this might add extra cost and/or time. Switching the location of the diaginals would be an easy thing to do, but may require making a bar in addition to the standard production runs, unless the timing is just right.
Old 12-01-2007, 12:59 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
sub'd. Awaiting further info
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 12-01-2007, 01:00 PM
"farking Porsche hero"
Rich Lambert's Avatar
Swb?
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 12-01-2007, 09:25 PM
Originally Posted by Rich Lambert View Post
Swb?
probably not if they are different than the LWB cars. Just not enough market to justify making another fixture.
Old 12-02-2007, 12:12 AM
