More acronyms:
FD = Fuel Distributor
AFR = Air to Fuel Ratio
FV = Frequency Valve
AFM = Air Flow Meter
CD Box = Capacity Discharge Box
What about ISV & ECU
Old 01-18-2008, 01:07 PM
Jim Williams's Avatar
Originally Posted by tngirl74 View Post
Ask Beetle Bailey, still working on a '69 911, what his favorite acronym is:
PPP.....Piss Poor Planning
tngirl74 - if it wasn't for physics and law enforcement, I'd be unstoppable.
'88 911 Carrera Cabriolet
In my early work environment, I learned a variation of this one, called "The 7 P's".
"Proper Prior Planning Prevents Piss Poor Performance...."
Never forgot that one.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 01-18-2008, 02:21 PM
Autodidactic user
David E. Clark's Avatar
Here are a few serious websites that may help with this project:
AUTOMOTIVE ACRONYMS
Car & Automotive Acronyms
AUTOMOTIVE ACRONYMS
Abbreviations, Acronyms and Initialisms
and one funny one:
Automotive Acronyms
* notice that no one has come up with a put-down acronym for Porsche yet!
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 01-18-2008, 03:24 PM
Thrlls's Avatar
ICV = Idle Control Valve
This is great Randy!
I've learned alot just by what's here now.
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 01-18-2008, 03:50 PM
AutoBahned
RWebb's Avatar
glad it's useful
SWB was posted above, but LWB was not...
LWB = Long WheelBase, technically it could refer to any 911 during or after 1969, but in practice it is usually restricted to mean those from 1969 to 1973 (i.e. the LWB early cars with long hoods).
Old 01-18-2008, 04:23 PM
evergreen's Avatar
Excellent thread. Rwebb posted SAE.... Society of Automotive Engineers
What is DIN? (pertaining to horsepower.. for that matter what about BHP?) anyone pls jump in w/short explanation of methods used for SAE vs. DIN horsepower ratings; for instance, early 911E listed @ 158HP DIN but @ only 140HP SAE.. (I might have those reversed)..thks
Old 01-18-2008, 08:05 PM
AutoBahned
RWebb's Avatar
DIN = Deutsche Industrie Normal (did I spell that right)
Who remembers the years and specific auxillary devices involved in the hp changes?
SAE hp - used to allow the manf. to disconnect all (?) or most power robbing accessories (alternator, power steering pump, etc.) and ws much higher than DIN hp.
In the year _____, SAE switched to a measurement protocol that required some or all acc. to be connected, and was about equal to DIN. They called that SAE Net hp, and went back and called the old way SAE gross hp. So the same hp might be labelled SAE in something written in 1961 (a guess), but called SAE gross hp in something written in 1988.
There may be other stuff, but is all I recall at the moment. I bet Google would pop up the "rest of the story."
Old 01-18-2008, 10:01 PM
oceanvue's Avatar
here's one
What's WOT? Is that an acronym?
'89 Carrera Metalic Satin Black Silver Edition
'89 928 Silver S4 EUROMSL..SOLD
'93 968 Black
Old 01-18-2008, 10:18 PM
oceanvue's Avatar
Oh and in case you come across any 928ers and you hear them refer to an OB that means "old bastard" refering to the early 16 valve cars.
'93 968 Black
Old 01-18-2008, 10:20 PM
AutoBahned
RWebb's Avatar
WOT = Wide Open Throttle, aka Wheeee!
Old 01-18-2008, 10:24 PM
Registered Usurper
DARISC's Avatar
Has BTDC been mentioned (degrees Before Top Dead Center)?
'82 SC RoW coupe
Old 01-18-2008, 11:04 PM
Sadly i havent seen PPOT= Pelican Parts off Topic.
Old 01-18-2008, 11:16 PM
Registered Usurper
DARISC's Avatar
Maybe because it's OT?
'82 SC RoW coupe
Old 01-18-2008, 11:26 PM
rexav8r's Avatar
Great thread idea !
I may have over looked it, but in the very first post you called the early cars "Long Nose". I've always heard "Long Hood".
Could you also add the different "states" of an engine, such as what components are actually included in a "long block" that's for sale v/s a "short block" or the other alternatives ???
Richard W.
Red '70 E, 2.2
White (w/ Red & Blue), '82SC, "Frankenstein" -a bit tweeked
Old 01-18-2008, 11:49 PM
Autodidactic user
What is DIN? (pertaining to horsepower.. for that matter what about BHP?) anyone pls jump in w/short explanation of methods used for SAE vs. DIN horsepower ratings; for instance, early 911E listed @ 158HP DIN but @ only 140HP SAE..thks
The very simple answer is in Wayne's book: How to Rebuild and Modify Porsche 911 Engines 1966-1989 on page 198, "The value of SAE and DIN horsepower are very similar with 1 SAE HP being equal to .98629 DIN HP."
In general, horsepower is a measurement of the engine's ability to perform work. SAE is measured in pounds and DIN in kilograms. One SAE horse is the ability to lift 33,000 lbs one foot in one minute. One DIN horse is the ability to lift 450,000 kg one cm in one minute. Thus, for the same power the SAE measurement is 98.629% of the metric DIN measurement. As Wayne points out, not much difference!
There are now various SAE measurements such as "Brake horsepower" (BHP), "Certified Horsepower," "Gross Horsepower" which all measure the HP in different ways by taking into account the loss caused by various mechanical components (gearbox, engine accessories, emissions controls, exhaust system etc). These specific SAE measurements would modify the above answer with different mathematical calculations so consider the above answer a "general rule." For a more thorough answer, check out: Wikipedia - Horsepower.
Old 01-19-2008, 04:47 AM
AutoBahned
RWebb's Avatar
thx - i'll delete my post to clean up the thread...
Old 01-19-2008, 01:08 PM
AutoBahned
RWebb's Avatar
Short Block vs. Long Block
Short-block vs. Long-block question
Old 01-19-2008, 01:12 PM
AutoBahned
RWebb's Avatar
NVH = Noise, Vibration, and Harshness -- bad things that designers attempt to eliminate from suspension systems, motors, etc. -- even in sports cars
Old 01-23-2008, 08:33 PM
rexav8r's Avatar
"Short Block vs. Long Block
http://forums.pelicanparts.com/showt...ort+long+block"
----well, don't I look like the guy that doesn't know how to use the search bar.
(maybe it'll still make it in the Wiki though..)
Thanks !
Richard W.
Red '70 E, 2.2
Old 01-23-2008, 09:17 PM
Marco8's Avatar
Here's something for the 993 brothers.....
CEL check engine light
SAI secondary air injection (often the cause of a CEL)
96 993 coupe
88 911 cab (gone, but not forgotten)
Old 01-24-2008, 06:08 AM
