AutoBahned
RWebb's Avatar
MY Model Year
P AG or PAG - Porsche AG, the factory (AG stands for the the type of business organization, roughly equals "Inc." in the US)
Old 01-24-2008, 11:01 AM
AutoBahned
RWebb's Avatar
CHT = cylinder head temperature; usually much higher than the oil temperature; commonly measured at the base of a spark plug with a thermocouple
Old 02-02-2008, 06:20 PM
AutoBahned
RWebb's Avatar
Moon Plates - a double hole, elongated, thick washer or spacer used on certain 911 constant velocity (CV joints)
Schnorr Washers - a lock washer with sharp edges made in a concave shape (when viewed on edge). They may be a type of Belleville washer or may be only similar to them (not sure if that was ever settled). They were used on certain 911 CV joints.
Many think both the above should be added to the later 911 CV joints (which left them out, perhaps for cost cutting). Slightly longer bolts (cap screws) would be needed and these are a 12.9 high-strength fastener.
Old 05-21-2008, 05:29 PM
No new acryonym - just a clarification: The Belleville washers that I ordered for my car (because it seemed like a good idea, given the advice on this forum) were manufactured by a company called Schnorr. So I suspect the terms are interchangeable. I ordered these (and tons of other stuff, it's been crazy) from McMaster-Carr. They have a warehouse in Cleveland so I get all my stuff the next day. (Find a worn or just an annoyingly 30 year old and dirty fastener and have 20 more like it the next afternoon for $8. Good stuff.) Cheers, Scott
1978 911SC RoW
work in progress
Old 05-21-2008, 11:30 PM
Skunk works
JV911SYDNEY's Avatar
great thread!
havent seen "WTF" yet
964 RS-4
Old 05-21-2008, 11:47 PM
AutoBahned
RWebb's Avatar
Internet Abbreviations are in another thread - thiss one is for Porsche mechanical ones.
R&P = ring and pinion -- the thing in the big back housing of the transmission that transforms rotation along the longitudinal axis (from the motor) into lateral rotation (for the wheels)
CWP = Crown Wheel & Pinion - same as R&P, above
Old 05-22-2008, 12:37 PM
One that we have all experienced while working on our cars,
SNAFU = Situation Normal All Fu*ked Up. This is the original definition from World War II.
The modern press has tried to clean it up to Situation Normal All Fouled Up. I laugh every time I hear a news anchor on TV say something like "A major SNAFU in traffic today"
Old 05-22-2008, 03:18 PM
BAR = well, I don't know the acronym, but it stands for one unit of pressure equal to the force of the earth's atmosphere at sea level, and translates to about 14.5 to 14.7 psi.
PSI=pounds per square inch, a unit of pressure.
ICV=idle control valve, the bane of many 3.2 911 owners.
PCAR=I hate this one. I'm not going to translate for you guys.
druck pres=oil pressure. Did someone already cover this?
SAE=Society of Automotive Engineers. Randy already covered SAE HP. These guys set many of the standards that we use to measure stuff. Sometimes we refer to SAE vs. Metric, in which case we are drawing a distinction between English or Standard bolt sizes vs. Metric bolt sizes.
ISO=International Organization for Standardization. This should be IOS right? I'll bet they're Frenchie or something. When we refer to ISO rating of 12.9 it means we are specifying a bolt strength rating, rather than just saying "aircraft grade". It's better to quantify these things, and sometimes you want the strongest bolt you can get. Usually ISO 8.8 is what we use on Porsches.
O2=oxygen
CO2= carbon dioxide
HCO=hydrocarbon
PET= I don't know this one. It refers to Porsche's parts inventory system, that's all I know.
POS=anything from either Weltmeister or Harbor Freight Tools. Ok, not their airtools, but certainly their welders, wrenches, and electric dye grinders.
Old 05-22-2008, 03:23 PM
Thrlls's Avatar
And I thought POS meant "Porsche Owners Society"...I guess I was wrong.
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 05-22-2008, 05:24 PM
Member 911 Anonymous
DRACO A5OG's Avatar
RSD = Rubber Side Down
Not mine Borrowed
Hey I thought POS stands for Previous Owner ShiestHead?
'85 Carrera Targa
PCA/POC
Old 05-23-2008, 01:37 PM
Fahren mit dem Wind.
mhackney's Avatar
The late, great Harry Pellow always used a unit of measure in his writings:
BCH= blonde c*nt hair = .001" (if I remember correctly)
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 06-06-2008, 10:39 AM
Peter Zimmermann's Avatar
OK, excuse any repeats - I just caught up to this thread...
"TC" = Traction Control
"PSM" = Porsche Stability Management
"PASM" = Porsche Active Suspension Management"
"ECU" = Electronic Control Unit
"ABD" = Automatic Brake Differential
"ASR" = Automatic Slip Regulation
"DDD" = Dynamic Driving Differential
"PCM" = Porsche Communication Management
"E-Gas" = Electronic Throttle
"OBD" = On Board Diagnosis
"Sport Chrono Package" = Aggressive electronic management maps available since 2005 models.
"Dual Mass Flywheel" = Invention that dramatically reduces transmission noise.
Cheers!
Keep the Shiny Side UP!
Pete Z.
Old 06-06-2008, 11:19 AM
AutoBahned
RWebb's Avatar
Thanks, Pete.
I hope this will be Wiki-ized soon...
Old 06-06-2008, 12:16 PM
AutoBahned
RWebb's Avatar
Pano - Panorama - a magazine about Porsches, published by PCA
PCA - Porsche Club of America
UpFixin' - a series of paperback books, now discontinued, that compiled numerous technical, new product, and other articles from Pano. There were about 8 volumes int he series.
Excl. - abbreviation for Excellence, an independent US based magazine on Porsches
Old 07-31-2008, 11:55 AM
Druck Press: Press press. A bilingual marking on the Oil Pressure gauge to catch the unsuspecting.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 07-31-2008, 12:56 PM
AutoBahned
RWebb's Avatar
Schnorr washer (often mis-spelled Schnoor, or Shorr, or Shoor - use these terms in the search engine to find add'l threads beyond the ones with the correct spellin)
A "Schnorr" washer is a hardened steel, ribbed or serrated Belleville-type spring washer. It is used for fastener locking purposes. The ones on the CV joints should be replaced every time you dis-assemble the joint.
http://www.schnorr.com/safetywashers.html
Old 08-11-2008, 10:56 AM
AutoBahned
RWebb's Avatar
ROW = Rest of the World, as opposed to U.S. Market (the latter often includes Canada)
JDM = Japanese Domestic Market
WUR = Warm-Up Regulator, an integral part for the success of a CIS (continuous injection system) fuel injection system
AAR = Automatic Air Regulator - another CIS component
Old 11-16-2008, 10:54 AM
1968 2.0s
What does the `J` denote, as in 7J Fuchs wheels? Are different types/styles represented by other letters?
Thanks, Mike.
1968 Super. 1959 Super.
http://tinyurl.com/pbvfl5w
Will this learning curve ever level out ?
Old 11-16-2008, 01:56 PM
Thrlls's Avatar
Fixed...
Woody
Slow n Fast
Old 11-16-2008, 02:03 PM
rodoredas's Avatar
Cookies - ATS Cookie Cutter rims, used on some early 944's and some mid year 911
ATS - ?
RUF - ?
Shane
1975 911 Coupe 2.7L 4Spd CIS Sporto 9115100500
1977 911 Targa, 3.0L, 5 Spd LSD, Zenith Carbs modified, SSI, Dansk 9117310158
Old 11-16-2008, 02:24 PM
