CHT = Cylinder Head Temperature
Tranny = Transmission
Dizzy = Ignition Distributor
Sneakers, Shoes = Tires
Double Clutch = Method of Manual Transmission Shifting through neutral with clutch engaged
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-07-2008, 05:22 AM
Registered Usurper
DARISC's Avatar
There are also some anachronicalisms (but, not being mechanicalstically inclinated, I don't know whether or not they're Porsche specific?) that relate to adjustifying a thermomastat, corroborater, etc., that refer to turning a screw 1 RCH. What's that one mean?
By the way, my favorite anachronicalism used to be IACOCCA (I Am Chairman Of Chrysler Corporation America).
'82 SC RoW coupe
Old 01-07-2008, 07:38 AM
@aircooledph on Instagram
jaldeguer's Avatar
How about SSi? What does that mean? I see it all the time. Thanks!
Old 01-07-2008, 08:13 AM
Kantry Member
oldE's Avatar
Long Nose = Early Car = the 911s made up thru 1973, which had a longer nose and hood than the cars with large impact bumpers from 1974 to 1989
Great idea.
I might just be sensitive, having a '69 E, but isn't the term usually: long hood?
Les
Best
Les
Old 01-07-2008, 08:53 AM
Registered Usurper
DARISC's Avatar
SSI is a brand of performance enhancing heat exchangers for 911s.
'82 SC RoW coupe
Old 01-07-2008, 09:21 AM
SSI = Stainless Systems, Inc.
dum dum = panel seal caulk
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-07-2008, 10:36 AM
Diss Member
Quicksilver's Avatar
Two favorites:
TLA = Three Letter Acronym or Two Letter Acronym
FLA = Four Letter Acronym or Five Letter Acronym
These are useful to throw into a conversation when one of the participants is trying show off or confuse people by using acronyms.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-07-2008, 10:54 AM
Not quite.
Double de-clutching.
As it implies, de-clutching twice. Pedal down--out of gear- pedal back up-blip throttle-pedal back down-in to gear- pedal back up- drive on.
I drove a crash gearbox box 16 tonne Leyland truck for 3 years & nearly 400,000 miles D-D-C'ing up & down the box.
My left leg still has the "muscle memory" twenty years on!
On a cold day the oil was so thick the first few changes always resulted in the dreaded grinding noise, accompanied by hoots and cat-calls from the dock loaders as I drove away.
Old 01-07-2008, 03:12 PM
Originally Posted by dagriff View Post
As it implies, de-clutching twice. .
better explain than mine... thx
I drove a 1965 10 ton La France for 10 years. Downshifting was fun and artful.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-07-2008, 05:41 PM
AutoBahned
RWebb's Avatar
PMO = carburetors - these are improved versions of the Webers used on 911s when stock
IDA, IDT - specific models of Weber carburetors
carbs = abbrev. for carburetors
ERP = Eisenlohr Racing Products; maker of high quality 911 suspension parts; see also Elephant Racing
Elephant Racing = Elephant Racing Products, company founded by Chuck Moreland which makes high quality 911 and 914 suspension parts, found more recently than ERP hence the tendency to use ERP to mean the Eisenlohr company
SRP = Smart Racing Products; maker of various high quality after-market parts, mostly suspension parts
Tarrett - maker of sway bars
Sanders = maker of hollow torsion bars; still in operation?
Automotion = originally, a paper catalog company of Porsche Parts run by a couple; it was bought out by Performance Products and the price to quality ratio changed...
Wevo = Windrush Evolution products, maker of various high quality after-market parts
Pelican = secret as to why Wayne named this company & bbs after that bird; he has promised to divulge it someday...
AutoBahned
RWebb's Avatar
H1 = H-1 = type of headlight used early on with separate bulbs and reflectors for high and low beams, which can be aimed independently of one another. Often thought to be the best lights available and expensive on the used market (~$1,200 for a good pair); NLA as new parts.
H4 = H-4 = A later type of headlight with two types: Drop-in replacements (cheapest option) for your sealed beams, or completely different light assemblies similar to an H1 in appearance. One bulb either way, aiming one beam affects the other.
[modified from a jdog post today that I have shamelessly stolen]
H-5 = H5 = some new-fangled headlight type that people talk about on this bbs
Old 01-07-2008, 05:49 PM
AutoBahned
RWebb's Avatar
SAE = Society of Automotive Engineers; a professional society that publishes various journals and papers, often online
DOT = US Dept of Transportation; has some regulatory authority over cars (safety aspects) and parts, including tires - the specifications are not anwhere as tight as for TUV
TUV = a German regulatory agency; nearly every German product must meet very tough standards set by this agency; as examples brake lines and wheel that meet US DOT standards will often not meet TUB standards
ISO = International Standards Organization; sets process and performance standards for a wide variety of products, including some auto parts
Old 01-07-2008, 10:17 PM
Lorenfb's Avatar
Check here:
www.systemsc.com/glossary.htm
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 01-08-2008, 08:37 AM
Banned but not out, yet..
RSBob's Avatar
Better add the '73 Carrera (uh oh) RS to the list of MFI cars.
Dizzy = distributor (not a 60s song by the Young Rascals)
LSD = Limited slip differential (Not Timmothy Leary's drug of choice)
Speedo = Speedometer and male swim apparel worthy of being banned.
Spacers = a piece of metal availble in varying thicknesses which is placed between the wheel and the hub to push the tires out/widen the track of the tires. (Also see Timmothy Leary).
Old 01-08-2008, 02:59 PM
Autodidactic user
David E. Clark's Avatar
Since no one has said this yet, I'll point out that Porsche has a publication (undated but apparently pre-1991) that will be useful in this effort. It's called: Porsche Technical Terms. It's 104 pages in an odd format, 4 1/2" x 11". Most of the definitions are not "Porsche specific" and are more detailed than those listed in this thread but are still useful. For example, below is the Porsche definition of DME as compared to Randy's
DME = Bosch Digital Motor Electronics - a type of electronic fuel injection, that began on 911's in 1984
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 01-08-2008, 04:13 PM
AutoBahned
RWebb's Avatar
Interesting -- it isn't online is it?
Old 01-08-2008, 04:36 PM
Autodidactic user
I don't think so ... at least I can't find it. Here's the cover:
Old 01-08-2008, 04:40 PM
Head Lady in Charge
tngirl74's Avatar
Ask Beetle Bailey, still working on a '69 911, what his favorite acronym is:
PPP.....Piss Poor Planning
tngirl74 - if it wasn't for physics and law enforcement, I'd be unstoppable.
'88 911 Carrera Cabriolet
Lady Brin
If it wasn't for law enforcement & physics, I'd be unstoppable.
'56 Chevy Bel Air ** '81 Excalibur Phaeton
'94 F250 ** '00 Expedition
Old 01-08-2008, 05:44 PM
gerrygug's Avatar
What is ROW?
2000 Boxster S
1984 Carrera
1976 912E
Old 01-09-2008, 11:27 AM
Autodidactic user
ROW = Rest of World (not made for sale in the United States).
Old 01-09-2008, 11:59 AM
