When i installed my Steve Wong chip, i re-mounted the DME on some cushy foam rubber to absorb some of the vibration- maybe cheap insurance...
Old 02-05-2008, 09:25 PM
dshepp806's Avatar
Originally Posted by ianc View Post
Great post Steve!
Posts like this kinda make me want to just take my DME out and examine it very closely. However, I have found, after a recent DME relay failure, that these cracked joints are not always obvious to the naked eye (at least not 45 year old eyes like mine), so a magnifying glass is a big help.
A question Steve: I've read of a fair number of these types of solder fractures, and they seem usually to lead to intermittent starting or running of the engine. Based on your knowledge of the DME internals, are there any such fractures that would not lead to a complete engine cutout or start failure, but instead to poor running condition of some kind?
I wish someone would compile a kind of manual of the DME itself: what each component does, and what its failure might cause.
ianc
I recall reading a thread recently relating to the ICV driver circuitry (output drivers)....Loren chimed in on this (spot on) with a study of heat specs on these particular components, as one reader speculated that these parts would bode well with better heat sinking capabilities. Ends up not really being the case. Member corrected a poor running condition (although) by replacing the drivers (IIRC). Haven't seen other failure modes relating to "running" conditions other than obvious, hard failures.
I'm looking forward to extracting mine (DME) and spending some "quality time" under bright light and magnification. As well, I'd like to scope several output points and have a look at the signals...will use my storage scope and post the photos of each waveform at the board's output connector. Should be interesting,......(wish I had a pinout box for this).
The cushioning of the box itself (mentioned above) is most definately a plus(why not?), as to reducing transmitted vibrations...smart.
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-05-2008, 10:27 PM
ianc's Avatar
I've long been intrigued with the idea of using a scope to diagnose engine troubles or motronic problems. I asked for info here:
Using an o'scope for DME\engine testing
but didn't get a single response. If you could post some shots of output, hookups, and info on obtaining an appropriate scope, I'd be greatly appreciative...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 02-05-2008, 11:23 PM
Matt
mhoffman's Avatar
Question
Steve-
with the magnified view of the failed joint, the solder joint looks pretty grainy, and given the component above it's heat output, the failure looks more like a "disturbed joint" which lead to the failure. A disturbed joint is where the solder is soft or not fully set and the then the joint is moved (like as the car is bouncing down the road)- the graininess is caused by the solder not setting properly (develops a crystalline structure I believe). Why that may be interesting is that if it is a disturbed joint, that means normal operating conditions are causing the solder to re-melt, which is a very different problem than just cracked joints, which would presumably be caused by fatigue failure or some other mechanically induced problem.
Part of the real fix may be a different solder alloy with a higher melting point...or perhaps a conformal coating on the board.
And any ideas on the yellowish precipitate? How did it get in the box and where did it come from? If it does conduct, even slightly, it will change the output of each component in the system.
Matt
79 SC Targa
87 m491 Targa
73 BMW 3.0 CS
73 BMW R75/5
88 BMW M6
Old 02-06-2008, 06:27 AM
dshepp806's Avatar
best,
Middle Georgia
Old 02-06-2008, 07:22 AM
Steve W's Avatar
I've repaired several DME with solder failures under this exact transistor. I know mechanics that have also taken apart several DMEs over the years to resolder these exact joints for this transistor. See the end of this post from a year ago for the exact same failure:
Carrera No Start; Motivated by Greed to Not Throw in The Towel--Yet
I think most of the failures are due to heat and/or over current at these junctions. This transistor switches on and off and provides the ground signal to the ignition coil to allow it to charge. The other terminal of the coil is a fixed 12 volts. It's possible that defects in the ignition coil cause some type of short that overloads this transistor. I once worked on a car that had a full Nology ignition system installed. The DME ran so hot, you really could have fried a egg on it. The case temp had to be over 200 degrees and almost burned my hand. I believe the shop who was working on it had resoldered this joint once. I couldn't say if the ignition system was what overloaded it, as I don't know how it was wired it, but if it drew it's current from here, then I would not be surprised.
Bad injectors will also cause a similar failure to the fuel injector side of the circuit. The fuel injector transistors are on the opposite end of the board mounted on a standoff aluminum heatsink. They work in the same way in that the transistors switch on and off sinking the current, acting as the grounding, while the other end of the injector is hot with 12 volts. I have a customer with a race/rally 3.2 that could not figure out why his car kept shutting down in his ralllys. He burned up three DMEs, spent about $4k in parts, replaced every single component/sensor, removed and did a full wiring harness scan, before we traced it to bad injectors. The interesting thing is that he could drive it for hundreds of miles on the street and there was never a hiccup and the DME never was hot. However as soon as the car was under racing conditions, where full throttle was norm, the DME fried and shut down within 3 miles. The big grey resistor next to the burgundy capacitor was burned black, along with some damage to the auxiliary components.
Old 02-06-2008, 11:56 AM
abit off center
cgarr's Avatar
So if you only subscribe to books and manuals, which one tells you to check the solder joints in their trouble shooting guide? Or is this just good ole common sense? Good Job!!!
______________________
Craig
G2Performance
Old 02-06-2008, 12:12 PM
scarceller's Avatar
Steve,
Great stuff! Now that I have my DME opened I will be checking. By the way a failed solder joint like this will induce it's very own heat because of the higher resistance in the joint and only make the matter worse. This type of failure/condition in electronic boards is a death spiral.
I also repaired such issues on my DME relay already.
Thanks for the great thread.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-06-2008, 12:59 PM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Now for the big question, when the transistor at T-504 fries, has anyone found a modern day equivalent?
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 02-06-2008, 03:47 PM
heiliges blechle!
The DME schematics show a NPN Darlington pair for that component. Steve W's pic shows a TO-3 package. A search turned up a transistor made by ST Microelectronics that is marketed as a ignition coil driver in the TO-3 package. ST's schematic for this part looks like the same one on the Bosch schematic.
http://www.st.com/stonline/stappl/productcatalog/app?path=/pages/stcom/PcStComGenerateTableView.onClickOfRPN&primaryheader=Transistors&secondaryheader=Transistors%2C%20Power%20Bipolar&subclassheader=Darlington&subclassid=88&rpncode=75077&producttype=product&open=&applilevel=
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 02-06-2008, 05:27 PM
Is the ICV bad or has it been replaced recently? If so, the ICV driver circuitry (output drivers) will be the source of your problem. Ask me how I know.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 02-06-2008, 07:37 PM
Large Registered Member
PatrickB's Avatar
Originally Posted by Steve W View Post
Ever since since Lucas stopped selling magic smoke, I've been trying to find a new source, but no luck yet.
Steve... I have a source! A good friend of mine restores old MG's, purely for hobby. He bought a case of these awhile back...
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 02-06-2008, 08:29 PM
charleskieffner's Avatar
sooooooooooo..... where do i buy the super zoomy full race/rally/street never have to think about the fuchin damn thing ever again 20 year leap in technology one for my 87 cab?????
or do i just carry a spare and hope to hell it hasnt come apart at the seams.
another item that has to have a 20 year quantum leap in techno to solve problemo once and for all.
NEW AND IMPROVED would apply here!
Old 02-06-2008, 08:30 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Damn, I knew this was a test. You.........
I am seriously thinking uping my DME
'85 Carrera Targa
PCA/POC
Old 02-06-2008, 09:59 PM
I don't see why that one wouldn't work. Digi-Key even has 212 in stock for $3.50 each.
Rick
88 Cab
Old 02-07-2008, 12:00 AM
ianc's Avatar
Steve, here's food for thought:
I doubt that anyone on else on this board (well, maybe one person, but who cares) has as much knowledge about the DME and fuel maps as you.
What a fabulous thing it could be for those of us who are not electronically inclined to put some of that knowledge into a small pamphlet you could sell.
Personally, I'd pay $$$ for a little guided tour of the DME with pictures and info on what each component does, failure modes, and some basic troubleshooting info and perhaps an overview of each component for the layman. Shouldn't have to be much longer than the DME test plan I shouldn't think. The thing is such a black box that anyone without a detailed knowledge of electronics, like myself, just can't make head or tail of it.
With a few evenings work, you could probably knock out something pretty good. Post it on your website with a Paypal link and wait for the cash to pile up. If you did ever think about writing such a thing, sign me up as your first customer!
ianc
Old 02-07-2008, 11:32 AM
how about just a new and improved...........bombproof,vibration proof, beer proof, waterproof, dust proof, heat/cold proofed DME in its very own lil soft and cozy foam lil house with spare DME attached that nothing can bother and it outlives all of us for some reasonable cost amount with a lifetime guarantee and free shipping!
after reading about DMEs and then having one fail...........it seems this concept would never have made it on the NASA SHUTTLE.........well maybe once, since its built on lowest bid!
Old 02-08-2008, 04:33 AM
EMJ EMJ is offline
Had the same cracked joints in my DME 2 years ago. Drove me nuts trying to find the problem. Soldered them up on the advice of this great board, put the DME back in, never had the problem again. Prior to that I was all but about ready to sell my little car. Man, am I glad I didn't.
Ed
88 911 Carrera Coupe
Old 02-08-2008, 11:38 AM
Steve W's Avatar
Shoot me his contact info!!
ianc
Whatever I know on troubleshooting and addressing all the problems on these cars, I'd post it online for everyone to access for free. I've just been too swamped with work and various projects these past couple of years to put it all up. Thanks for the idea though!
Old 02-08-2008, 12:48 PM
HarryD's Avatar
And hopefully he still has the ultra rare refill harness that is required for a proper fill:
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-10-2008, 01:20 PM
