Steve W's Avatar
Carrera stalling problem ... can you spot the problem?
The car is an 88 Carrera with ain intermittent stalling/cut-out problem. Swapping in another Motronic DME unit fixed the problem. Below is a picture of the lower board of the Motronic unit (0.261.200.082 / 911.618.111.20). Can anyone spot the problem?
Old 02-05-2008, 02:05 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Steve? Is this a test?
Sorry I wish I could help you.
Break a Leg man hope you find your issue.
Maybe if you post the known good one next to this one could help some electro guru, my .02
'85 Carrera Targa
PCA/POC
Old 02-05-2008, 02:14 AM
KCinBR's Avatar
Cold solder joint.....WHAT DID I WIN?????????
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 02-05-2008, 03:15 AM
dshepp806's Avatar
There are several joints that look suspect...I'd reflow 'em and see.
What is that crap in the upper left hand section of the pic? Doesn't look like flux to me.
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-05-2008, 03:52 AM
PeterTarga's Avatar
Bad solder on the right, seems to be broken.
Old 02-05-2008, 04:01 AM
heiliges blechle!
I see a few places that look suspect. A cold solder joint, a posible solder bridge and a couple of places where it looks like vibration or thermal could have broken the solder joint - looks like a ring around the joint.
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 02-05-2008, 04:54 AM
dshepp806's Avatar
Best,
Middle Georgia
Old 02-05-2008, 05:10 AM
dshepp806's Avatar
Specifically: the 2 joints circled, lower right. classic cold joints, as one can see the circular fracture footprint.
Best
Middle Georgia
Old 02-05-2008, 05:17 AM
Is this one?
Rick
88 Cab
Old 02-05-2008, 08:16 AM
Matt
mhoffman's Avatar
Whatever the yellowish precipitate is in the top right- looks like some leakage from above(?) If it dissolves in water and precipitates out, it probably conducts electricity...
Also that one darkened solder joint looks like is got a bit too warm- what is the component above it? It may have failed...
79 SC Targa
87 m491 Targa
73 BMW 3.0 CS
73 BMW R75/5
88 BMW M6
Old 02-05-2008, 08:22 AM
3.2 CAB's Avatar
I actually lost count of the number of "cold solder joints" along with a couple or spots that look like they got too hot. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 02-05-2008, 12:06 PM
abit off center
cgarr's Avatar
I want to know what camera you used??
______________________
Craig
G2Performance
Old 02-05-2008, 12:12 PM
burgermeister's Avatar
I see many cracked solder joints. I see some possible bridging of joints by goo or corrosion (or just leftover rosin from a previous repair) by the 2 cutouts in the board. And I see odd yellow chalky stuff in the upper LH corner - is it a solid version of the "magic smoke" that makes electronic componentry work?
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-05-2008, 01:48 PM
Steve W's Avatar
Actually I hoped Loren would chime in . . .
Keith, I'd send you a box of chocolates, but since you weren't more specific, you only get a cookie. Shoot me your address and I'll get it right out to ya.
Not sure, could be glue, or cat pee - let me taste it and I'll get back to you.
... lemme see, you may be right
Doyle, you are a genius - yes those two lower joints you circled are indeed fractured.
Originally Posted by rick-l View Post
Is this one?
Rick, although that joint does look a little dark, it looks pretty solid.
Matthew, that is pretty spot on. There is some white crap on the other side of the board around the DME connector pins that look like corrosion from a liquid. That component above the dark joint is the big gray resistor, R528. It looks OK, typically when something overloads them, they look completely burned out.
LOLs, that camera is a HP scanner - although I think a Canon SD950is is a fantastic compact.
Ever since since Lucas stopped selling magic smoke, I've been trying to find a new source, but no luck yet.
Old 02-05-2008, 02:02 PM
Steve W's Avatar
Here's a closeup of those cracked solder joints:
It belongs to the big metal transistor, T504 right above it that you see outlined in the picture below. This is a common failure point for these DMEs - the solder joints crack from heat/fatigue/overloading. This powers/charges the ignition coil and when the joints crack, you will get an intermittent connection from a joint that expands and contracts. When cold, your car may start, but when it warms up from the current flow, the joint will expand and the connection will break. When a car starts having problems starting, or cuts out while driving, this area should be checked, in addition to the DME relay.
Old 02-05-2008, 02:30 PM
Had the exact same transistor burn up in a 951 DME with the same cutout/stalling characteristics as Steve pointed out. Left me stranded on the side of the road on the way back from Laguna Seca. The TV repairman who cold soldered it for me found another 30 or so cracked joints in there. Seems to be common as the DME's get older.
'82 911
previous:
'86 951
'72 914
Old 02-05-2008, 02:41 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
subscribing, when I get a 951, I am going to need this. . .
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 02-05-2008, 04:08 PM
DRACO A5OG's Avatar
Oh my, Great post thanks Steve.
'85 Carrera Targa
PCA/POC
Old 02-05-2008, 05:04 PM
dshepp806's Avatar
always the higher power components,....heat's the enemy,..AMEN!
Best,
Middle Georgia
Old 02-05-2008, 05:12 PM
ianc's Avatar
Great post Steve!
Posts like this kinda make me want to just take my DME out and examine it very closely. However, I have found, after a recent DME relay failure, that these cracked joints are not always obvious to the naked eye (at least not 45 year old eyes like mine), so a magnifying glass is a big help.
A question Steve: I've read of a fair number of these types of solder fractures, and they seem usually to lead to intermittent starting or running of the engine. Based on your knowledge of the DME internals, are there any such fractures that would not lead to a complete engine cutout or start failure, but instead to poor running condition of some kind?
I wish someone would compile a kind of manual of the DME itself: what each component does, and what its failure might cause.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 02-05-2008, 07:30 PM
