Carrera stalling problem ... can you spot the problem?
The car is an 88 Carrera with ain intermittent stalling/cut-out problem. Swapping in another Motronic DME unit fixed the problem. Below is a picture of the lower board of the Motronic unit (0.261.200.082 / 911.618.111.20). Can anyone spot the problem?
Member 911 Anonymous
Steve? Is this a test?
Sorry I wish I could help you. Break a Leg man hope you find your issue. Maybe if you post the known good one next to this one could help some electro guru, my .02
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 02-05-2008 at 02:18 AM.. |
Cold solder joint.....WHAT DID I WIN?????????
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
There are several joints that look suspect...I'd reflow 'em and see.
What is that crap in the upper left hand section of the pic? Doesn't look like flux to me. Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Bad solder on the right, seems to be broken.
heiliges blechle!
I see a few places that look suspect. A cold solder joint, a posible solder bridge and a couple of places where it looks like vibration or thermal could have broken the solder joint - looks like a ring around the joint.
'84 M491 '07 Silverado '75 Suzuki GT550 2-stroke triple '02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train |
Best
Is this one?
Rick 88 Cab |
Matt
Whatever the yellowish precipitate is in the top right- looks like some leakage from above(?) If it dissolves in water and precipitates out, it probably conducts electricity...
Also that one darkened solder joint looks like is got a bit too warm- what is the component above it? It may have failed...
79 SC Targa 87 m491 Targa 73 BMW 3.0 CS 73 BMW R75/5 88 BMW M6 |
I actually lost count of the number of "cold solder joints" along with a couple or spots that look like they got too hot. Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
abit off center
I want to know what camera you used??
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I see many cracked solder joints. I see some possible bridging of joints by goo or corrosion (or just leftover rosin from a previous repair) by the 2 cutouts in the board. And I see odd yellow chalky stuff in the upper LH corner - is it a solid version of the "magic smoke" that makes electronic componentry work?
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Actually I hoped Loren would chime in . . .
Keith, I'd send you a box of chocolates, but since you weren't more specific, you only get a cookie. Shoot me your address and I'll get it right out to ya. Quote:
... lemme see, you may be right Quote:
Rick, although that joint does look a little dark, it looks pretty solid. Quote:
LOLs, that camera is a HP scanner - although I think a Canon SD950is is a fantastic compact. Quote:
Here's a closeup of those cracked solder joints:
![]() It belongs to the big metal transistor, T504 right above it that you see outlined in the picture below. This is a common failure point for these DMEs - the solder joints crack from heat/fatigue/overloading. This powers/charges the ignition coil and when the joints crack, you will get an intermittent connection from a joint that expands and contracts. When cold, your car may start, but when it warms up from the current flow, the joint will expand and the connection will break. When a car starts having problems starting, or cuts out while driving, this area should be checked, in addition to the DME relay.
Had the exact same transistor burn up in a 951 DME with the same cutout/stalling characteristics as Steve pointed out. Left me stranded on the side of the road on the way back from Laguna Seca. The TV repairman who cold soldered it for me found another 30 or so cracked joints in there. Seems to be common as the DME's get older.
'82 911 previous: '86 951 '72 914 |
Cigars and 911's -- Smile
subscribing, when I get a 951, I am going to need this. . .
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
Oh my, Great post thanks Steve.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
always the higher power components,....heat's the enemy,..AMEN!
Best,
Great post Steve!
Posts like this kinda make me want to just take my DME out and examine it very closely. However, I have found, after a recent DME relay failure, that these cracked joints are not always obvious to the naked eye (at least not 45 year old eyes like mine), so a magnifying glass is a big help. A question Steve: I've read of a fair number of these types of solder fractures, and they seem usually to lead to intermittent starting or running of the engine. Based on your knowledge of the DME internals, are there any such fractures that would not lead to a complete engine cutout or start failure, but instead to poor running condition of some kind? I wish someone would compile a kind of manual of the DME itself: what each component does, and what its failure might cause. ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
