Weber rebuild by Paul Abbott
I had my Weber 40IDAs rebuilt by Paul Abbott of Performance Oriented. I wanted to share what I feel was a great experience. My Webers, while in generally decent shape, had obvious signs of shaft wear and were spitting, getting hard to tune, etc. Paul came to my attention via Pelican and/or the Early S Registry. We got in contact with each other and arranged for Paul to rebuild my carbs. Paul offers several stages of rebuild, from partial DIY to a very complete rebuild. He sends you an excellent description of services, along with the costs and you choose your level/options. Once Paul receives your carbs, he analyzes the condition and gets back to you with a suggested route to take and a firmed up cost. Total turn time for my carbs was about a week or so. I received them this morning. The packaging was very good and protective. The carbs, on first impression looked very nice and clean. Upon closer inspection I could see that they were basically completely rebuilt with two new shafts, bushings, butterflys, gaskets, etc. (Looked like new! ) He also sent back all the parts that he replaced. Paul replaced one of my floats with one of his, in better shape....He tuned the carbs on his engine and had them set up close to perfect. He really went the extra mile. I installed them and the engine fired right up and, once warm, idled smoother than ever before. It ran really good, I just had to balance the carbs and away I went. Great throttle response, sound, etc. I am a happy customer and I recommend Paul highly. You can contact him at info@performanceoriented.com ......Great service and value. See pix
73 911X Cafe Racer 77 911S...off to NY 71E....off to Paris Early S #1240 Gruppe X #001 |
Shane
Good for you Al. Looks great, I was wondering about the orientation of your coil, I assume it is not an oil filled coil, if it is then it needs to be pointed down.
Shane -- 78SC Big Port 3.2 SS, 46 PMO Carbs, M&K 2/2, RARLYL8 Tuned Headers, DRC GT2-108 Cams, MSD, Clewett Wires, J&E 98mm (Disclaimer-I am a novice and pretend to know just enough to be dangerous (I have the scars to prove it). By reading my post you accept that I am not responsible for any bodily harm, mental anguish, material and/or monetary losses that may result from anything you choose to do based upon my shared experiences.)
aka 'vageen'
How did he get them so shiney? were they replated?
Part owner in the Vageen Racer 77 911S Wide Body GT2 WCMA race car 86 Slantnose 930 ...and a bunch of other iron. Yoosta have: 90 C4 Targa, 87 944 |
The bodies are bead blasted and/or ultrasonically cleaned. restored finishes and/or new hardware, etc. They look like new. Very thorough job. The new shafts, bushings, butterflies, ball studs, pump levers, etc. make them work like new too. Nice workmanship throughout.
regards, al
Very nice! Does he sell used Weber setups to replace CIS? If so, please send me a link to his web site.
'77 911s Targa with '87 930 engine '97 BMW M3 Coupe '99 Honda VFR 800FI Interceptor |
How much? I need that too. Soo much spitting!
I included Paul's email address in the first post. Here it is again. For pricing and other questions, you can contact him at this address: info@performanceoriented.com
Tell him Al Kosmal sent you.
Al,
What kind of fuel filters have you used. They are on the top of the motor and I have had an issue with crud traveling to my carbs. Thanks in advance, Tom |
