al lkosmal's Avatar
Weber rebuild by Paul Abbott
I had my Weber 40IDAs rebuilt by Paul Abbott of Performance Oriented. I wanted to share what I feel was a great experience. My Webers, while in generally decent shape, had obvious signs of shaft wear and were spitting, getting hard to tune, etc. Paul came to my attention via Pelican and/or the Early S Registry. We got in contact with each other and arranged for Paul to rebuild my carbs. Paul offers several stages of rebuild, from partial DIY to a very complete rebuild. He sends you an excellent description of services, along with the costs and you choose your level/options. Once Paul receives your carbs, he analyzes the condition and gets back to you with a suggested route to take and a firmed up cost. Total turn time for my carbs was about a week or so. I received them this morning. The packaging was very good and protective. The carbs, on first impression looked very nice and clean. Upon closer inspection I could see that they were basically completely rebuilt with two new shafts, bushings, butterflys, gaskets, etc. (Looked like new! ) He also sent back all the parts that he replaced. Paul replaced one of my floats with one of his, in better shape....He tuned the carbs on his engine and had them set up close to perfect. He really went the extra mile. I installed them and the engine fired right up and, once warm, idled smoother than ever before. It ran really good, I just had to balance the carbs and away I went. Great throttle response, sound, etc. I am a happy customer and I recommend Paul highly. You can contact him at info@performanceoriented.com ......Great service and value. See pix
RGruppe #669
http://www.x-faktory.com/
Old 03-07-2008, 07:40 PM
Good for you Al. Looks great, I was wondering about the orientation of your coil, I assume it is not an oil filled coil, if it is then it needs to be pointed down.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-07-2008, 07:55 PM
Bland
unclebilly's Avatar
How did he get them so shiney? were they replated?
Old 03-08-2008, 06:47 AM
al lkosmal's Avatar
The bodies are bead blasted and/or ultrasonically cleaned. restored finishes and/or new hardware, etc. They look like new. Very thorough job. The new shafts, bushings, butterflies, ball studs, pump levers, etc. make them work like new too. Nice workmanship throughout.
regards,
al
RGruppe #669
Old 03-08-2008, 07:23 AM
laughac's Avatar
Send a message via AIM to laughac
Very nice! Does he sell used Weber setups to replace CIS? If so, please send me a link to his web site.
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 03-08-2008, 07:32 AM
How much? I need that too. Soo much spitting!
Old 03-08-2008, 08:17 AM
al lkosmal's Avatar
I included Paul's email address in the first post. Here it is again. For pricing and other questions, you can contact him at this address: info@performanceoriented.com
Tell him Al Kosmal sent you.
RGruppe #669
Old 03-08-2008, 01:32 PM
red901's Avatar
Al,
What kind of fuel filters have you used. They are on the top of the motor and I have had an issue with crud traveling to my carbs.
Thanks in advance, Tom
Old 09-02-2008, 11:44 AM
