Dog-faced pony soldier
Subscribing.
This is great information. For one, I'm still trying to learn/understand the nuances of points ignition (I have points/CDS on my '74).
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
this is not rocket science
I had points with Bosch grease take 1,000 miles to seat. Easy to eyeball the gap and just set timing. They shouldn't pit.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
AutoBahned
looking down, there are small cam lobes on the distr. shaft. - the points arm extends past the shaft with the pivot pin on one side & the points themselves on the other side - in the middle of the arm is the rubbing block (brown phenolic 'plastic' or maybe they are black now) -- that is what is pushed up by the cam lobe & makes the points open at the end of the arm clear as mud now? |
Correct, points combined with a CD ignition will not pit, like, say, points in a 356...
Keep the Shiny Side UP! Pete Z. |
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max Sluiter
Great photo
AutoBahned
there is a slot beneath the slotted screw*
you move the points back & forth along that slot to adjust the dwell -- there is a small round tab (hidden) that is the pivot * apparently, slots were quite popular when these things were originally designed |
Designer King
And, can anyone confirm if there is a diference between an early car ignition system in which the change in dwell angle does change the timing, and a later CDI car, in which some have stated the dwell change does not affect the timing?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
A point set is just an electric switch, just like in your house. There is a voltage and current through it. Older conventional systems had the full 12v dc current used to saturate the coil going through them and needed a condenser to reduce the spark generated when the point faces had a small separation. In these systems the point faces will pit and burn themselves out in short order, longer if the condenser is doing it's job.
CD ignition reduced the voltage and current so that the point faces last far longer, in a CD the points act like a relay, the small point voltage/current controls the much larger secondary voltage/current. In both systems rubbing block wear has an effect on timing, as the block wears gap closes up and timing is proprotionally retarded. The length of dwell(point closed) determines the saturation time of the coil. The spark plug fires when the points open, then the coil is resaturated when the points close. Too little coil saturation caused by too little dwell reduces available spark energy,
Seems to me that a CDI car's timing would change, as the points are acting as a triggering device. As the block wears down the timing of when the points open changes by default, thus the timing of the CDI changes too.
I will admit that I hated the idea of changing points in my '67 912 so I went the Pertronix route and never looked back. I think I set the timing once in the three years I had that car. Scott |
Thank you Bill for your informative explanation. Analogies always work well for me.
Kirk
'83SC '76 911S - Sold. |
Bill: Thank you!
cycling has-been
not to worry
the car probably won't start at 30, 45 or 50 deg anyway. I know mine won't at 45 or 50. Bill K Last edited by bkreigsr; 05-29-2008 at 07:40 AM.. |
many thanks for this discussion. it took me right back to '73, learning how to tune & time (both incorrectly & correctly) my BMW 1600. I am tempted to drag out the old dwell meter & hook it up, just for fun!
Designer King
OK, thanks to Bill V for clarifying.
This now brings me at least back to square 1. If the point dwell angle goes from 35 to 41 degrees, and if each increase in dwell by a degree retards the timing by a degree, then if your timing was set @ 0TDC @ 35 then it would be retarded to 6ATDC @ 41. If that's the case, then why not check both timing and dwell every so often, say 3000 mi, and reset either one or both to maintain the correct optimal timing? Maybe this is self evident and others have been doing this. I have always just let the points go through their wear cycle and then replaced them @ 41. Points aren't too expensive, as Bill K pointed out, but why waste them? Who knows how much longer they will be available?
That's what many DIY's do, it would be crazy to pay a shop to do it
