Need help with brake problem
Hello, finally got my project on the road (pics to follow soon). I have taken a few short shake down trips and have encountered a brake problem.
Here is some info: per previous owner
rebuilt M calipers
new master cylinder
new pads, fluid etc.
Here is what happened:
When I went on a longer trip and the brakes heated up more, they began to gradually bind until the car was unmovable. When I came back to get the car and they had cooled off and I was able to drive it again.
So I:
Had to hammer off the front caliper
Removed the calipers to inspect and the piston moves freely.
Noticed pins centering pads had no grease.
My theory:
The pins prevented the pads from retracting as things started to heat up and expand. This explains why they were able to work again when they cooled off.
Any thoughts?
Old 05-27-2008, 06:09 PM
Old rubber brake lines preventing return of fluid from pistons?
Old 05-27-2008, 07:48 PM
nope new brake lines.
Old 05-27-2008, 08:14 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Are you absolutely certain the Spring is placed properly?
It sounds like the springs are not puting enough tension on the pads to keep them away from your rotors when pressure is released.
Placing anti sieze on the pins and spring where the back top of the pads meet the spring is a must but even if you forgot or did not have the antisieze the spring (if clean) should give enough tension to move the pads out when pressure is released.
my 2 cents
'85 Carrera Targa
PCA/POC
Old 05-27-2008, 08:22 PM
The spring was installed correctly as far as I could tell. Still confused as to why the calipers/pads not relasing when hot.
Old 05-27-2008, 08:51 PM
Max Sluiter
Flieger's Avatar
I know you said new flex lines, but it sure sounds like swollen rubber flex lines to me.
Old 05-27-2008, 08:56 PM
DRACO A5OG's Avatar
How about some pics Brother?
'85 Carrera Targa
PCA/POC
Old 05-27-2008, 09:02 PM
barney911rs's Avatar
Both fronts were stuck or just one? I agree with Flieger, it does sound like bad lines. Get some new OEM rubber lines and see if the problem goes away. One way to test this, is when they are "stuck" crack open the bleeder and see if that releases the pressure and the pads will retract. Be careful not to spray the fluid on hot brake parts, as it could catch fire.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 05-27-2008, 09:10 PM
2 more things to add:
Seemed like driver front caliper was the hottest.
The pedal became stiff when brakes started to bind.
Old 05-27-2008, 09:36 PM
do you by chance use a motiv pressure brake bleeder?
Old 05-27-2008, 10:07 PM
I have one, yes. I have not used it on this car yet.
Old 05-27-2008, 10:14 PM
Max Sluiter
Flieger's Avatar
Just throwing this out there:
Knock-back pin mechanism binding when warm?
Old 05-27-2008, 10:15 PM
I was thinking maybe the vent tube is still clamped or pinched in some way.
Old 05-27-2008, 10:46 PM
Flieger - Not sure what you mean "knock back pin" I am coming from a bmw background; same language, different terminology
Rusnak- vent tube? are you talking about the motiv?
Keep it coming guys! I appreciate it. I think it is the last thing keeping my car off the road.
Old 05-27-2008, 11:04 PM
no, the master cylinder reservoir vent tube. Crazy theory, probably far fetched, but what if someone forgot to release the tube clamp, and the brake fluid got hot, and the air in the reservoir started to expand?
Old 05-27-2008, 11:12 PM
Max Sluiter
Flieger's Avatar
I posted here before rusnak but it didn't work.
I have a tube that goes from my fluid tank vent through the smugglers' box and out the bottom of the car. Now the trunk is not wet anymore and there is blue fluid in the lines and on the ground. I guess I just go too fast. I don't have any interior in the cabin or trunk but it keeps the paint from melting.
The knock-back mechanism is a pin in inside the cylinder bore mounted to the outside cover of the caliper body. The piston has a tube protrusion with a brass tube and a spring that grabs the pin and lightly forces the piston back toward the rotor. This makes the piston react quicker and build up pressure faster:
http://www.early911sregistry.org/forum/showthread.php?t=17846
I know these are S calipers but Ms have them too. See the M caliper thread: http://www.early911sregistry.org/forum/showthread.php?t=16254
If something is expanding when warm and binding, it may not allow the piston pressure to relax.
Just a thought.
Old 05-27-2008, 11:32 PM
I think I made a mistake. The calipers are on my '67. I thought they were called
M, I was wrong.
Old 05-28-2008, 01:11 AM
Max Sluiter
Flieger's Avatar
L calipers?
http://www.early911sregistry.org/forum/showthread.php?t=20424
Old 05-28-2008, 11:13 AM
on a 67, that eliminates a brake boster problem, so the clogged MC vent is very possible. That's why I suggested cracking open the bleeder next time it's stuck. If the pads release, it's not a caliper problem.
John Snodgrass
Old 05-28-2008, 04:23 PM
Thanks guys,
I am going to check the MC vent line this weekend. I also am going to replace the rear lines as they may be old contrary to my previous belief. The previous owner may have only replaced the fronts.
Old 05-29-2008, 12:52 PM
