Less brakes, more gas!
euro911sc's Avatar
Unhappy '82 ROW SC No-Start after rebuild
'82 SC 9.8:1 CIS; Stock ROW motor
Ok... 1st the starter didn't work so got that rebuilt. Then the fuel pump was shot, so I got a new one of those along with some hose... that works now.
  1. I went to turn it over and I can hear the injectors running while it cranks.
  2. It would not start so I checked spark by removing a plug and grounding it while looking for sparks. Sparks were there.
  3. Smelt plug and it smelt like gas.
  4. I just rebuilt the engine so I'm pretty sure I have good compression. I can check it I suppose, but the motor is hard to turn with the plugs in (9.8:1 motor).
  5. I checked the timing before putting it back in about 3 times...
  6. I have reviewed the plug wires and they are in the correct order
  7. I have 5 gallons of gas in the tank
  8. Brand new Optima battery with a charger on it
  9. All the connectors are plugged in to their respective recepticals.
  10. CDI buzzes and hums.
Ok so I'm out of ideas... Anyone??
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-08-2008, 10:36 AM
Fuel delivery pressure.......
Michael,
Check your fuel delivery pressures. Since you said you have ignition (spark) at correct timing (???), good compression, and fuel with metered air, the motor should start or run. I like hook up a CIS fuel gauge during initial start-up of my motor/s.
Double check the ignition timing. There were several instances were people inadvertently set the timing 180° off. Compression is easy to verify. And confirm the fuel pressure is sufficient so the fuel injectors make uniform spray pattern (mist). Keep us posted.
Tony
Old 09-08-2008, 10:55 AM
T77911S's Avatar
check timing, very easy to get wrong on rebuild, also, mixture may be wrong with new motor
also make sure all fuses good, like to the computer.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-08-2008, 11:40 AM
Initial start-up.......
Michael,
Turn your ignition switch @ RUN or ON and check if you have power at terminals #87a & 86 of the FP relay socket. Make sure that both terminals have power. No power when ignition switch is OFF.
Next, check that #85 (FP socket) is grounded. With the ignition switch off, test again #85 for ground but this time lift up the air sensor plate. With the air sensor plate up, there should be NO GROUND @ 85.
Please let me know what you found from these tests. Thanks.
Tony
Old 09-08-2008, 12:56 PM
Somatic Negative Optimist
Gunter's Avatar
Greetings
Ok... 1st the starter didn't work so got that rebuilt. Then the fuel pump was shot, so I got a new one of those along with some hose... that works now.[LIST=1]
[*]I went to turn it over and I can hear the injectors running while it cranks.
I doubt that you can hear them over the clatter of the engine cranking.
Keep it simple. Pull a few injectors and place them into glass jars. Ignition ON, briefly lift the Airsensor Plate. Even with 2 seconds running, you should see some fuel in the jars. After a change of pump, some air is in the lines and system. Fire Extinguisher nearby
[*]I checked the timing before putting it back in about 3 times...
Make sure that the #1 cylinder is indeed at the compression stroke. Rotor pointing to notch is no guaranty that timing is correct; it may be 180 deg off
[*]I have reviewed the plug wires and they are in the correct order
Direction of rotation of the distributor is ccw. The Bentley mistakenly says cw.
Good luck.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-09-2008, 07:25 AM
mca mca is offline
mca's Avatar
Are you getting anything? Does it sound like it is trying to start? Backfiring?
If so, I bet the dizzy is 180 out. I spent 2 hours trying to start my rebuild a few weeks ago. Turned out that I was 180 off on my dizzy although it looked like it was at TDC. You can pull your left side intake valve cover and make sure #1 is where it should be.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 09-09-2008, 08:30 AM
euro911sc's Avatar
Success!!!!!
It must have been flooded! I looked under and wiped some drips off the headers and they were coming out of an exhaust port and smelt of gas. After that I tested an injector with a glass jar; All was good! So... I figured before I start tearing into it I'd just give it one last collage try.
It started to make that cyclical rrrrrwrwrwrwrwwwrrrrrwrwrwrwrwrrrwrwr like it was trying to start. This was different than before!! So I put my battery charger on it that has an extra 50 amp start switch. It took about 20 seconds but she fired up!! I had to keep my foot on the gas to keep it revved. I was so pleased.
I threw it in reverse and backed/rolled out of the garage just in case. Then I got stuck in the car as I had forgotten to get anything to keep the pedal down and I was helperless!! Lukily, my muffler was so loud my wife and kids came out to see what all the racket was. I was able to get a piece of wood handed to me and get out to check for leaks... none! YES!
She ran for 25 minutes then I pulled her into the garage and drained it. Now I need to set dynamic timing... and drive it!
http://www.rhodesign.com/porsche/imgs/Its_Alive.MOV
YEEEhaw!!!! Its only been a meager 3 years almost to the day...
thanks for all your help guys!
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 09-11-2008, 07:32 PM
TibetanT's Avatar
How do you spell relief?
Drive, drive, drive!!
congrats, Michael.
this has truly been a long time coming...enjoy.
BTW...those door handles you sent are being put to good use.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 09-11-2008, 11:25 PM
euro911sc's Avatar
I'm getting the insurance re-instated today and will stop at the DMV at lunch to get my plates
Oh baby I can not wait. Funny thing is, my AC failed in my commuter car last week so I am already aclimated to driving with no AC in Florida
Glad you made good use of the handles! They were just slowing me down
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 09-12-2008, 06:57 AM
mca mca is offline
mca's Avatar
Michael,
CONGRATS! I am on mile 90 with my rebuild. Finally got everything running right - what a relief!
Wow, acclimated to Florida heat! I don't have my a/c belt on yet and it is brutal here in SC. Not that the a/c does much anyhow.
Enjoy and have fun.
Cheers,
Craig
Old 09-12-2008, 08:31 AM
