LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average.
you see Arthur...
jasonlee's Avatar
nice build. sub'd
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 12-10-2008, 03:01 PM
evill's Avatar
Me Too! Sub'd
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 12-10-2008, 04:53 PM
davisriley's Avatar
Wow, looks fantastic! Can't wait to hear it run! I guess it goes without saying that we will all be waiting for the first videos. Good luck.
1991 C4-edging further away from stock
1972 T-Incoming project
Old 12-10-2008, 05:01 PM
3 restos WIP = psycho
kenikh's Avatar
Slight spec change - I must be going crazy, but I have decided to go ALL THE WAY. Some would say I already had, but...I just got my hands on an out of spec 66mm crank, now to be reground to 3 liter crank journals, fitted with custom R&R rods from LN Engineering.
Oh yeah, I am going to use titanium wrist pins, too. That's what happens when you talk to Burn Bros too much. The rotational mass of this setup will be downright juicy. Albeit not to titanium rod spec, but certainly good enough and without the life limit worries that can come with Ti rods.
Originally Posted by kenikh View Post
2.3L ST replica motor:
Fully detailed small spigot 7R case (shuffle pins, squirters, light mooning, every oiling mod known to man, etc) - at Ollie's now
85mm JE pistons @ 9.5:1 CR - have them now
'69S heads; ported by Dick Evelrude - have them now
Twin plugs (still debating which system to use)
DC44 cams (custom grind; .490 lift at both lobes; 102 deg lobe centers) - have them now
Titanium valve retainers - have them now
RARE 47mm 4-bearing cam carriers - have them now
Nickie cylinders - have them now
R&R 3 liter journal rods for 66mm crank
Titanium wrist pins
Cross drilled crank, 66mm crank undergrind to SC bearings
Fresh 930 oil pump, with full race chamfer on the internals by Supertec - have it now
rebuilt 2.4S MFI pump - have it now
52mm>38mm (taper bored) magnesium MFI stacks and match bored and rebuilt TBs - have it now
Lightened '69S flywheel - with Jeff Hines
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-13-2009, 05:03 PM
AutoBahned
RWebb's Avatar
so, how many grams do the titanium wrist pins save?
Old 01-13-2009, 05:10 PM
Sports Purpose 911 Driver
mjshira's Avatar
I am in. Nice work and brave man! I need to show my wife this thread so she knows that I am not the only 'crazy man' out there :-D
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
ShakinJoe's Avatar
subd
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 01-13-2009, 05:17 PM
kenikh's Avatar
Between 120g and 150g lighter per pin. Throw that into your calculator for rotational mass at 8000 RPM and you have some serious difference! I don't have the number handy, tho.
Don't show my wife this thread!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-13-2009, 05:20 PM
I would rather be driving
jpnovak's Avatar
Sounds like a great build. Can't wait to see the crank.
Does this mean you are going custom rod journal size (2"?) and rods to increase the stroke? This is like the "supercrank" from henry?
HMM my wrist pins were 112g each. That must means I would be floating on air.
Old 01-13-2009, 05:30 PM
kenikh's Avatar
I clearly have my numbers wrong.
These aren't 2" bearings - they are a bit smallish for a non moly crank. I am using the 3 liter journals which are still much smaller than the 66mm crank, but good to go on a steel crank. Henry's moly supercrank is of a material that you could actually use the 1.8" Honda bearings and be fine. Strong stuff.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-13-2009, 05:36 PM
Max Sluiter
Flieger's Avatar
Wow, how do the Titanium wrist pins avoid the fatigue failure of Titanium rods?
Old 01-13-2009, 10:41 PM
Kenik,
Awesome build, I can't wait to hear it. It should be a screamer.
86 Carrera
70 914-6
Old 01-13-2009, 11:39 PM
Carrerax's Avatar
Sub'd.....
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 01-14-2009, 05:23 AM
(the shotguns)
berettafan's Avatar
7800rpm...wow!!!!
Old 01-14-2009, 05:33 AM
UnRegistered User
billybek's Avatar
Sounds like fun....
Subscribed..
Bill K.
Old 01-14-2009, 05:44 AM
AutoBahned
RWebb's Avatar
Thanks much. I put a rev limit on my calculator since it runs out of cam before 8k....
BUT! I like many others can live vicariously thru your threads -- and it is well within my budget to watch.
Old 01-14-2009, 02:14 PM
kenikh's Avatar
Mmmmmmmmmmmmmmmmmmm...look what arrived today! Custom George Narbel headers, with longer custom length primaries with ceramic coating. Just what a high strung, small bore motor needs to make mad torque! These are a Rennsport Systems design.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-15-2009, 10:10 AM
ShakinJoe's Avatar
where did you get these headers? How much are they is you don't mind saying?
Old 01-15-2009, 10:19 AM
Porsche Doc's Avatar
Thumbs up
Hey Man!
Looking GOOD
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
Old 01-15-2009, 10:28 AM
kenikh's Avatar
Just short of $1400.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-15-2009, 10:29 AM
