Throw it on the ground!
Source for a back up light conntector on a G50 tranny
One of the two back up light pin connectors broke off on removal. Not sure if I'm going to salvage it or ruin it in the process. Anyone got a source for these rather unusual connectors?
UPDATE: found p/n 911-612-907-00 may be a special order item from Germany
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 11-29-2008, 11:06 AM
drill it out and resolder or get one at the dealer. part # 911 612 907 00
206 637 4071
Old 11-29-2008, 12:32 PM
Metal Guru
911nut's Avatar
+1 on the drill out/resolder.
I've had to do both connectors going to the switch on my car.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 11-29-2008, 12:37 PM
Southern Class & Sass
Dixie's Avatar
I drilled mine out and soldered it back on.
A friend told me he simply used the male half of a crimp-on connector available at any parts store...
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 11-30-2008, 07:23 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
The problem is they are a little skinney so you'll either have to bend them a bit OR I've used a small bolt the same diameter as the "bullet" with nut on it and attach to a circle connector.
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-30-2008, 07:42 AM
That is what she said. Sorry Todd, couldn't resist
I would desolder and reuse
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-30-2008, 01:34 PM
The right tool for the job is a $5 desoldering pump, sometimes called a "solder sucker". Rat Shack carry them, along with 1000's of others.
Cock it, heat the connector with the soldering iron until the solder is molten, stick the teflon tip in the end of the bullet and press the button.
Job done, just resolder the connector.
This is also the way to get rid of/remake those nasty cold/dry joints the factory supplied in the 80's on just about every circuit board in the car (the dull-looking ones with all the flux not boiled off). I'm amazed any of those ever worked/still work/passed QA.
'77 S with '78 930 power and a few other things.
Old 11-30-2008, 01:59 PM
9dreizig's Avatar
After she called you little and skinny, you'd desolder and re-use her??? You're more forgiving than me dude!!
BTW,, things only got better after I left you guys yesterday if you know what I mean hehehehe
"Todd"
Old 11-30-2008, 04:17 PM
