LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
356RS's Avatar
Posted twice.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-04-2009, 07:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
Originally Posted by 356RS View Post
Thanks to all of you. Scott; The AC Tech unit is the motor control system. The control unit is programmable. I have set the min. RPM for 400 and the max. RPM at 4000 controlled by a potentiometer, set the ramp-up speed to max and the ramp-down to max. the ramp-up is very important because at tests at 2000 RPM and up I need the motor to get there from a dead stop to (example 3000 RPM) in less that 1 sec. At 4000 RPM it takes about 1 sec. At these high RPMs I have to do a little loss calculations at the start-ups.
John; I will post some pictures of the pump that had the intermittent stuck piston.
John Bell; Let me know what you need. I'll be glad to help.
Next Pump will be a RS space cam installation in a 015. I will first flow test the stock 015 and document the flows, then R & R the space cam and recalibrate for RS specs.
Hello Mark
Are you sure you will be able to set to Rs specs with a 015 regulator ?
Your pumping pistons don't look good, on that pic ... ? what are you feeling when moving them ?
Old 05-05-2009, 05:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
356RS's Avatar
Philippe, The photo of the pistons with corrosion on them in post #104 are from a 2.2E pump Im working on. After I finish this 2.2E pump I will be starting on a different pump project, installing an RS space cam in a 015 pump. I have the 2.7S or RS flow test paper and I see no reason why I can't recalibrate it to the RS specs. But I could be wrong. This is the whole idea of having the MFI Pump Dyno. Philippe, You have lots of experience with the MFI pump and I thank you for all the information you contribute.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-05-2009, 06:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
On top of everything else, this guy's a great photographer???
Is this for freakin'g real?
Amazing stuff - keep it up!
1972 911T/S MFI Survivor
Old 05-05-2009, 07:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Autodidactic user
David E. Clark's Avatar
Mark,
On the off chance that you haven't seen these yet, here and here are two sites with pictures of the equipment at Pacific Fuel Injection. Enjoy!
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 05-05-2009, 03:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
356RS's Avatar
David, Yes I have and thank you. I used the test tube rack that Guss has for my set up. Notice the wine glass style funnel on top so you can view the injectors if necessary. My dream would be to have the computer based flow test and data. Next year maybe?
Mark Jung
Bend, OR
MFI Werks.com
Old 05-05-2009, 04:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Industrial Grade Tool
WoodSport's Avatar
Hey, Mark - just wondering if my emails got through. Once we locate some suitable meters, I could have the software done in a couple of weeks or less. I'm currently 'in-between jobs' so this would be a good time for me if you're still interested.
/Jon
/Jon
Old 05-06-2009, 04:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
356RS's Avatar
Yes very interested. I'll e-mail you the specs. today.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-06-2009, 06:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Anyone care to speculate on the number of MFI systems produced by Porsche?
On another note, did they ever MFI a 4 cylinder - 356? 4 Cam? 912? 914?
Old 05-06-2009, 07:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
3 restos WIP = psycho
kenikh's Avatar
Nope.
That said, it is possible, given that MFI was available in Alfa and BMW 4 cylinders. Alfa used Spica and BMW used Kugelfischer (and possily Bosch). I think MB only used MFI on 6 cylinder and up cars.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-06-2009, 07:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
I know you spent a lot of time and elbow grease cleaning the unit; I have picked up a couple of Ultrasonic units off evil bay cheap, which would help reduce your labor on future units.
Old 05-06-2009, 10:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
Autodidactic user
I found these pictures in an old repair book. It's interesting to see how close Mark has come to the factory setup - or maybe that's Mark in the pictures.
© Harold T. Glenn, Glen's Diesel and Gasoline Fuel-Injection Manual, pages 6-7 (1973). Posted here for educational purposes only.
Old 05-06-2009, 11:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
356RS's Avatar
Great pictures David, Thanks. Amazing how the Germans used a monster lathe and converted it for MFI pump testing. Or did Bosch actually build that specifically for the MFI pumps? Must have 20 hp. How could they tell if the MFI pump camshaft all of a sudden seized up the bearings? That big motor would just grind it all up before you could pull the plug. 72 pump that guys working on. Looks like they run the pump without the side cover on the regulator?
Mark Jung
Bend, OR
MFI Werks.com
Old 05-06-2009, 12:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Thanks for the kind words Mark ...
But i'm not really experienced comparing to some of us on this board ...
Yes i've done a lot of pump calibrating with success on stock engines ...
The new way i try from some monthes is non factory engine tuning ... I ve understood that the springs are not all the same on MFi units, that's why it's not often easy ... i've one pump at home that has self made centrifugal weights, and that i set to "RSR" flows ... we'll see what happen ... I think you won't have to consider electronic or so data collecting ... the way you measure is pretty accurate and you'll see you will be able to repeat the process with reliability. By the way, the guy that will throw the pump on the engine will have to do fine tuning (often). I believe here 's the hard job ...
I will soon try to do a 3.2LMFI engine and tell you about !... for what i see the guy for that job Here is Henry Schmidt !
Old 05-06-2009, 12:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
you can operate without the side covers of the pumping elements too !
Old 05-06-2009, 12:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
That Bosch must make pretty good stuff
From our late model tractor:
The similarities are many!
Old 05-06-2009, 12:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
304065's Avatar
What is REALLY interesting about the modern Bosch stuff is that they have electronic diesel control. If you read the Bosch Automotive Handbook (I have the 7th edition) they say that there is a no-contact sensor for the rack position and that is coupled with a servo that moves the rack, so you have feedback. Those elements are contained in an end housing that looks like it replaces the mechanical and centrifugal governor of the pump.
It makes sense, the only part that controls the fuel is the rack. The rack is moved by the governor. If you went to direct control of the rack . . .
By the way there is an awful lot of information about the very similar diesel pumps out there. . . here is one example . . . http://www.competitiondiesel.com/forums/showthread.php?t=14085
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-07-2009, 01:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
356RS's Avatar
Very interesting John. Do you have one I can play with?
Mark Jung
Bend, OR
MFI Werks.com
Old 05-07-2009, 04:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
304065's Avatar
Mark, it's hard for me to keep anything interesting around without taking it apart and rendering it useless. (Animate objects excepted)
That said, Bosch innovated EDC (electronic diesel control) in the early 1980s, so there are probably tens of thousands of the pumps around. It's funny, our gasoline pumps are a very small branch on the huge tree of Bosch diesel stuff. MFI development for diesels continued LONG after the advent of CIS so there is interesting stuff out there.
'81 R65
Old 05-07-2009, 04:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
356RS's Avatar
I received the Magnesium Treatment Kit today. I had the MFI pump body cleaned and ready for the treatment procedure. Last week I spent several hours cleaning all the corrosion out of the fuel head area. So today I completed the magnesium treatment and also added a black dye process at the end. Pictures below:
Bench set up for the dipping and rinsing process:
Black Dye dip had to at 140 degrees:
First dip was the Magnesium Corrosion Treatment dip:
Then the Black Dye Dip:
Then the water rinsing and air blow dry and this is what it looks like:
Before Treatment last week it looked like this:
Now this is what the finished product looks like:
Mark Jung
Bend, OR
MFI Werks.com
Old 05-08-2009, 04:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
Tags
calibration , mfi
