Main Fues Block Replacement Time.
OK - It is time to take the plunge and replace the main fuseblock on my old 79 930. Can anyone suggest a practical block? There are a ton of them on the internet but I thought I would ask youse guys what have done it.
Vinnie - the Bronx ![]()
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
yep, im slow in the head
iv got my eye on one of these.....
![]() Our 8 position fuse block contains 8 individual fused curcuits with connections that enter and exit from the bottom. Excellent fuse block to mount to a bulkhead or panel with the fuses sticking out the front and the wires hidden behind. Connections are using 1/4" female push-on connectors. Reinforced mounting holes located 4.055" center to center. Mounting hole diameter is 7/32". Includes a clear gasketed cover. clicky |
My take goes something like this:
Happiest when Tinkering
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Hey Harry my car is such a mutt now that most Pros wont touch the whole car, and I am finding that the "Pros" are highly overpaid and way highly overrated in some cases not all.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me Last edited by gsmith660; 03-09-2009 at 04:00 AM.. |
Thanks to all for the input.
EPS
Hi Buddy: No worries on my part. I hear you 5 x 5. As far as I am concerned, everyone has do what they think is right. Your money, your car, your choice. I just wanted folks to be aware of a potential downside to changing the factory setup. For many here, the change in no biggie but for others it may be a short term solution that leads to a long term problem.
Throw it on the ground!
Search under Pelican Fred Cook who has done good work on this topic.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Thread Tools | |
Rate This Thread | |
