On a great circle route
xlr8's Avatar
Boring Fuchs, An experiment in reduced unsprung weight and rotating mass.
Since the Fuchs factory put holes in the petals of the 914 wheels-
I thought "Why not bore some holes in those five spoke Fuchs too?"
Less unsprung weight, less rotating mass, better brake cooling-
Further weight reduction is achieved by inflating the tires with hydrogen.
With this performance upgrade I can reach 175 MPH with the top down. ( On the Bonnieville Salt Flats of course, don't try this at home!!!)
Any possible issues with strength reduction have been addressed by backyard shot-peening. (12 guage magnum loads) Be sure to remove the tires before this step. YMMV.
Let me know what you think, and have a nice DAY!
Russ
Old 04-01-2009, 07:32 AM
I assume you included symmetric speed holes in the bonnet, right?
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-01-2009, 07:44 AM
Nine9six's Avatar
Hmm,
Why not three lightening holes in each pedal with a smaller hole closer to the center of the wheel, and getting progressively larger towards the diameter.
Were you serious about 175 mph? If so, I think not.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-01-2009, 08:12 AM
Cross drilling the rotors with 3/4 inch diameter holes will help even more. If you go all out you can go to one inch holes and get to 180 MPH!
Old 04-01-2009, 08:27 AM
IROC's Avatar
It's definitely April 1st...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-01-2009, 08:30 AM
joecrum's Avatar
Rotate the tires parallel to the ground, replace petals with large fan blades and you can make a hovercraft!!! 0 unsprung weight!!!!
joe
>82 3.0 SC
>01 Audi S4 Avant
Old 04-01-2009, 09:38 AM
Diss Member
Quicksilver's Avatar
That is a two wheel drive car.
It would just end up flipping over the front bumper onto its roof...
(BTW- That would massively increase the unsprung weight. When it is on the roof the whole car is unsprung except the wheels would be sprung weight...)
On the later all wheel drive cars it would work better.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 04-01-2009, 10:03 AM
joecrum's Avatar
Plus, no rotating mass!!!
joe
>82 3.0 SC
>01 Audi S4 Avant
Old 04-01-2009, 10:36 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I assume you had the wheels re-balanced on a homebuilt jig too?
Old 04-01-2009, 11:00 AM
abit off center
cgarr's Avatar
If the front edges are beveled it will scoop air in for the brakes.
______________________
Craig
G2Performance
Old 04-01-2009, 11:04 AM
The windshield is a large contributor to drag. Remove it. And since it's a Targa, the windshield frame as well. Put the rear view mirror elsewhere. Don't forget the aero-bicycle helmet.
Sherwood
Old 04-01-2009, 12:53 PM
a haircut & shave will do a lot at diminishing drag as well.
You could easily jump the 200 mph barrier!!
Old 04-01-2009, 02:43 PM
Although it's April 1st, the reality of drilling holes in the wheels will not cause better brake cooling. At Speed, the holes don't let in any air as they are rotating too fast and act just as a solid piece of metal. Unless you add an air foil to scoop up air and viola, you have that hovercraft as indicated above via joecrum's post.
___________________________________________
2001 Boxster S, Orient Red Current Vehicle,
1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**,
1971 911T **Sold**, 1968 912 **Sold**
Old 04-01-2009, 02:53 PM
AutoBahned
RWebb's Avatar
you need to talk to the Porsche R&D people about the 993 wheels
Old 04-01-2009, 04:12 PM
