dazed and confused
john baldwin's Avatar
Is there a shorter spark plug tool?
After reading all the posts on sparkplug removal methods, I ordered the wrench from the toolkit (no toolkit with the car) from a reputable salvage yard. However, despite many attempts, it's just too long for me to maneuver. I resorted to articulated sockets, locking extensions, and hoses (Pelican posts are extremely helpful!). Took a while, but once I got the "feel", what started as a chore became fun.
However, now I've got this wonderful tool that I can't use....see pictures...were they all this long? It's missing the knurled tip that others spoke of in previous posts....could it be aftermarket (says "Klein", which I thought was factory...) Or is it just me....curious. Watch for it in the for sale forum....
89 Carrera 3.2 Targa
2011 BMW 335d
2013 BMW X3 3.5
80 911 SC Weissach Coupe (Sold)
Old 04-22-2009, 05:09 AM
Almost Banned Once
sc_rufctr's Avatar
There is a shorter version of that tool. It's less than half the length of yours but otherwise very similar.
- Peter
Old 04-22-2009, 05:35 AM
That tool looks like the one for a 912 maybe? Definitely way too long for a 911. Contact the salvage yard and see if they'll exchange it for the correct tool.
Mike
'68 911 # 11830241
Old 04-22-2009, 05:43 AM
Bill Verburg's Avatar
This one from the tool kit that came w/ my '72 was the best I ever used
Bill Verburg
Old 04-22-2009, 05:53 AM
Friend of Warren
That sure isn't a 911 tool, more like a 944?
Kurt V
Old 04-22-2009, 05:55 AM
Tom '74 911's Avatar
Mine looks just like Bill V's. It is a great tool to have. Even at it's shorter length, there was a plug or two that took some maneuvering to extract while attached to the tool - there's no way you could get to any of the plugs with the tool in you photo!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 04-22-2009, 06:28 AM
This is the tool that came with the later 911's, I know at least 77 and newer. The shaft flex's to make it easy to remove/install in the tight area's of the 911.
The "fixed" shaft tool of Bill V's came with the early cars.
I have no idea where the tool you got came from, but it was not a 911. Possibly, as stated above, a 356 or 912...
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 04-22-2009, 06:46 AM
Designer King
Paulporsche's Avatar
Looks like a 944 tool.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-22-2009, 07:16 AM
Fast Corners's Avatar
John,
Yours is definitely one from a 944. The "flexible" 911 tool (as shown in timc's) post works well for the later cars (84-) & turbos but the earlier "fixed" is the best one I have ever used on the earlier cars. The fixed one really gives you a lot of feel which really helps when it comes to avoiding cross threading the plugs.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 04-22-2009, 07:17 AM
dazed and confused
Thank you all for your help!...now back to the salvage yard..wish me luck!
2011 BMW 335d
2013 BMW X3 3.5
Old 04-22-2009, 07:23 AM
Autodidactic user
David E. Clark's Avatar
This one is definitely the best. I only wish that they had designed it to attach directly to a 3/8 ratchet instead of using a 10mm hex.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 04-22-2009, 08:52 AM
Depends on the car...
Tim
1986 930
Old 04-22-2009, 09:06 AM
not that hard to weld a 3/8 end on one. 5 5/8" is the magic length. been using this one for many years.
206 637 4071
Old 04-22-2009, 09:08 AM
I agree. However, mine needs a new rubber sleeve that holds the spark plug in place. I didn't see it in the Pelican parts store. I assume the dealer can still get this? Any rubber sleeve replacement options outside of this?
Sherwood
Old 04-22-2009, 10:45 AM
Hazet
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-22-2009, 01:54 PM
dazed and confused
Recognition of two suppliers...
Contacted the salvage yard that originally supplied me the wrong tool (top of photo). Sent pictures from the responses I received on Pelican...this forum is TERRIFIC. After much searching, they located the correct sized tool (bottom of photo). No charge replacement; this after a year of my first receiving tool. dc Automotive...very responsive and honorable! Thank you to all.
2011 BMW 335d
2013 BMW X3 3.5
Old 05-31-2009, 04:47 AM
