3.2 Trans cooler questions....
Hi
Discovered my recent purchase included a transmission cooler (euro 3.2).
Do these really make a big difference? Also, why did they only fit them to the Euro models?
Just curious....
Cheer
R
Old 06-05-2009, 05:13 AM
Bill Verburg's Avatar
Originally Posted by Rols 912 View Post
Hi
Yes
... Also, why did they only fit them to the Euro models?
Just curious....
Cheer
R
Porsche has a history of downgrading the performance capabilities of it's products that are shipped to NA. I'm also sure that the importers here had/have a say it what is offered on this side of the pond.
Bill Verburg
Old 06-05-2009, 06:06 AM
the 231 hp of a 3.2 euro was about all a 915 could take, hence the cooler.
carrera coupe 85
Old 06-05-2009, 08:55 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Lucky you that you got a factory cooler. If you use the car at track day events, it'll really provide a benefit for you. The heat of high rpm usage, and heat from a LSD if you have one, will be reduced by having a radiant cooler like that.
Kevin L
'86 Carrera "Larry"
Old 06-05-2009, 09:31 AM
Porsche 911 SC, SAAB SPG
Can you take some pictures of where the lines route and the cooler itself?
Is there a pump as well?
Very cool stuff.
Jeff C
Old 06-05-2009, 09:39 AM
Very cool stuff.
The pump is internal, there were 2 versions
early mounted in the tail housing used from circa '73
Bill Verburg
Old 06-05-2009, 09:47 AM
and late mounted in the side, used for some but not all '84 - 86 RoW 3.2
Bill Verburg
Old 06-05-2009, 09:53 AM
Hey Bill, great pics!!
You're showing the internal spray bars in those photos above - my understanding was that the 84-86 cars didn't necessarily come with the spray bars (additional option), even if they had the pump and cooler?
I certainly had to have my spray bars retro-fitted..
'77 S with '78 930 power and a few other things.
Old 06-05-2009, 10:06 AM
That's correct, the early version was far more expensive and was an option on RS, std on RSR. It was intended for race use where temp control was only 1 of the design criteria.
the '84 -86 versions were targeted for street use(ok Autobahn) temp control only.
Bill Verburg
Old 06-05-2009, 10:55 AM
Administrator
Jack Olsen's Avatar
Europe has (well, had) many highways with a tradition of sustained (and legal) high speeds. The USA does not. I suspect that this (as opposed to horsepower) was a bigger factor in the decision to include the cooler for some markets and not others.
In my opinion, a cooler is really essential if you want your transaxle to survive much track use -- but is less important for U.S. street driving.
Old 06-05-2009, 06:40 PM
