cdrik915's Avatar
AFM spring calibration : i need help please guy's
Hi !!!
I've got a problem to remember how was the spring calibrated in the AFM .
Can someone explaining me the way to do it with factory values ???
Number of teeth ?
I just talk about the spring , and not found something about it.
Thanks for all input ,
Cheers,
Ced'
LIGHTER = FASTER !!!
Old 10-22-2009, 07:51 AM
T77911S's Avatar
i assume you are talking about an 84 or newer, not a CIS car?
you should post the year and any other info that will help.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-22-2009, 10:15 AM
Friend of Warren
84-89 all used the same AFM. I even thing the 964's has the same AFM.
Kurt V
Old 10-22-2009, 10:55 AM
Steve W's Avatar
I think you're going to have difficulty setting the spring calibration. The only way I can think of doing this is by a flow bench comparing the output voltage to a calibrated unit.
Old 10-22-2009, 11:28 AM
cdrik915's Avatar
The car is a stock 86' 3.2 model .
I've got the AFM way of calibrating , but that don't talks about the stock calibration of the spring.
Only how to leaning up or leaning down the mixture .
If somebody knows...........Thanks again !!!!
Good day to all !!!
Old 10-22-2009, 09:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Ced,
Post a picture to show what your AFM looks like, maybe we can see the issue and help that way.
I have an AFM that you maybe able to referrence to as well.
'85 Carrera Targa
PCA/POC
Old 10-23-2009, 07:33 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
mine was messed with by the previous owner and i spent alot of time trying to sort it out, and i finally bought a another one off of here and problem solved. there are a few different markings on the spring and holder and housing, but i wasnt able to find out what they menat so you're shooting in the dark.
Old 10-23-2009, 09:10 PM
cdrik915's Avatar
Originally Posted by DRACO A5OG View Post
Ced,
Ok , thanks for the advice , i'm going to do a pics of the AFM.
Old 10-24-2009, 01:08 AM
cdrik915's Avatar
Here a pic of the AFM.
Thanks.
Old 10-24-2009, 04:13 AM
