Header choice for HP 3.0
I am finished with my 3.0 SC rebuild and am now looking for an exhaust system. I think I would like headers as heat is not necessary here in Houston. My build is as follows:
Stock case w/ stock crank
Re-sized SC rods with Raceware bolts
95mm Mahle cylinders w/Supertec studs
95mm JE pistons @ 10.5 : 1
Stock '78 SC heads w/ new guides, race springs, titanium retainers, twin plug
GE 60 Cams w/ re-bushed & re-ground rockers
Pressure fed tensioners w/ Supertec idlers
46mm Webers on PMO manifolds w/ PMO insulators
BURN-BROS twin plug dizzy w/ MSD 6 AL & 2 MSD blaster coils with 15 volt inverter
Stock 915
2100 pound Targa w/ chassis mods
I would like it to sound good but not too-too loud.
Mix of street and DE with limited track use. Mostly a weekend hot rod.
Any suggestions?
Lindy
Old 03-05-2010, 12:42 PM
These guys have a real nice setup....
Buckley Racing - 911 Car Prep
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 03-05-2010, 12:48 PM
Bill Verburg's Avatar
I'd second that suggestion
Bill Verburg
Old 03-05-2010, 01:04 PM
For your motor I'd recommend European Racing Headers or the headers from S-Car-GO. The Buckley headers are top notch but not the right ones for your motor. You need shorter primary tubes like on the headers I mention.
-Andy
Old 03-06-2010, 07:11 PM
Send a message via AIM to fintstone
Sounds like a great engine! IMHO, SSIs are great...you get great headers and heat.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-06-2010, 07:13 PM
Thanks for the help. I had SSI and sold them looking for a bigger primary. I'm going to go see Jim Buckley this week and see what he has to say. I had never heard of his headers before asking this question of what to use here. His stuff is very trick. I will be checking into the shorter primary theory and what European and S-CAR-GO have to offer. I'll keep you all posted as things move forward.
Lindy
Old 03-08-2010, 06:48 AM
Maltese Falcon's Avatar
MSDSinc. has these equal length and mitred collector headers (1.625" primaries) on sale this month at 30% discount. With a set of extensions you can go directly into any dual inlet muffler available. These are raw-steel, but there are several coating options from MSDS.
They are at MSDS Inc. -* HIGH QUALITY HIGH PERFORMANCE ACCESSORIES
Porsche builds the 21st century 9146
so easy...even a Cayman can do it !
Old 03-08-2010, 05:17 PM
Crotchety Old Bastard
RarlyL8's Avatar
I have these in 1.5" or 1.625", 321 stainless, equal length.
Old 03-08-2010, 06:52 PM
