Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Replace clock with voltmeter
Hey guys,
I am looking to replace my clock with an analog voltmeter and was wondering if any of you have and input on what unit might be best?
I believe that is a 3" guage, but I can only locate smaller diameter units on amazon.
I note that pelican sells a unit, but its $44!!!
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 05-04-2010, 06:36 PM
Senior Advisor
James Brown's Avatar
Try Palo Alto speedometer or North Hollywood Speedometer for a nice looking one. Or replace the oil quantity gauge with a volt meter. Keep the clock.
08 Cayenne Turbo
Old 05-04-2010, 06:50 PM
gulf908's Avatar
Justin,
This is what I did with mine.
I prefer to keep an eye on the charging rate in the batteries rather than watching the time !
Quite some time ago I bought a clock blank from the local Porsche dealer when they weren't too pricey.
I subsequently went to the local VDO store and picked a voltmeter I liked that was closest to the other instruments in appearance.
This is the result.
Going the OEM clock blank way may be a bit more $pendy these days but it looks a bit more authentic to me.
BTW,the voltmeter has saved my batteries from frying twice due to an overenthusiastic regulator.
HTH,
Dennis.
The 914-6 from my 'Lotto'garage has finally arrived.
1971 911S 2.2.
1975 Carrera Targa (ROW) - missed.
One of us is fast becoming a valuable antique.
Old 05-05-2010, 03:09 AM
woland's Avatar
Justin
Considering that the 911's oil level gauge is quite inuseful, I'm looking to turn it in an analogic voltmeter using a variable resistence connected with a positive wire.
In this way I'll keep the splendid Porsche clock with his white arrow that tells me the trip duration.
I let you know the results when done
Paolo from Alps
1980 911 Targa SC 3.0 - Silver metallic
1980 Ducati Pantah 500 - Red
1989 Yamaha 500 "Tracker"
Old 05-05-2010, 04:06 AM
MBruns for President
JeremyD's Avatar
I had North Hollywood convert my tach and install a voltmeter
Old 05-05-2010, 06:09 AM
winter
Winter's Avatar
These are some nice looking solutions. I'm not there yet with my ongoing improvements to the much neglected '75, but will be at some point. I'll keep what you guys have done in mind. Good work and thanks for sharing
Tom '75 targa
Old 05-05-2010, 06:29 AM
Wandered off somewhere...
Drdogface's Avatar
Originally Posted by woland View Post
Justin
I did just that and it's worked out well....but pricey. I think I uses No. Hollywood. I like having the clock there for the original look if nothing else.
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 05-05-2010, 07:09 AM
lin7310948's Avatar
voltmeter
several solutions but i prefer the factory gauge look. i do not use the clock as i use it for a fuel pressure and and oil temperature gauge combination gauge...gauges converted by n. hollywood speedometer.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 05-05-2010, 07:35 AM
poorsche930's Avatar
Thats bad ass! I have a 930 with the boost gauge at the bottom so it would get cluttered for me. Maybe they can convert my oil level into a volt meter?
Ryan
79 930..... among other fine German cars.
Old 05-05-2010, 12:14 PM
JeremyD's Avatar
I'm having them do that now with the gauges from my 1974 911.
Old 05-05-2010, 12:27 PM
Take a look at Bigmarkdesign, he has a really great stock appearing voltmeter that he installs in the lower part of the tack, at a very reasonable cost. Did mine and I am very happy with it. Try a search here may turn up the info you need. Lynn
lynn, 68 912 coupe, 2011 Cayman base
Old 05-05-2010, 02:23 PM
kodioneill's Avatar
I like! What did that cost?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-05-2010, 02:49 PM
JeremyD's Avatar
Call North Hollywood - they are very reasonable. I didn't just get that done = so not sure what the cost to just do that is.
Old 05-05-2010, 06:55 PM
Voltmeter instead of Clock 1987 Porsche 911
I went through two clocks which are not cheap. i read the article regarding swapping out the clock for a voltmeter and thought about doing this. i should have done it sooner, because my alternator went out last week 76 miles away from home so i needed a tow.
i used the outer metal ring and the rubber gasket/grommet that hold the clock in the dash from my again non-working clock for this project. i purchased the same VDO Voltmeter as shown on this forum. i bought a set of hole saws, plywood, black spray paint, and a black vinyl/plastic.
i purchased a non working clock on ebay for $25, in case i sell the 911 in the future to make it original again. if i had to do the job over again i would have made it a little differently, because it would have saved me a lot of time. it turned out excellent.
Old 12-05-2011, 05:21 AM
RETIRED
Joe Bob's Avatar
Wesstach, aircraft gauge manufacturer....
2012 ML350 3.0 Turbo Diesel
Old 12-05-2011, 06:15 AM
a_bayuga's Avatar
NH VDO Clock
Got mine from north hollywood. I do not recall the price though.
Old 12-05-2011, 02:10 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep. I agree Mark does very nice work. His website is New Vintage USA
New Vintage USA-Our Original Porsche Work
He is "marks914" here on Pelican
Kevin L
'86 Carrera "Larry"
Old 12-05-2011, 03:00 PM
dshepp806's Avatar
Thanks for the info here,...
I'm up for exorcising my clock on my '89. It has worked flawlessly during it's six years with me...(I surely would stow it away),..and make use of a voltmeter in it's place. Maybe a combinational gauge,..we'll see.....had been using R/L detector to monitor voltage (saved my arse' on an alt/reg going bad)....am coverting R/L detector to wireless or hidden cables to rid myself of (exposed) cables.......will be cool to NOT have to occasionally check the cig lighter output DC level vs. the actual battery (compensating for the differential-while "monitoring"------,..albeit small, but still existent).. A voltmeter with the rest of the instrumentation will be nice.... (usefully: i.e., REQUIRED).
It's amazing that they would omit such crucial voltage monitoring,........I can assure you that nothing lit up my (stock) dash when that reg output +16.0 volts for a brief moment,..caught (and alarmed) when it happened by the R/L detector.....then it happened once more on a different day....BAM,..fresh alt/Reg......DONE. Found the original 1989 alternator in my 1989, BTW!!!!! Guess it was done after all of those years of service (ahem).
Will check this guy out,...thanks, again.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-05-2011, 04:02 PM
I am wondering if I added a volt meter if I might not notice a spike for a while. Has anyone added a warning light somewhere instead? Would be interesting if someone made a replacement cigar lighter that was a voltage warning lights with a buzzer perhaps.
Old 11-05-2021, 08:42 AM
lots of volt meter options for the lighter socket. See, e.g. https://www.amazon.com/Cigarette-Lighter-Voltage-Digital-Voltmeter/dp/B00UCEAKYU
Old 11-05-2021, 08:59 AM
