Grady Clay, thank you very much for your useful information.
I posted something to you but suddenly my answers required approval from moderator and they are still waiting... don't know what happened.. |
gearhead
http://www.jzmachtech.com/images/news/0000330_P_World_Sept_09.pdf
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks Matt!
Unfortunately, the web sites rs-teknik.com and rs-911.co.uk, disappeared...
Bad luck!! If anyone knows any other supplier in Europe at good prices, please inform. Thank you Last edited by AlexJ; 07-02-2010 at 07:21 AM.. |
And these chaps I've used them very good mouldings(cr*p web site). http://www.porscha.co.uk/ And if you need any help finding supplier(good ones!) in the UK just let me know chris |
Thanks for your help! I'll contact you.
Alex,
Now that some time has passed, please re-define your goal. Writing it down for review may help. I agree that there is ‘real value’ in starting with an already-imported 911. What are the rules & taxes about importing ‘used, junk’ parts? Is there a ‘consolidator’ importer on Madeira who brings containers from the US on a regular basis? If so, perhaps we can organize palettes of necessary ‘used’ parts and consolidate with goodies from Pelican and other. The rear suspension and torsion bar tube from a salvage ’84-’89 would be a good ‘junk’ repair part. Torque tube modification for rally use You can convert to the ’69-’89 front suspension. This works better than the original SWB and there are more choices for components. It appears the engine has some ‘rust distress’. You may find it more satisfactory and less cost to start with another engine. A 3.0/3.2 are available and can be purchased in running condition. I would prefer a 2.4/2.7 converted for 2.7/2.8 high compression, twin plugs and using your Weber carburetors. The rules you choose may determine the choice. The ‘good news’ is you can always change engines easily. Staying smaller than three liters allows you to use the 901/911 transmission. Ideally, start with a good 1971 type 911 magnesium transmission. You can add the large ZF LSD and gear it for your use. There are good fuel cell inserts made for inside standard fuel tanks – but they are expensive. A standard fuel cell in the stock location will work fine. There are good discussions on Pelican about cage design. First, decide on what rules. Current SCCA has the widest acceptance. If you want to ‘improve’ on their requirements, you can submit detailed plans for prior acceptance. Go talk to your ‘killer sand blaster’ technical person. See if they can use other media. Discuss lower air pressure and other to avoid damage. Technique is also critical as heat from too aggressive process can warp panels. You will want to remove as much undercoat and debris as possible by ‘manual’ techniques. There are some good Pelican threads on this subject. ‘Seam welding’ a rusty old chassis is difficult. You will need to split the seams first in order to have clean (no rust) metal to weld. This gives you the opportunity to build the chassis with 40+ years hindsight. In replacing damaged panels, consider using the rear seat tin from ’72 and later. This allows easy installation of a 915 transmission someday. You will want to increase the chassis clearance above the outboard CV joint. You might make provision for it to either be SWB or LWB. I would retain the ability to have heaters, i.e. reinstall heater tubes in the side frames. Don’t be tempted to use the ’69-’71 oil pipes in the rocker panels. The serviceable (replaceable) external oil pipes from ’74-> are best. When working the chassis, make improved provision for the oil plumbing. The SWB was not designed with this in mind (particularly inside the RR wheel). I would compare all the series regulations you might possibly run. That would be the European FIA-like and USA Historics, PCA, SCCA, NASA and more. You don’t want to do something that makes it non-complying in some important series. Start yourself a ‘Personal Workshop Manual and Parts Manual’ Personal Car Specific Manual My Porsche Library - Do I have everything for fixing my 1972? You can include images and posts from Pelican and other. Use the exploded diagrams from Porsche Parts Manuals and 911 Workshop Manuals to show your chassis plans. Keep us up to date. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
go for a 2,3 st
go for a 2,3 st!!!!!!!!!!
Let's wait a few days more...
How!! Your advices are really motivating but... before I get more tempted to start already discussing some aspects... please... let me get this business done!
![]() I am working really hard on that but I don't want to cause any disappointment around! ![]()
K-Jetronic student
Grady Clay, I am really interested on discussing most of the aspects on your post. Not because of this specific project but also about others I have on my mind and also already going like the SC 1983 stated on other thread.
I'll keep in touch. (can I PM you?)
K-Jetronic student
Digging up this old thread...
Any progress to report Alex? You might want to find the kardex for that vehicle. It looks to me that it has the mounts in the engine bay for a sport kit oil catch. andy |
