1980 911 SC
Has anyone gone with smaller diameter wheels in the front.
Just wondering.
Its a question I've been meaning to ask for a while.
What are the pros and cons. Has anyone done it.
Life's a Beach
Old 07-16-2010, 02:04 PM
racer's Avatar
It might make more sense to go with a smaller diameter rear to affect a gearing change. Not sure going to smaller fronts would do much, unless its a cheaper way to create a change in the vehicles rake (front to rear).
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 07-16-2010, 03:57 PM
Peter Zimmermann's Avatar
When I built my '81 SC for PCA Club Racing I went to 10 x 17 rears, and used 8 x 16 fronts - worked fantastic.
Keep the Shiny Side UP!
Pete Z.
Old 07-16-2010, 04:52 PM
1980 911 SC
That was one thought.
Life's a Beach
Old 07-16-2010, 05:10 PM
1980 911 SC
Peter, thanks for the picture.
I have seen your car posted here several times and was pretty sure it wasn't an illusion.
I figuered that it would probably turn quicker with the larger diameter rear trying to run over the smaller front.
If that makes any sense.
Life's a Beach
Old 07-16-2010, 05:15 PM
efhughes3's Avatar
Wheel diameter does not necessarily effect outside diameter. 17" tires typically will have lower aspect ratio numbers than 16's keeping the OD's similar.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-16-2010, 06:07 PM
Bill Verburg's Avatar
Originally Posted by sailchef View Post
Just wondering.
It would depend on what your goal is.
a bigger wheel can accommodate bigger brakes
a bigger wheel of equal width can run a lower profile tire that will run at a lower slip angle that will generate more grip and run cooler
Bill Verburg
Old 07-17-2010, 03:58 AM
