www.ALBERTOBILLA.it
Then ....I set the MFI at 15 ° BTCD 4 cyl ... As a result I had an enrichment at 4500rpm Someone knows the difference there is in regulating MFI in a different position from FE(40°ATCD 4 cylinder)?? PLS Help ![]() ![]()
www.ALBERTOBILLA.it
A/F result
1000rpm 10.2 2000rpm 10.8 3000rpm 11 4000rpm <10 4500rpm <10 5000rpm 11.8 6000rpm 12.5 7000rpm 13.5 8000rpm 15 |
Max Sluiter
You know, the LARGE font and colors just makes you look like a jerk, no offense intended. Please make ONE thread about your car and post all your questions about the MFI tuning there. It is much easier to help you when all questions and responses are in ONE place. If the thread goes more than a day without a reply, then you can bump it.
You should start learning forum manners by now. Best Regards, Max
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
www.ALBERTOBILLA.it
ok..i'm sorry
strung excuses I'm desperate ... |
Bandwidth AbUser
Best bet is to do all this on the Engine Rebuilding forum. You are in very specialized territory with this engine you're building, and the average Porsche do-it-yourself'er here is not going to be able to provide you with any help. I have some MFI experience, but it's at too immature a level to be of any use to you. You need very experienced MFI/engine building help / advice. Best wishes for success on your project, cyber.
Jim R. |
What Jim said!
I am not an expert here but I have read a lot of the MFI threads. I don't think the timing of the pump is causing your problems. From the Technical Articles: "... Porsche factory racers found that they could detect no difference in engine performance, no matter how the timing was set. I haven't noticed any difference myself in the adjustment, but I still set it anyway. Just a little tidbit I wanted to pass on. -Hans Achter"
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Max Sluiter
I have also heard that the timing makes little difference.
as to the original question i am going to try and help you out. i have someone i ca try to contact that use to set up my fathers race-car. tho its been a while, hoe he remember something. ill be intouch
theres nothing like the rear end squatdown of a turbo |
Max Sluiter
That's why I used the smile.
He was doing it more and more, if it was just occasionally, it is fine. I did not acutally think he was a jerk, just that he was making himself look like that to others. Besides, I have tried to give what help I can but you did not see that because it was in his other threads in the engine forum, early 911S board, and in this forum. He is doing fine now. The main thing was that he kept posting a new thread for the same question so all the responses were spread out. It is hard to help when everything is so fragmented.As for his question about the re-phasing the MFI 360*, the answer from the Early 911S Registry board was that the pump turns 360* for every 720* engine revolutions. Therefore re-phasing the MFI will not effect anything.
glad he got his answer. . . .i actually like the big blue writing. was refreshing
Max Sluiter
Do you gave the correct space cam in the MFI pump?
Max Sluiter
He says everything is RSR spec.
www.ALBERTOBILLA.it
Many thanks to everyone for your help ... and sorry if I wrote some time I opened color or more topics ...
I finally succeeded in setting up the car ... I depleted the screw pump up bringing more MFIs to lean after 4000rpm I unscrewed the screw in place of the thermostat so enriching all ... now is a bit fatter at 3000 rpm but it's ok ... thanks for all your advice seriously without it I could not ... now my car has 336hp at 8250rpm and 6850rpm 34kg/ma ... THANK YOU! |
Happy it all worked out for you. I believe you got and AFR instrument, and that helped. What kind did you get? Was there one in the dyno room
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
www.ALBERTOBILLA.it
Aem wideband , stack rpm ,dyno race... All sincro in datalog..
| Tags |
| 911 , cams , mfi , porsche , rsr |
