Yep, I've done that!
Move front 'M' Calipers to the rear?
Guys I have an early car with F & R 'M' calipers on it. The front is getting later BOGE/Bilsteins with Alloy 'S' calipers.
So I am sitting here looking at the removed front 'M' calipers thinking it might be a nice upgrade to mount them in the rear. I know the 'balance' will be off but a proportioning valve could fix that. They will need new lines but everything else is bolt on it looks like. Thoughts?
71' 911 Fully restored Tarmac Rally Long Hood RSR 03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine! 00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast! 86' 944 SPEC Car 'In Process' 2013 Debut |
I don't think it is worth the aggravation. 48mm pistons vs 38mm pistons is a huge difference to compensate for. I've only seen race cars with pistons that big on the back, and few enough of them. It also adds a lot more unsprung weight.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Is my memory failing or are they different bolt spacing on SWB?
Same F&R on 'M' caliper LWB. Different on 'S' caliper LWB. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
no, a p/v will not correctly compensate you want ~1.6+/- bias, moving front to rear will give you 1
Under the radar
You don't want to increase the rear braking on your car. You will find that with the S calipers in the front the brake balance will be great with your original rear calipers.
They do bolt on as I test mounted them.
OK it seems the consensus is that they are too much unless I go much bigger in the front which I do not intend to do.
I would think that if a four piston caliper was used with larger piston area it would be a nice easy way to add some rear brake without a lot of $$$ investment. By the way the weight difference between the front M and rear M is not very much.
common choices for the front and resulting hyd bias ratio w/ front M used in back 964 or Boxster 2 993 or 993tt 2.2 930 2 remember you want ~1.6 the bigger rotors used on all of the above further move bias to the front when the car is set up right you can take advantage of more rear bias down into the 1.475 + area, but no further
I would rather be driving
Bill, Can you elaborate on this statement? What setup changes need to be in place? I would assume a much stiffer suspension would not weight transfer as much to the front. This could take advantage of increased rear bias and therefore more braking force from the rear tires before rear lockup.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Anti-dive (as the 930s had) front suspension might reduce weight transfer.
Max Sluiter
Anti-dive does not reduce weight transfer, it actually speeds it up. The main way to reduce weight transfer is to lower the center of mass or lengthen the wheelbase.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Don't do it. the results are not an improvement. S fronts and M rears are well set up together. I even run this set on the 911. Think about it. IIRC the pad size is the same and you will need to reduce the pressure to make them work with the fronts. You are now right back where you started. Last edited by Green 912; 09-13-2010 at 01:40 PM.. |
You forgot downforce! Big wings go up in angle of attack during high speed braking which adds downforce during the nose down giving further ability to efectivly add rear braking.
Ask me how I know ![]()
Sorry if I confused anybody I have six calipers, two front M, two rear M and two front S. I changed struts and front calipers, swaping in the S calipers in front which left me with two front M calipers I was thinking about putting on the back. I think that I will hold off though now that I am hearing all this.
I do have some 944 Turbo calipers I was once thinking of putting on the front but I am leaning more toward period parts for this car, even if they are not 'original'. I figure the guys in the day were mixing things up that they had access to for race cars so I will do the same ![]()
