Yep, I've done that!
joeblow's Avatar
Move front 'M' Calipers to the rear?
Guys I have an early car with F & R 'M' calipers on it. The front is getting later BOGE/Bilsteins with Alloy 'S' calipers.
So I am sitting here looking at the removed front 'M' calipers thinking it might be a nice upgrade to mount them in the rear. I know the 'balance' will be off but a proportioning valve could fix that. They will need new lines but everything else is bolt on it looks like. Thoughts?
71' 911 Fully restored Tarmac Rally Long Hood RSR
03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine!
00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast!
86' 944 SPEC Car 'In Process' 2013 Debut
Old 09-13-2010, 08:01 AM
djpateman's Avatar
I don't think it is worth the aggravation. 48mm pistons vs 38mm pistons is a huge difference to compensate for. I've only seen race cars with pistons that big on the back, and few enough of them. It also adds a lot more unsprung weight.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-13-2010, 08:16 AM
Grady Clay's Avatar
Is my memory failing or are they different bolt spacing on SWB?
Same F&R on 'M' caliper LWB.
Different on 'S' caliper LWB.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 09-13-2010, 08:27 AM
Bill Verburg's Avatar
don't do it
no, a p/v will not correctly compensate
you want ~1.6+/- bias, moving front to rear will give you 1
Bill Verburg
Old 09-13-2010, 09:06 AM
Under the radar
Trackrash's Avatar
don't do it
+1
You don't want to increase the rear braking on your car. You will find that with the S calipers in the front the brake balance will be great with your original rear calipers.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-13-2010, 09:15 AM
joeblow's Avatar
They do bolt on as I test mounted them.
Best,
Grady
Old 09-13-2010, 09:32 AM
joeblow's Avatar
OK it seems the consensus is that they are too much unless I go much bigger in the front which I do not intend to do.
I would think that if a four piston caliper was used with larger piston area it would be a nice easy way to add some rear brake without a lot of $$$ investment.
By the way the weight difference between the front M and rear M is not very much.
Old 09-13-2010, 09:34 AM
Seems a bit odd.
The Rear M should be a 3" spacing
Early Front M had the same spacing.
All Alloy S Calipers had a 3.5" spacing so you may have an issue with your struts.
Old 09-13-2010, 09:58 AM
nope,
common choices for the front and resulting hyd bias ratio w/ front M used in back
964 or Boxster 2
993 or 993tt 2.2
930 2
remember you want ~1.6
the bigger rotors used on all of the above further move bias to the front
when the car is set up right you can take advantage of more rear bias down into the 1.475 + area, but no further
Bill Verburg
Old 09-13-2010, 10:06 AM
I would rather be driving
jpnovak's Avatar
Bill, Can you elaborate on this statement? What setup changes need to be in place? I would assume a much stiffer suspension would not weight transfer as much to the front. This could take advantage of increased rear bias and therefore more braking force from the rear tires before rear lockup.
Old 09-13-2010, 10:30 AM
Walt Fricke's Avatar
Anti-dive (as the 930s had) front suspension might reduce weight transfer.
Old 09-13-2010, 11:18 AM
Max Sluiter
Flieger's Avatar
Anti-dive does not reduce weight transfer, it actually speeds it up. The main way to reduce weight transfer is to lower the center of mass or lengthen the wheelbase.
Old 09-13-2010, 11:33 AM
the car needs to be very low and stiff, you will also want a p/v and an effective lsd, if you do that then you can get f/r pad/rotor temps to be almost equal, the braking decel rate is just awesome
Bill Verburg
Old 09-13-2010, 11:47 AM
Green 912's Avatar
Originally Posted by Trackrash View Post
+1
I did just this to make a full set of four on the 912 after the rears were found to have been damaged by an old ham-fisted rebuild. I just so happened to have a later set of stuts and some S binders in hand and threw it all on the car.
Don't do it. the results are not an improvement. S fronts and M rears are well set up together. I even run this set on the 911. Think about it. IIRC the pad size is the same and you will need to reduce the pressure to make them work with the fronts. You are now right back where you started.
Old 09-13-2010, 02:37 PM
joeblow's Avatar
You forgot downforce! Big wings go up in angle of attack during high speed braking which adds downforce during the nose down giving further ability to efectivly add rear braking.
Ask me how I know
Old 09-13-2010, 06:17 PM
joeblow's Avatar
Sorry if I confused anybody I have six calipers, two front M, two rear M and two front S. I changed struts and front calipers, swaping in the S calipers in front which left me with two front M calipers I was thinking about putting on the back. I think that I will hold off though now that I am hearing all this.
I do have some 944 Turbo calipers I was once thinking of putting on the front but I am leaning more toward period parts for this car, even if they are not 'original'. I figure the guys in the day were mixing things up that they had access to for race cars so I will do the same
Originally Posted by chris_seven View Post
Seems a bit odd.
Old 09-13-2010, 06:23 PM
