And note the crossover between the two tips too.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Sports Purpose 911 Driver
Steve stop being a tease...
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Dansk sport
I have one of these for sale, if you're interested!
Black Widow Blk on Blk '86 911 "...the secret to Porsche: we do things others cannot" |
Steve -
Is this something you are going to market, or a one off experiment? It looks interesting. Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Somewhere in the Midwest
Vacuum actuated to open less restrictive path at WOT. Now squeeze a couple of turbos in there
Where is the vac going to come from to open them?
Or are they held closed with vac? |
I was planning to plug my other outlet with a electric cutout.
911-87 mit der 3.6 V-Ram und alles spaß |
If it is open sitting on the bench and he has to close it manually it probably is held closed with manifold vac at idle and cruse. Then opens under WOT when vac drops.
That is my guess. |
Crotchety Old Bastard
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Brian,
Could be fun. On a turbo, other than noise control, do you think it might add to the power band anywhere over a great open muffler or zork. I can see an actual advantage on a NA car where it might broaden the TQ range. The best. |
Nope, on a turbo it's all about sound. Nothin' better than that turbo whistle and burbles on decel. With the 911 it must be a tuned system that adds performance and a cool sound.
I'm happy w/ these: Hushpower Pro Series mufflers
I'm running them on my twin turbo, so not a good comparison. They're light, quiet and inexpensive.
Nice!
Great set up for a turbo car. However, using that layout as a starting point for a NA car. I think I would try putting the mufflers on the tail pipe side which would make for a longer secondary tube and would work best with a long tube design. Then would add a cross over in the center just before the mufflers. A cross over should help with noise level, should reduce the back pressure potential from the muffler sections, and from reports by experts that know more then me, should make for a wider TQ band. Do not know how quite it would be though. I like. Just a guess. |
Gary,
Did you figure out a solution? I'm in the same boat with my car. I just found out that Limerock dropped their max db by 1 db. They'll be enforcing 87db max for BMW track days and 88db for PCA DE events. I just purchased a 911 with a 3.4 and megaphones and need to find a quiet muffler. I like the looks of Tom Butlers RSR rally style muffler. 2 rear outlets similar to M&K's but it also has the capability to cap the 2 outlets and use the 3rd exit pipe from the side pointing downward. i was searching for a picture of his muffler but I couldn't find it. Does anyone know if this style will be too restrictive on a 350hp engine when capped? Also, i don't see this style for sale anywhere. It looks like it might be a custom make
-Rich- 1984 911 Track 1985 911 Track/Autocross |
Look at the $200 muffler thread, i'm using the biggest Magneflow 2-in 2-out they have in 2.5" pipe. Not sure if it fits or how quiet, will post as soon as I get my SPL (iPhone) db readings!
Gary R. |
I should add this though I haven't had the car outside for a db test on my iPhone. Custom pipes using a Magneflo 12568.
Initial mounting ![]() Finished with all non SS parts heat painted.
Gary R. |
Gary, nice work. So what do you think, will it'll be quiet enough? Also, do you know what the distance is between exhaust pipes (center to center)? I'm wondering if that muffler is too long or will it fit within my exhaust cutouts on my bumper.
Other than stuffing baffles in the out pipes there is nothing else I can do, it's a BIG Muffler! The guys at Magnaflo seem to think it will do it. I even pointed the pipes down 30 degrees as I read in Grassroots it's one of many "tricks" to dissipate sound. It's ONLY for DE's at one track so if it needs baffles too so be it. I would start with one and then add the other if needed.. There's no way to know if next year's race will be muffled or not, but if not I need it and also for any NASA races that happen at LRP..
Gary R. Last edited by GaryR; 04-02-2011 at 10:39 AM.. |
I ran a Flowmaster 80 w/George's european headers on our 3.4 race car. I registered 92 db at Infineon. I ran small baffles for the street. The baffles probably cost me about 5+ h.p. at the top end and lowered the sound level by at least a few db's. I made my own baffles using perforated steel and wrapping it with s/s wool. You can control the sound level by how many wrappings of the s/s wool.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
