tobluforu's Avatar
With that setup you could install almost any third party muffler(s) you wanted. I guess I missed the track car part.
Old 10-21-2010, 11:23 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Yes, I can make any muffler work, just need one that does the "magic" of making power while knocking sound down to sud-90db..
Gary R.
Old 10-21-2010, 11:25 AM
Administrator
Jack Olsen's Avatar
I recently switched from the Flowmaster to a (smaller) Magnaflow, and was surprised that the new setup is quite a bit quieter. One other change is 993 headers instead of B&Bs. But the Magnaflow did very well on the dyno and -- especially on track days -- I actually wish it were a little bit louder.
Old Flowmaster: big.
Magnaflow: small.
Old 10-21-2010, 11:36 AM
GaryR's Avatar
Jack - would you remember which model Magnaflow it was?
Thanks!
Gary
Gary R.
Old 10-21-2010, 12:09 PM
constaf's Avatar
Gary,
I like Jack's set up. Wanna share the cost of buying 1 kit to experiment? then we'll split the cost of the 2nd kit of kit 1 proves adequate.
Also, i found a treasure chest of 15 inch wheels this morning
Fred
Old 10-21-2010, 12:38 PM
GaryR's Avatar
Also need to get an opinion on which way to point the tailpipes to minimize any readings. I was thinking straight down but then there may be an amplification bouncing off the asphalt. Set them the way Jack has them and it may be best as they only measure from one side.. if the muffler is quiet enough it won't matter.
Gary R.
Old 10-21-2010, 12:53 PM
wwest's Avatar
Originally Posted by GaryR View Post
I need to come up with a new muffler for my SC as the old Flowmaster 80 isn't going to cut it next year. I'm thinking Magnaflo 2-in/2-out this time but not sure if that will get me any lower db (figure 90db max at Limerock). I have two baffles crammed in the tailpipes now but it's killing power...
Does one exist..?
Yes, absolutely, and even in daily use in some applications.
Electronic "anti-noise" engine mufflers have been around for quite some time now. It's possible they could even be switched off and on if one wished to do so. Most commonly used on diesel engine power generators in urban areas, QUIET zones, hospitals, etc.
Old 10-21-2010, 12:56 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
put a turbo on it! they are quiet
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 10-21-2010, 01:06 PM
Been here a while
for lime rock, I would dare say point towards the passenger's side.....most times I've seen them taking measurements, it has been along the driver's side....also, this will be quieter for the driver.
agreed, down will amplify the sound
you could point them towards each other, and hope they will be cancel each other out
looking for 1972 911t motor XR584, S/N 6121622
Old 10-21-2010, 01:30 PM
Navin Johnson
TimT's Avatar
This is my Lime Rock set up. The car has headers and a M&K RSR muffler. I got a cap for one side, an elbow, and a baffle.. I can obviously switch the cap and elbow side to side, aim the elbow etc..
Also on the headers I had v band clamps installed so I can easily put on megaphones..
'69 911 GT-5
'75 914 GT-3
and others
Old 10-21-2010, 01:47 PM
Navin Johnson
TimT's Avatar
oops pic posting error
'69 911 GT-5
'75 914 GT-3
and others
Old 10-21-2010, 01:49 PM
Navin Johnson
TimT's Avatar
the whole shebang
'69 911 GT-5
'75 914 GT-3
and others
Old 10-21-2010, 01:58 PM
Bill Verburg's Avatar
Originally Posted by TimT View Post
the whole shebang
That's the sort of thing I was referring to, except of course it's in steel instead of c/f
Lot's of internal volume to absorb the noise
Bill Verburg
Old 10-21-2010, 02:08 PM
Steve W's Avatar
teaser pics:
Old 10-21-2010, 03:44 PM
Administrator
Jack Olsen's Avatar
Model 11386 - currently $81 at Amazon and it's stainless.
There are bigger models, but I needed to squeeze between the outlets of 993 headers.
Here's a picture of how it works:
I'm trying to figure out Steve's. Is that a solenoid for a bypass valve?
Old 10-21-2010, 04:18 PM
Zeke's Avatar
Whoa, it sure looks like it. Shoots the gasses thru the lower pipe right at the exit.
Old 10-21-2010, 04:39 PM
Diss Member
Quicksilver's Avatar
Weren't you using the Dynomax 17725 with the B&Bs?
If so which was quieter?
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-23-2010, 08:18 AM
GaryR's Avatar
I would think I would use the biggest one I could fit, similar in size to the FM 80..
Gary R.
Old 10-23-2010, 08:22 AM
Administrator
Jack Olsen's Avatar
No, I had a Flowmaster. I never took measurements, but my belief is that the Magnaflow is quieter. Again, though, it could also be because the 993 headers might be quieter than the B&Bs.
Old 10-23-2010, 09:11 AM
Crotchety Old Bastard
RarlyL8's Avatar
The muffler Steve is using looks to be from a late model 911GT3. Not an inexpensive solution, and when the valves open, not quiet. Very cool street system though.
Old 10-23-2010, 10:52 AM
