Throw it on the ground!
NEED HELP! 1987 3.2 won't start
Started with usual suspects. Replaced DME relay today and then fuel pump (orig) .....both on my to do list anyway. Still won't start. Could not hear old fuel pump running with ignition on and can't hear new pump either. Ideas?
Speed and reference sensors both replaced year ago at time of engine swap along with new dizzy cap, rotor, plugs and plug wires. Are any of the fuse panel relays associated with the fuel pump or just the DME relay under the driver seat? Could it be the Motronic box? Mine is a reman unit already....not sure when replaced. Thanks ![]()
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 10-22-2010 at 04:38 PM.. |
Checked out
I'd pull a plug and see if you are getting spark.
I'd try a shot of starter fluid to see if it is a fuel issue. I'd also give the CHT sensor a check with a multimeter to see if you have proper cold resistance. For the 20 minutes it would take to do those 3 things, it can help narrow things down quite a bit. |
Checked out
Also, you said you replaced the DME relay today. Was it starting fine with the old relay? If so, put the old relay back in and give it a shot. Many people (myself included) have gotten new DME relays that were bad right out of the box (esp. if its a URO one).
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
I was not starting with the old DME Relay either. My new DME Relay came from the local dealership - spendy but I needed it immediately.
battery?
Battery is fine - Optima Yellow Top < 1 year old - cranks like a mother!
Car has been running fine with no previous problems. Retuned from trip late last night......would not start this AM (fortunately this did not happen when I was out of town)
Do a quick dist cap/rotor check, after you check the fuses in the trunk?
Have checked all fuses in trunk and engine bay and dist cap. All good. Have Motronic box out now checkng for cracked solder joints (PITA for these 50 year old eyes)
more PM's than Posts
Was the Reference Sensor you replaced an OEM Bosch unit? Ive heard of people having problems with non OEM ones. The original reference sensor on my 84 just stopped working about a month ago, leaving me stranded with no fuel/spark. The easy check for that would be to see if the tach needle bounces while the car is cranking
You have to check and see if you lack spark or fuel. Do not use starter fluid on a gas engine ever. Pull off a plug wire, short it to ground and see if you have spark. If you have spark then check fuel pressure.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Was it parked outside in the rain?
Could not find any obvious solder cracks on the DME cirucit boards so I buttoned everything back up. Still no power to the fuel pump so I called AAA and flatbedded it to the Dealership for them to troubleshoot the problem.
Thanks all for the help. I've got to get my DD back on the road quickly and promissed Mrs PAPAMRK I'd finish the hardwood floors upstairs this weekend. In 4 years of daily driving, this is the first time I've had to get towed. ![]() ![]()
The fuel pump only runs when you crank or when the engine is running. Did you check power WHILE cranking?
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
No. I did not know that. I thought the fuel pump was energized with the ignition on. In any event, after replacing the fuel pump and DME Relay (both needed to be replaced anyway for peace of mind), I am beyond my diagnostic capabilities.
Did you check the fuel pump relay in the trunk on the fuse block? The red one
Dan O 84' 3.2 Targa |
Per my check of the Bentley Manual, there is no fuel pump relay on the panel (none labeled as such in the picture anyway)
Mine is the first position on the right and is not labeled on the block cover. I presumed you have one too as the part is listed for 74 thru 89 I think. I had the same issue and it was the relay. Here's the blurb from the hosts parts site:
Relays are a very common source of failure in the 911. There are several different relays used within the 911, and all are subject to failure after many years of service. Before suspecting your wiring or your components, be sure to check your relays. Before you decide to replace your fuel pump, make sure that your Red fuel pump relay, which is located on the relay board within the front trunk area, is functioning properly. Also be sure to check that your DME relay, 911 (1984-89), is functioning properly. Pelican recommends that you carry an additional DME relay, which is located just under the driver's seat, with you at all times. It is wise to have at least a spare on hand, so that you can check the proper operation of the one that is already installed within your 911.
Thread Tools | |
Rate This Thread | |
