AlfonsoR's Avatar
Engine Drop: While you're in there stuff??
Guys,
I am planning an engine drop (first one) to replace the oil cooler seals, they are leaking and oil from that and from leaky fitting on oil return line is getting onto exhaust, so those are the main two reasons for the engine drop. But can you guys help me with other stuff to replace "while i'm in there"?? The car is an 89 Carrera 3.2 and has 104,000 miles. Valve guides were replaced at 98,000. I will be dropping engine and trans as one unit. This is my list so far:
1. throttle bell crank bushings, on engine and trans
2. three fuel hoses and oil return line to Amazon hose in Tampa, c/o Bill Hippy
3. oil cooler seals
4. oil pressure sending unit
5. Spark plugs
6. valve lash adjust
7. Transmission oil
What else??
Thanks in advance.
Old 10-23-2010, 05:25 PM
Oh Haha's Avatar
Engine and transmission mounts although they can be done with the engine in.
Pacific Blue
Wayne
Old 10-23-2010, 05:31 PM
Zeke's Avatar
How's the sound/heat pad?
Old 10-23-2010, 05:45 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuses and relays
Not part of your ongoing effort(s),
but check my June post "Adding fuses and relays".
And +1 on your sound heat pad.
P/N 911-556-891-01
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-23-2010, 05:59 PM
Vac lines & heater hoses, especially if they look at all worn.
++ on the sound mat, very easy without the engine... very hard with.
I'm not familiar with the 3.2 engine bay layout, but in the SC/2.7 the fuel filter is much easier to deal with w/o the engine in (unless the electric heater fan has been removed), and you don't spill gas all over the engine.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 10-23-2010, 06:47 PM
Taking it apart is easy
Jerome74911S's Avatar
I replaced the sound pad, as some others recommend.
Got a deluxe one from our host:
Honestly, I don't notice any improvement in noise abatement when compared to the original - and disintegrating - noise pad. But, it needed to be changed, regardless.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 10-23-2010, 07:01 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Arrow Start Ordering...
Doing the same and looking for a "not going crazy" list... Got the sound pad last year so it will go in.
101 Project #7 highly recommends the following replacement among other things;
Oil Pressure Switch: Project 21
Heater Hose: Project 43
Oil Breather Hose: Project 21
Clutch and Flywheel seal: Project 8
CIS Intake Manifold Hose: Project 31 (1973-1983)
Oil Cooler Seals: Project 21
Pulley Seals: Project 21
Valve Cover Gasket (& adjustment): Project 18
Oil Cooler O Ring Thermostat: Project 21
Rocker Arm Seal: Project 21
Who Will Live... Will See
Old 10-24-2010, 03:29 AM
Throw it on the ground!
Be sure to check the condition of the rubber on this vacuum line behind the heater blower as cracking is a common failure. Link to my repair thread attached.
Repair vs Replacement options for this part?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 10-24-2010, 06:01 AM
sp_cs's Avatar
Banana arm bushes?
Fuel line inspection, for sure
Shirish
1987 Carrera, Granite Green
Old 10-24-2010, 06:47 AM
and if you are close to replacing it, then replace the clutch. If you do go into the clutch, replace the rear main seal as well.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-24-2010, 07:05 AM
Oh Haha's Avatar
+1000!!
Pacific Blue
Wayne
Old 10-24-2010, 07:12 AM
cleaning and paiting engine tin baffles. that is almost free.
Old 10-24-2010, 07:18 AM
mppickett's Avatar
Check the oil breather gasket to see if it is leaking. If you're replacing the clutch, be sure to put in a new release bearing.
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 10-24-2010, 11:29 AM
burgermeister's Avatar
You can de-rust & refurbish the heater flapper valves.
Rear brake lines are a breeze with the engine out
Rear wheel bearings are a lot easier
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 10-24-2010, 12:25 PM
Crusty Conservative
silverc4s's Avatar
Originally Posted by sp_cs View Post
Banana arm bushes?
Not sure what year your car is, but on many of our torsion bar cars, the bolts that hold the banana arms in place are installed pointing outward. Reversing these - as you check the bushings - will enable removal with the engine in place in the future.
Also a good time to clean and repaint or powdercoat all of the engine tin. Nice dress up item...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 10-24-2010, 12:45 PM
AlfonsoR's Avatar
Thanks guys for all the replies…
Let’s see
Engine and trans mounts → will check these once engine is dropped, thanks Wayne
Sound/heat pad → looks to be in good condition. I will take a closer look once engine is down, thanks Milt
Fuses and Relays → this one’s been at the back of my mind. I definitely don’t want my car to burn down to the ground, so I’ll probably do this too, thanks Gerry
Vac Lines & heater hose → I guess I’ll have to search on that one, not sure where these are
Fuel fitler → thanks for reminding me of that. I actually already have the filter, thanks Chris
101 porjects → I’ve been meaning to buy this reference. Thanks for the list JJ. I too did not want to go Crazy with this project.
Vacuum line → thanks MThomas,
Bannana Arm bushings, need to research these too → thanks Shirish
Clutch → The clutch feels good, if a bit stiff for a hydraulic unit. So won’t be replacing it now. Thanks YelCab1
Clean and paint engine compartment → will do, thanks again YelCab
Oil Breather gaskets → thanks Mike, I will do these too
Flapper valves → will do, thanks Burgermeister
Reverse Banana bolts and powder coat engine tin → thanks Bill
Thanks again everybody!!
Old 10-24-2010, 12:54 PM
Mo money = mo parts
I'll suggest the temp sensor and the speed and reference sensors. If the outer casing on your sensors crumbles in your hand, time to go. You can cross reference the speed and ref sensors to BMW units which are considerable less expensive (1/2). I don't have the part numbers, but there are threads that list them. I did mine two years ago with Bosch units for a BMW. They were identical in every respect - length, bolt location, diameter, etc. Direct replacements from the same manufacturer designed for a motronic engine mgmt system.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 10-24-2010, 05:54 PM
Less brakes, more gas!
euro911sc's Avatar
With the engine out it is a good time to check CV joints and boots for wear and tear.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-24-2010, 06:19 PM
Tule Tom
Engine out-------Clean Clean Clean make it spotless and keep it that way.....
Polish or look into the fan and alternator assembly, any seal and or o rings
valve cover gaskets, fuel lines disinigrate, change them. Steam clean.
Clutch throw out bearing new disk, and your car will really quiet down...
Have fun
Tom
88 Carrera Targa
Old 10-25-2010, 07:37 PM
+1 on replacing speed, reference and CHT sensors. Easy to do with engine out and good preventative maitenance. I am going thru a no start situation traced to a reference sensor failure right now.
Mark
1987 911 Coupe
Old 10-25-2010, 07:59 PM
