Engine Drop: While you're in there stuff??
Guys,
I am planning an engine drop (first one) to replace the oil cooler seals, they are leaking and oil from that and from leaky fitting on oil return line is getting onto exhaust, so those are the main two reasons for the engine drop. But can you guys help me with other stuff to replace "while i'm in there"?? The car is an 89 Carrera 3.2 and has 104,000 miles. Valve guides were replaced at 98,000. I will be dropping engine and trans as one unit. This is my list so far: 1. throttle bell crank bushings, on engine and trans 2. three fuel hoses and oil return line to Amazon hose in Tampa, c/o Bill Hippy 3. oil cooler seals 4. oil pressure sending unit 5. Spark plugs 6. valve lash adjust 7. Transmission oil What else?? Thanks in advance.
Engine and transmission mounts although they can be done with the engine in.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
How's the sound/heat pad?
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuses and relays
Not part of your ongoing effort(s),
but check my June post "Adding fuses and relays". And +1 on your sound heat pad. P/N 911-556-891-01 Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-23-2010 at 06:19 PM.. |
Vac lines & heater hoses, especially if they look at all worn.
++ on the sound mat, very easy without the engine... very hard with. I'm not familiar with the 3.2 engine bay layout, but in the SC/2.7 the fuel filter is much easier to deal with w/o the engine in (unless the electric heater fan has been removed), and you don't spill gas all over the engine.
Don't Lift... Don't Lift... Don't Lift ![]() ![]() ![]() '75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade. |
Taking it apart is easy
I replaced the sound pad, as some others recommend.
Got a deluxe one from our host: ![]() Honestly, I don't notice any improvement in noise abatement when compared to the original - and disintegrating - noise pad. But, it needed to be changed, regardless.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
83 911 Production Cab #10
Doing the same and looking for a "not going crazy" list... Got the sound pad last year so it will go in.
101 Project #7 highly recommends the following replacement among other things; Oil Pressure Switch: Project 21 Heater Hose: Project 43 Oil Breather Hose: Project 21 Clutch and Flywheel seal: Project 8 CIS Intake Manifold Hose: Project 31 (1973-1983) Oil Cooler Seals: Project 21 Pulley Seals: Project 21 Valve Cover Gasket (& adjustment): Project 18 Oil Cooler O Ring Thermostat: Project 21 Rocker Arm Seal: Project 21
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Throw it on the ground!
Be sure to check the condition of the rubber on this vacuum line behind the heater blower as cracking is a common failure. Link to my repair thread attached.
Repair vs Replacement options for this part? ![]()
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Banana arm bushes?
Fuel line inspection, for sure
Shirish 1987 Carrera, Granite Green |
and if you are close to replacing it, then replace the clutch. If you do go into the clutch, replace the rear main seal as well.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
+1000!!
cleaning and paiting engine tin baffles. that is almost free.
Check the oil breather gasket to see if it is leaking. If you're replacing the clutch, be sure to put in a new release bearing.
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) |
You can de-rust & refurbish the heater flapper valves.
Rear brake lines are a breeze with the engine out Rear wheel bearings are a lot easier
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Crusty Conservative
Not sure what year your car is, but on many of our torsion bar cars, the bolts that hold the banana arms in place are installed pointing outward. Reversing these - as you check the bushings - will enable removal with the engine in place in the future. Also a good time to clean and repaint or powdercoat all of the engine tin. Nice dress up item...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Thanks guys for all the replies…
Let’s see Engine and trans mounts → will check these once engine is dropped, thanks Wayne Sound/heat pad → looks to be in good condition. I will take a closer look once engine is down, thanks Milt Fuses and Relays → this one’s been at the back of my mind. I definitely don’t want my car to burn down to the ground, so I’ll probably do this too, thanks Gerry Vac Lines & heater hose → I guess I’ll have to search on that one, not sure where these are Fuel fitler → thanks for reminding me of that. I actually already have the filter, thanks Chris 101 porjects → I’ve been meaning to buy this reference. Thanks for the list JJ. I too did not want to go Crazy with this project. Vacuum line → thanks MThomas, Bannana Arm bushings, need to research these too → thanks Shirish Clutch → The clutch feels good, if a bit stiff for a hydraulic unit. So won’t be replacing it now. Thanks YelCab1 Clean and paint engine compartment → will do, thanks again YelCab Oil Breather gaskets → thanks Mike, I will do these too Flapper valves → will do, thanks Burgermeister Reverse Banana bolts and powder coat engine tin → thanks Bill Thanks again everybody!! |
Mo money = mo parts
I'll suggest the temp sensor and the speed and reference sensors. If the outer casing on your sensors crumbles in your hand, time to go. You can cross reference the speed and ref sensors to BMW units which are considerable less expensive (1/2). I don't have the part numbers, but there are threads that list them. I did mine two years ago with Bosch units for a BMW. They were identical in every respect - length, bolt location, diameter, etc. Direct replacements from the same manufacturer designed for a motronic engine mgmt system.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Less brakes, more gas!
With the engine out it is a good time to check CV joints and boots for wear and tear.
-Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Tule Tom
Engine out-------Clean Clean Clean make it spotless and keep it that way.....
Polish or look into the fan and alternator assembly, any seal and or o rings valve cover gaskets, fuel lines disinigrate, change them. Steam clean. Clutch throw out bearing new disk, and your car will really quiet down... Have fun Tom 88 Carrera Targa |
