Send a message via AIM to NoLift911
Brake line part number for SC (removing proportioning valve - Carrera)
Does anyone have the part number for the SC brake line that runs from the M/C to the front coupler? I am removing my proportioning valve on my 84 Carrea and want to use this line in place of the valve.
Thanks -
Jeff
Old 01-10-2011, 12:14 PM
Bill Verburg's Avatar
Thanks -
the line that goes from the m/c to the rear brakes on lhd 911 '83 and earlier is 911.355.307.03 but you can't just use it w/o re-plumbing the front too.
Porsche changed the line config from old ('pre 84 style ) to new ('84-89 style), probably just to confuse everyone.
It's easiest to just make up your own replacement line or you can just gut the p/v.
Bill Verburg
Old 01-10-2011, 12:57 PM
Having not taking the P/v off yet is it possible to gut? That was my next question...what's involved?
Jeff
Old 01-10-2011, 04:32 PM
yes, they are easy to gut
this one is off a 964 but yours will be similar
Bill Verburg
Old 01-10-2011, 05:04 PM
Awesome - thanks Bill!!!
Jeff
Old 01-10-2011, 07:03 PM
175K911's Avatar
Like Bill said, I've always just gutted the ones in my Carreras. Just make sure you put some saran wrap or tin foil under the pv before you loosen the lines so the brake fluid doesn't run out on the painted surfaces.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 01-10-2011, 07:20 PM
Jaskas's Avatar
I took the whole valve away and bended the small line part a bit to connect the line w/o the valve. This was in my -87
The parts are in wrong order in the last picture...
911-87 mit der 3.6 V-Ram und alles spaß
Old 01-10-2011, 10:48 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Agreed you can simply "stretch" the line to make up the lost length of the pressure-limiting valve. Porsche OEM brake line material is nice & flexible, unlike the cheap storebought pre-flared lengths that are much stiffer.
Kevin L
'86 Carrera "Larry"
Old 01-11-2011, 06:38 AM
TroyN's Avatar
Benefit to removing or disabling the valve?
'01 996, w/ LN IMS!
Past: '96 993, '98 986, '82 911, '99 986, '87 930, '86 951, '85 911 GTS3 race car
Old 05-09-2011, 09:56 PM
