HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Just a thought...would a spool (locked differential) and an electrically controlled torque box on either side leading to the rear wheels work?
With bias control available from the steering wheel, you would effectively have an infinite control of the torque or power to each side, and the trailing power leading into a turn would also be controllable.
I know the several manufacturers use these things to balance power to the front in 4 wheel drive applications, so using 2 of them of the correct size should not be a problem.
As I said...just a thought.
Bob
Bob Hutson
Old 02-12-2011, 09:48 AM
VZ935's Avatar
Send a message via AIM to VZ935
I'll throw my hat in with some of the other guys on the Guard Ltd . I used to break Quaiffe's frequently in my car and though the customer service was fantastic and they would always send me a new unit I eliminated the problem when I went to the Guard .
A bunch of old race cars
Old 02-12-2011, 10:29 AM
Bob - What's a torque box?
Some of the World Rally Cars used to have hydraulically controlled LSDs which seemed very effective but these have now been banned but the technology certainly exists.
Old 02-13-2011, 04:11 AM
Max Sluiter
Flieger's Avatar
How about a FTT (Front Torque Transfer) system from a 90's F1 car appied to the rear?
Old 02-13-2011, 11:53 AM
HawgRyder's Avatar
Chris:....my brain seized when I described the box.
What I meant was an electrically controlled viscous coupler.
These are used in 4 wheel drive vehicles to couple the power to the opposite end and sometimes side to side.
The inside of them looks like a torque converter with the liquid viscosity controlled by DC voltage (or current).
I have seen these about 6 - 8 inches in diameter pushing power from a 100HP electric motor.
In operation, they build up some heat, and usually have fins on the outside to help the cooling.
If you look up Viscous Drive....one picture will explain everything.
Bob
Bob Hutson
Old 02-13-2011, 01:40 PM
Any experience with the Wavetrac LSD yet on 911's?
Old 05-16-2011, 10:06 AM
wayner's Avatar
Is this what a quaife is for?
YouTube - VW Beetle Quaife gearbox test
SOLD - 914 wide body hot rod
Old 05-16-2011, 12:53 PM
gearhead
Originally Posted by chris_seven View Post
Interesting - I don't think an LSD will help much with wheelsin off the line but should be good at stopping the inside wheel spinning out of corners.
Care to explain the logic behind this statement? When an LSD experiences a certain amount of wheelspin it's going to lock. Whether or not that's in a corner or on a standing start off the line it's going to be the same. When one drive wheel begins to spin the LSD is going to lock and split the power between both wheels, given the car better traction.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-17-2011, 10:16 AM
strangefingers
Even though this seems to be a year old thread, I have experience with Wavetrac in 2 applications. I have an '85 911 track/street car with a modified Euro 3.2L, coilovers and a '74 911S 7:31 short gear box. It's a very happy puppy with great scoot and handling. I love the Wavetrack, it puts down the power on short technical road courses with numerous slow tight turns and elevation changes in my region and the cars behavior under decel, braking and trail braking is exemplary leading me to believe in the claimed friction on deceleration.
The second car is a track only '74 chassis 911, modified torsion bar suspension, 3.8L built racing motor and a re-geared/modified G50/01 with a shortened bell housing. When I was completing this car I didn't hesitate to use Wavetrack again and I LOVE the end result. Again, I can drive the car rotating around apexes with controlled throttle input pointing it exactly where I want it and accelerating hard through the exits... I've driven 911s with good stock Porsche LSDs and one with a Guards built LSD and my sweet spot was instantly struck with the Wavetrac. Bang for the buck, for a unit which has never put a wheel wrong for me, I'll continue choosing it for any future projects.
Dave.
Old 06-05-2012, 05:02 PM
DG624's Avatar
The Wavetrack seems to be an advancement in technology with more flexibility for decel and aceleration out of corners. The ads show how the plates react to different torque between wheels and it seems to allow the differential to revert to a simple unlocked unit when everything is even. I have one for my VW GTI but not for my 911...yet.
Old 06-07-2012, 09:27 AM
gearhead
I don't know if it was you or someone else who made the post but on another board there was some guy asking about there being no warranty on our parts. The responder said that Quaife has a lifetime warranty and you will use it multiple times in your life. The Guard has no warranty and does not require one. Thanks for the endorsement.
As for the Wavetrac? There's some good commentary from owners, as wel as Steve Weiner, in a thread over on Rennlist:
Diff between a TBD and a LSD? - Rennlist Discussion Forums
1974 914 Bumble Bee
2009 Outback XT
Old 06-07-2012, 10:35 AM
cliyde's Avatar
Been running the Wavetrac in my newly rebuild 915 for about 4 months now. Came highly recommended by my local shop and Patrick Motorsports where I sourced it. So far nothing but positive comments with spirited road use. Car handles well in the curves and under braking... seems mildly passive in normal day to day road use and doesn't have an aggressive oversteer onset feel like my 928 LSD did. I DO feel it working when pushed hard in the curves... Will have my first DE with it in March so we'll see how much of a difference it makes out on the track!
G-Body 3.6 Transplant
Old 02-13-2013, 05:39 PM
Plavan's Avatar
I was looking into building a Spec Z car for NASA (New Spec series)- Wavetrac is the "Spec" LSD- Read their forums...... Some only last a race or two, and if they last, they are having other issues........ Junk in my book.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 02-14-2013, 08:55 AM
I thought that was a heat generation in the diff issue more than a Wavetrac issue? I thought that I read Nissan even admitted that there is a flaw in the Z design causing excess heat in diff fluid. I know that NISMO now offers an improved diff cover and diff cooling system.
Old 02-14-2013, 10:03 AM
Plavan's Avatar
From what I understand and have seen, there have been failures even when adding coolers. Check out NASA forums spec Z- there is a HUGE thread about it, and there are not many Spec Z cars built.
Quote de Plavan
Old 02-14-2013, 10:35 AM
cliyde's Avatar
Drove CMP last weekend... nothing but positive experience out on the road course. Coming out of carousel doing about 70mph got sideways drift going 30-40ft with power down to both wheels instantly. Was able to recover effortlessly.
Overall Car handled well in the "twisties", did not feel any aggressive wheel lock. I'm a VERY happy camper!
Old 03-16-2013, 07:54 PM
Alter Ego Racing
ErVikingo's Avatar
We only use GT or old ZF in our race cars. We get replacement discs for the old ZF units from GT.
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 03-17-2013, 04:59 AM
gearhead
Cliyde, what do you think caused the tail to wag?
Old 03-17-2013, 08:26 AM
Bill Verburg's Avatar
iId only use Porsche Motorsports asymmetric 40/60 w/ GT internals, GT asymmetric or as a last resort the an old style ZF, Porsche street asymmetric's w/ GT internal are pretty good too.
Bill Verburg
Old 03-17-2013, 08:44 AM
cliyde's Avatar
Driver's fault, for sure. Pinched the wheel too much tryin to reel it in before the straight. Totally predictable and controllable oversteer... Felt like Tanner Foust out there for a split second.
Old 05-15-2013, 07:38 PM
