| Now in 993 land ... |
			How old are your wires? Like I said above, if they are over 5 years old, chances are they may be bad. I know they aren't cheap, but they are the next thing to change. Generally you can't see or feel if they start to deteriorate. I would have done the cap, wires and plugs at the same time to save labor time. Now you have to go in there one more time disconnecting and reconnecting them on both ends.   G | ||
|  02-19-2011, 10:35 PM |
| Registered | Quote:
 I will be ordering some up Monday thanks for your help..
				__________________ A man who dares to waste one hour of time has not discovered the value of life....... Much Respect   | ||
|  02-19-2011, 10:41 PM |
| Registered Join Date: Dec 1999 Location: Novato, CA
			Beru ignition cables will make any 911 ignition challenged. Add rain and the situation becomes magnified. Cheers, Joe | ||
|  02-19-2011, 11:40 PM |
| Registered |
			Should I buy Beru,Magnacor,Bosch or Clewetts and are Magnacor and Clewetts the same brand because,Clewetts Website sells both?
|  02-20-2011, 08:47 AM |
|  02-20-2011, 04:18 PM |
| muck-raker Join Date: Jan 2009 Location: Coastal PNW
			89cab, make sure you save all the parts you replaced up to now.  If your problem turns out to be different than ignition-related, you will have a stock of known, good used parts that you can use to diagnose future problems....without having to throw money at it. Many people here like the Magnacore, BTW....the Clewetts have a good reputation as well.
				__________________ STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.  Deny Everything; Admit Nothing; and Always Make Counter-accusations   | ||
|  02-20-2011, 04:34 PM |
| Registered |
Noted,Thank you
|  02-20-2011, 07:55 PM |
			Also, you might consider sealing your distributor cap at the perimeter where it meets the distributor with Ultra Grey sealant to prevent moisture ( whenever it rains ) from getting inside and causing your problem in the first place. Another problem area are the rubber boots on the distributor terminals that have a tendency to wick water when wet causing shorts on the cap. Cheers, Joe 74 911 w/86 3.2 and no longer ignition challenged Last edited by stlrj; 02-21-2011 at 07:49 AM.. | ||
|  02-21-2011, 05:22 AM |
| Registered |
			OK,just installed new Magnacor wires,and I have to say removing the old wires was a *****.. there was a fastner under my A/C compressor that I could not get to, in order to remove the old Beru wires,so I had to cut them out,the left side was easy but right sucked..I can feel a big differance it seems like more power, WOW!!! Hasn't rain enough to tell if that was the problem,but I am glad I got to replace them..
|  03-03-2011, 02:54 PM |
| Registered Join Date: Mar 2005 Location: Northern CA
			AC compressor is easy to unbolt and get out of the way, I usually get it loose when fishing the ig. wires in/out of there.  Is it your opinion that the new wires fixed the problem?  Is it running smooth now?
|  03-03-2011, 04:26 PM |
| abit off center |
			If it gives you problems again "post 19"  I just had a speed sensor puke out finally after chasing an intermittent problem.  A quick test will tell but only if it is bad when you check it.
				__________________ ______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. | ||
|  03-03-2011, 05:19 PM |
| Member 911 Anonymous | Quote:
 I replaced my Beru's too but when installing my Magnacor's I realized one did not click on causing my rough performance.
				__________________ '85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC | ||
|  03-03-2011, 05:30 PM |
| Registered |
			Here is the thread I referenced back on post 19 concerning the problem with my sensors. Keep it in mind if you are still experiencing problems. Need help: power loss
				__________________ Kipp 1987 Black 911 3.2 Carrera Coupe 1999 Green Mazda MX5 (SOLD) | ||
|  03-03-2011, 07:48 PM |
| Registered | Quote:
|  03-03-2011, 08:35 PM |
| Registered | Quote:
|  03-03-2011, 08:36 PM |
| Registered | Quote:
 Nice thread, I am with you every time I do a search no one finishes there thread to tell us what the results are from there repairs..I know most people get excited when fixing the problem and feel that it may not help,BUT IT DOES! Also my next step if the problem returns is to replace the sensors..
|  03-03-2011, 08:47 PM |
| Registered | Quote:
|  03-03-2011, 08:50 PM |
| Registered |
			Tom Amon of Mobile Works West.  Do a search on his name, you will read a lot of positive feedback.  He also was the guy that did my PPI and had worked on my car several years before I purchased it. Mobile Porsche Repair - Mobile Works West brings the Porsche Repair SHOP to YOU
|  03-03-2011, 08:56 PM |
| Registered | Quote:
|  03-03-2011, 09:12 PM |
| Registered |
			Well guys,Looks like the Plug Wires were the problem,so far so good its rained twice and no problems. Thanks for all your help,I will keep you all posted if something changes..
|  03-17-2011, 12:12 PM |
