Now in 993 land ...
aigel's Avatar
How old are your wires? Like I said above, if they are over 5 years old, chances are they may be bad. I know they aren't cheap, but they are the next thing to change. Generally you can't see or feel if they start to deteriorate. I would have done the cap, wires and plugs at the same time to save labor time. Now you have to go in there one more time disconnecting and reconnecting them on both ends.
G
81 SC (sold)
Old 02-19-2011, 10:35 PM
G
There is a good chance that they are over 5 years old, I have had the car for 4 years..
I will be ordering some up Monday thanks for your help..
A man who dares to waste one hour of time has not discovered the value of life.......
Much Respect
Old 02-19-2011, 10:41 PM
Beru ignition cables will make any 911 ignition challenged. Add rain and the situation becomes magnified.
Cheers,
Joe
Old 02-19-2011, 11:40 PM
Should I buy Beru,Magnacor,Bosch or Clewetts and are Magnacor and Clewetts the same brand because,Clewetts Website sells both?
Much Respect
Old 02-20-2011, 08:47 AM
Just make sure they're carbon core and not stranded copper.
Old 02-20-2011, 04:18 PM
muck-raker
kidrock's Avatar
89cab, make sure you save all the parts you replaced up to now. If your problem turns out to be different than ignition-related, you will have a stock of known, good used parts that you can use to diagnose future problems....without having to throw money at it.
Many people here like the Magnacore, BTW....the Clewetts have a good reputation as well.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-20-2011, 04:34 PM
Noted,Thank you
Much Respect
Old 02-20-2011, 07:55 PM
Also, you might consider sealing your distributor cap at the perimeter where it meets the distributor with Ultra Grey sealant to prevent moisture ( whenever it rains ) from getting inside and causing your problem in the first place.
Another problem area are the rubber boots on the distributor terminals that have a tendency to wick water when wet causing shorts on the cap.
Cheers,
Joe
74 911 w/86 3.2 and no longer ignition challenged
Old 02-21-2011, 05:22 AM
OK,just installed new Magnacor wires,and I have to say removing the old wires was a *****..
there was a fastner under my A/C compressor that I could not get to, in order to remove the old Beru wires,so I had to cut them out,the left side was easy but right sucked..I can feel a big differance it seems like more power, WOW!!! Hasn't rain enough to tell if that was the problem,but I am glad I got to replace them..
Much Respect
Old 03-03-2011, 02:54 PM
AC compressor is easy to unbolt and get out of the way, I usually get it loose when fishing the ig. wires in/out of there. Is it your opinion that the new wires fixed the problem? Is it running smooth now?
Old 03-03-2011, 04:26 PM
abit off center
cgarr's Avatar
If it gives you problems again "post 19" I just had a speed sensor puke out finally after chasing an intermittent problem. A quick test will tell but only if it is bad when you check it.
______________________
Craig
G2Performance
Old 03-03-2011, 05:19 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Congrats on your fix, just a silly question but when you reconnected the old Beru's did you feel a "Click" when caps were replaced on those new plugs?
I replaced my Beru's too but when installing my Magnacor's I realized one did not click on causing my rough performance.
'85 Carrera Targa
PCA/POC
Old 03-03-2011, 05:30 PM
MH911's Avatar
Here is the thread I referenced back on post 19 concerning the problem with my sensors. Keep it in mind if you are still experiencing problems.
Need help: power loss
Kipp
1987 Black 911 3.2 Carrera Coupe
1999 Green Mazda MX5 (SOLD)
Old 03-03-2011, 07:48 PM
Yes I did,that kind of worried me they are not a tight fit on the plug side...
Much Respect
Old 03-03-2011, 08:35 PM
Thanks MH911
Much Respect
Old 03-03-2011, 08:36 PM
Nice thread, I am with you every time I do a search no one finishes there thread to tell us what the results are from there repairs..I know most people get excited when fixing the problem and feel that it may not help,BUT IT DOES!
Also my next step if the problem returns is to replace the sensors..
Much Respect
Old 03-03-2011, 08:47 PM
MH911 Do you have a good and reasonable mobile Mechanic ,I live in San Jose..Thanks
Much Respect
Old 03-03-2011, 08:50 PM
MH911's Avatar
Tom Amon of Mobile Works West. Do a search on his name, you will read a lot of positive feedback. He also was the guy that did my PPI and had worked on my car several years before I purchased it.
Mobile Porsche Repair - Mobile Works West brings the Porsche Repair SHOP to YOU
Kipp
Old 03-03-2011, 08:56 PM
Thank you..
Much Respect
Old 03-03-2011, 09:12 PM
Well guys,Looks like the Plug Wires were the problem,so far so good its rained twice and no problems. Thanks for all your help,I will keep you all posted if something changes..
Much Respect
Old 03-17-2011, 12:12 PM
