911 Newbie driving questions: how to keep the motor happy?
Ok have had the 911 for 3 days now. I am addicted!! Bought a well-maintained 3.2 / G50 with recent valve adjustment. Want to continue to keep this engine healthy.
But I have some questions. 1) What range should I keep the tachometer in while driving/gearing, so that I don't lug the motor, or over-rev it. I want to keep this engine happy and free of carbon buildup. Right now I am keeping it between about 2.5 and 3.5 typically. 2) How long should I warm up the car at startup (right now I am doing 4-5 minutes)? 3) Upon shutdown, how long should I be idling on a level surface (parked) before shutting the engine off? 4) Should I be trying to let the clutch out quickly and risk some jerkiness, or very slowly and carefully (but if I do the later I smell a little rubber burning- I doubt this is good). 5) Is 91 (premium) gas OK or do I need to supplement with something? I like 94 but 91 is the highest Octane I can get in California. 6) Why do I end up turning on the high-beams at least 50% of the time I am using the turn signal? The movements are very close - is this a design flaw? Thanks in advance. Also - thanks to cbeers (on the left) - for selling me the car!!
2016 Honda Civic LX in White 2015 Honda CRV EX in Black 1987 Porsche 911 3.2/G50 Targa in Guards Red *SOLD* 2005 Honda Odyssey LX in Gold *SOLD* 1986 BMW 325 in Black owned for 21 years *SOLD * Last edited by umfan866; 02-21-2011 at 11:51 PM.. |
umfan, congrats on the purchase. If you recall we talked once in the market place forum. I also found my car recently. I need tires and then I will take some pictures, its an 85 Iris Blue turbo look
![]() Some thoughts on your questions: the manual recommends not warming up stationary, just keep the revs low (shifting around 3k or 3.5k if I recall) until warm. My car stumbles a little when its cold, so I let it run for 35-45 seconds until the high idle settles a bit. This may be a mixture problem... the car is sometimes jerky until temp gets higher. Im not sure about letting it idle before it shuts off. I know there is a reason for this in turbo cars, but I've always thought it was better to just drive calmly for the last few blocks before you shut off. When the car is static it starts to build up heat quickly. My parking spot is underground so I let my car coast down the garage into my spot. That way it is not under load and has some cool air flowing over the coolers. my car is from California and has been run on 91 for all of its life (AFAIK). it has a SW chip tuned for 91. Now in BC 94 is available so I may switch, but I'm not sure if it will do any good without being tuned for it... My car doesn't turn on the high-beams with the turn signals, but the flash to pass pull and possibly the wiper sprayer pull dont work. In some searching the wiper/signal stalks commonly fail one way or another. Probably the case with yours as well. see this thread for more: turn signal switch quick fix pictures |
1- shift at 6k ... you should feel the pull .... at 3.5 your lugging it ... not a chevy
2- drive at 3000 rpm or less till it warms ... never idle 3- turn key .... if checking oil leave running at isle to check 4- dont know on g50 .... i have 915 5-good to go ... may try mid grade my 3.0 likes it ..... 6-just touchy ..... you'll get used to it steve |
a.k.a. G-man
Shifting at 6K!?? Are you serious? On an open road maybe, but imo traffic conditions won't allow you to drive like that all the time. Shift according to traffic, engine load and common sense. It will not hurt your car. Last edited by Geronimo '74; 02-22-2011 at 01:13 AM.. |
Senior Advisor
Read the owners manual and follow what Porsche recommends, it will last forever.
08 Cayenne Turbo |
Mine runs fine on regular even though it's been chipped and the book calls for premium. All engines are different as are the ways owners drive them and have different tolerances, so you do what works or feels comfortable to you. Cheers, Joe 74 911 w/86 3.2 chipped and on regular 250K original top end Last edited by stlrj; 02-22-2011 at 01:35 AM.. |
a.k.a. G-man
upshift indicator on a 3.2???
Сидеть, ложь, Переворачиваться |
Member 911 Anonymous
+1 read owner's manual.
But here is my 2 cents per $250 Post Purchase Inspection & Tutorial and Owner's Manual (PAG): 1. Shift up between 3-5KRPMs, per PAG keep her under 4K 1st 5 minutes. Once up to Proper Running Temps ( 1st mark of the oil temp gauge ) she will like it if once in awhile you give her an Italian Tune Up, in 2nd drag her to motion then when safe punch it to redline, you should see a cloud of grey smoke behind you, that is the carbon deposit being blown out. 2. Per PAG drive off immediately, do not sit and idle to warm her up. 3. No need. 4. Release the clutch quickly and smoothly but do not pop the clutch ever. 5. Welcome to People Republic of Kalifornia, 91 is the best we can get, stick with Chevron unless you want to pay for 100 Octane, they are out there. 6. Search for Hi-Lo Beam fix, I just did it. Very easy mod/fix. The stalk is going on 25+ years so it is tired and the switch needs a bit of a butt lift ![]() Oh yeah CONGRATS to the Addiction!!! Jim Regular OIL CHANGE, remember she should consume 1qt every 1K Miles, so keep some oil ready.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 02-22-2011 at 01:41 AM.. |
a.k.a. G-man
Didn't know that.
your 86 does
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
a.k.a. G-man
It does? (my car's not US, but ROW)
I can honestly say I have explored the entire rev range, numerous times; and never have I seen such a light...
Your tach should have an up arrow in addition to the right/left turn signal indicators, that is your Up Shift Idiot Light
a.k.a. G-man
You calling me an idiot??
![]() Don't think my tach has one, if it does, it's broken... Last edited by Geronimo '74; 02-22-2011 at 04:03 AM.. |
l haven't noticed it on my 89 3.2 (US) l'll have a good look it might have a blown bulb as well, good, l thought it would be cool to have a shift light
Northern Motorhead
I have the little arrow on my tach... it's a Canadian model 89 Carrera !
After a while you don't even notice it anymore ... Tried to follow the light a few times and shift when requested but i have to admit my car deserves a little more action ... lol Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
MBruns for President
Congrats on the car - the G-50 carreras are excellent cars.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Liberal Prawn
I guess I'll get out the flashlight and check. He was picked up in Germany when new - would that make a difference? Drive'em umfan!
'Such are promises - All lies and jest - Still a man hears what he wants to hear - And disregards the rest. Lie la lie, lie la lie la lie la lie' Paul Simon '87 Black Targa "Welpe" • '93 Cadillac Allante "Amante" • Various other boring cars |
muck-raker
the "up shift idiot light", IIRC, is called the "CASIS" light. It is a yellow arrow that is located below the center of the speedo needle. I don't remember why it is called CASIS, but I could look it up on my Owner's Manual if anybody really gives a rat's arse.
The CASIS light is used to use the shifter in the most "efficient" manner. What that means is, if used as recommended, your shifts will be most FUEL efficient. However, you will find that you will be shifting in the 1.5K-2.5K range with this light. Personally, I hate it. Maybe not bogging it, but it sure seems like it. Many people put a piece of black tape (or something else) over the light so they won't have to look at it. I like to shift in the 3.5K-4.5K range after she's good and warm. When I first purchased her, I used to putt around on the freeway in 5th gear. I no longer do this, unless I get to a speed where laws will be broken. A respected P-car tech in my area says that the cars just run "cleaner" running around in the 4K range. I have found this to be true, at least for me and my personal ride. +1 on Draco A50G, Italian tune-up's are a must. And the sound at 4K is like music. BTW, welcome to the board umfan.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Obsessed
if Porsche's shift lights were as annoying as the others I've encountered (seemed like manufacturers of the 80's/90's caught this craze) I'd venture to guess most of them have had their bulb ceremoniously smashed to bits by now
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
