WVU 911's Avatar
Send a message via AIM to WVU 911 Send a message via MSN to WVU 911
What's the best upgrade you've done to your SC?
Just curious, I have an 82 SC and I am debating putting 46mm PMOs and SSIs on this summer. The only thing I've done since I've had it is a short shifter, momo wheel and upgrade the front seats. But the bug is starting to get stronger...
Old 03-20-2011, 03:49 PM
RETIRED
Joe Bob's Avatar
A 3.6......
2012 ML350 3.0 Turbo Diesel
Old 03-20-2011, 03:53 PM
DUK DUK is offline
DUK's Avatar
Backdate everything and what Joe said.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 03-20-2011, 03:54 PM
SSI's, M&K, removed back seats and floor soundproofing, installed RS carpet kit. Different car afterwards.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 03-20-2011, 03:55 PM
Carrerax's Avatar
and maybe consider PMO 40's instead of 46's unless you plan on going over 3.0 in the future...
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
New Corbeau Targa's.
1. My stock leathers were pretty well worn
2. Stock non-sport seats just don"t hold the way I like
Old 03-20-2011, 03:57 PM
clutch-monkey's Avatar
A 3.6......
seconded
Old 03-20-2011, 03:58 PM
Checked out
McLovin's Avatar
Upgraded to a 3.2 (around 50 hp addition), G50 transmission, upgraded the interior, bigger sway bars, and a bunch of other things.
Oh, wait, I sold it and bought a Carrera!
Old 03-20-2011, 03:59 PM
Arrow
Remove all the non essential stuff in the engine bay; AC, Heater Blower, smog etc., Then add, 46 PMO Carbs, M&K 2/2, RARLYL8 Tuned Headers, DRC GT2-108 Cams, MSD, Clewett Wires, J&E 98mm pistons and cylinders, Momo 380 mm steering wheel, stiffen the suspension and add some Wevo sway bar mounts, short shift kit, etc.
Add a tail.
High Performance 3.2 Liter Short Stroke
Rebuilt: 1 Jan 2010 - 17 March 2010
3.0 Liter SC Case
Early SC Heads: Large Port 38mm
Stock Crank : Stroke Leangth 2.772"
Stock Rods
3.2 95mm Cylinders : Bored to 98mm (3.8582")from EBS
98mm J&E Pistons/pins/clips : Compression Ratio 9.5:1: Dome Volume 35.2cc
Gotze Rings : Top, 2nd and Oil : End gaps: .0015mm
GT2-108 Dougherty Racing Cams : Timing set at 3.2mm
High Lift Racing Springs and Retainers : Spring Height : 39.5mm, 110 lbs
PMO Carburetors and Manifolds : 46mm
Venturies: 38
Main: 160
Air: 190
Idle: 55
Idle Air: 130
Emul: F11
Thick flange SSI's
M&K Generation V, 2 in 2 out Muffler
Clewett Racing Wires
MSD 6AL Ignition
MSD Blaster Coil
Chain Housings gasket surface milled .1mm (modified for 3.2 Gaskets)
Rocker Arms resurfaced and reconditioned by C. Garret
Rocker Shafts reconditioned by C. Garret
New Valve stem seals
New Valves : 2E, 3I and 5I
New Oil Return Tubes and gaskets
New 3.2 Chain Housing Gaskets
New Chain Ramps
New Cam Seals and Gaskets
New Exhaust Manifold Gaskets
New Intake Manifold Gaskets
Used 3.2 Cam Bolts and Washers
New 3.2 Pressure Fed Tensioners
Used 3.2 Idler Arms and Sprockets
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Last edited by snbush67; 03-20-2011 at 06:45 PM.. Reason: I edited so my mod list so it would be longer than Joey Bobby's list.
Old 03-20-2011, 04:37 PM
Horrido's Avatar
Wevo Shifter
Upgrading to a Wevo.
Easy to install and a remarkable difference.
Dan
Old 03-20-2011, 04:58 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
Backdate, 930 brakes, Hargett shifter, Momo competitiion steering wheel....the list goes on
From this:
to this:
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 03-20-2011, 05:03 PM
Any way you go will be $$$.
I've done a top end, ssi, m&k, ac delete, backdated heat, cobra rs seats, rotas, duck tail, rear seats gone, rennshift shifter, bilstein sports all around, lowered it, wevo motor mounts AND inplan on RS carpet and door panels as well as removing the floor coating.
I probably could have bought a 3.6 for the money I've spent already but then what would I have to look forward to
Old 03-20-2011, 05:15 PM
Capitalist and Patriot
911Freak's Avatar
Lots of great mods listed, but, I'd suggest the old tried and true philosophy of weight reduction and suspension upgrade before chasing HP through mods.
Check out ShakinJoe's thread ont weight reduction and there are numerous TB & sway bar upgrade threads.
Removing 200 - 500 lbs and updating to larger torsion/sway bars + corner balance/alignment will feel like higher HP and planted on rails in the corners
Probably the cheapest place to start as well.
After the above I'd go with back date heat, A/C removal (if not already done), SSI, M&K, WEVO (or similar) etc...
Then when that doesn't put a grin on your face anymore get a 3.6
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 03-20-2011, 05:22 PM
Hard to say with so much done, but I lean towards really liking my big brakes and sticky tires on wider wheels.
That said, as far as going faster, doing the SSIs, sport exhaust, gearbox with short 2,3,4,5th, and slightly shorter tires all at once was a big obvious difference.
Bang for the buck: removing weight for sure.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 03-20-2011, 06:11 PM
RETIRED
Joe Bob's Avatar
OK....I'll list my mods.
TRE glass front end 73 RS back date
duck tail
7 and 8 Fuchs
Carrera sway bars, 22/29 t-bars
Sport engine and tranny mounts
dual oil coolers
3.6 with injection
Wevo shifter and trans upgrades
RS carpets, Leather Recaros, dropped driver ride height 3 inches
Konis
R tail lights, LED back ups
H4s, Cibie H1s
Light relays
993 gauges
Roll bar
Wiper relocation/single wiper
AC delete, heat backdate
Euro ride height
Corner balance
993 HEs, 3 inch single outlet
No Bad Days performance chip
Probably more.......
Oh yeah,
Ash canned crappy VDO clock, replaced with head Temp and Volt Meter
Upgraded tunes with IPOD input
dual marine blowers for heat ($20 bucks each, eh)
ash canned crappy paper heater tubing with aircraft SCAT
Optima Yellow Top, Marine fittings with kwik disconnects
Permanent Battery Tender pigtail
Elephant Racing finned oil lines with air assisted blow down
de chromed, de badged
930 steering wheel
Old 03-20-2011, 06:24 PM
nineball's Avatar
tough to answer... changing out the shift bushings, adding a short shifter and fresh fluid made the car "feel" the most different (actually took me a good day of driivng to get used to the new setup vs the old). completely new interior (carpet, 993 seats, tar removed and modern sound damping material used, rear seat delete) made the biggest interior visual change. 28mm rear wheel spacers, lowering the front and adding a chin spoiler on the exterior.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 03-20-2011, 06:33 PM
Thumbs up
duck tail
7 and 8 Fuchs
dual oil coolers
3.6 with injection
Konis
H4s, Cibie H1s
Light relays
993 gauges
Roll bar
Euro ride height
Corner balance
Oh yeah,
Ha! I see we have turned this into a "List Your Mods" thread.
Old 03-20-2011, 06:39 PM
RETIRED
Joe Bob's Avatar
I doan follow directions well...
Old 03-20-2011, 06:42 PM
