What's the best upgrade you've done to your SC?
Just curious, I have an 82 SC and I am debating putting 46mm PMOs and SSIs on this summer. The only thing I've done since I've had it is a short shifter, momo wheel and upgrade the front seats. But the bug is starting to get stronger...
RETIRED
A 3.6......
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Backdate everything and what Joe said.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
SSI's, M&K, removed back seats and floor soundproofing, installed RS carpet kit. Different car afterwards.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
and maybe consider PMO 40's instead of 46's unless you plan on going over 3.0 in the future...
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
New Corbeau Targa's.
1. My stock leathers were pretty well worn 2. Stock non-sport seats just don"t hold the way I like |
Checked out
Upgraded to a 3.2 (around 50 hp addition), G50 transmission, upgraded the interior, bigger sway bars, and a bunch of other things.
Oh, wait, I sold it and bought a Carrera!
Remove all the non essential stuff in the engine bay; AC, Heater Blower, smog etc., Then add, 46 PMO Carbs, M&K 2/2, RARLYL8 Tuned Headers, DRC GT2-108 Cams, MSD, Clewett Wires, J&E 98mm pistons and cylinders, Momo 380 mm steering wheel, stiffen the suspension and add some Wevo sway bar mounts, short shift kit, etc.
![]() Add a tail. ![]() High Performance 3.2 Liter Short Stroke Rebuilt: 1 Jan 2010 - 17 March 2010 3.0 Liter SC Case Early SC Heads: Large Port 38mm Stock Crank : Stroke Leangth 2.772" Stock Rods 3.2 95mm Cylinders : Bored to 98mm (3.8582")from EBS 98mm J&E Pistons/pins/clips : Compression Ratio 9.5:1: Dome Volume 35.2cc Gotze Rings : Top, 2nd and Oil : End gaps: .0015mm GT2-108 Dougherty Racing Cams : Timing set at 3.2mm High Lift Racing Springs and Retainers : Spring Height : 39.5mm, 110 lbs PMO Carburetors and Manifolds : 46mm Venturies: 38 Main: 160 Air: 190 Idle: 55 Idle Air: 130 Emul: F11 Thick flange SSI's M&K Generation V, 2 in 2 out Muffler Clewett Racing Wires MSD 6AL Ignition MSD Blaster Coil Chain Housings gasket surface milled .1mm (modified for 3.2 Gaskets) Rocker Arms resurfaced and reconditioned by C. Garret Rocker Shafts reconditioned by C. Garret New Valve stem seals New Valves : 2E, 3I and 5I New Oil Return Tubes and gaskets New 3.2 Chain Housing Gaskets New Chain Ramps New Cam Seals and Gaskets New Exhaust Manifold Gaskets New Intake Manifold Gaskets Used 3.2 Cam Bolts and Washers New 3.2 Pressure Fed Tensioners Used 3.2 Idler Arms and Sprockets
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 03-20-2011 at 05:45 PM.. Reason: I edited so my mod list so it would be longer than Joey Bobby's list. |
Wevo Shifter
Upgrading to a Wevo.
Easy to install and a remarkable difference. Dan
I hate freight charges
Backdate, 930 brakes, Hargett shifter, Momo competitiion steering wheel....the list goes on
From this: ![]() to this:
Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project"
Any way you go will be $$$.
I've done a top end, ssi, m&k, ac delete, backdated heat, cobra rs seats, rotas, duck tail, rear seats gone, rennshift shifter, bilstein sports all around, lowered it, wevo motor mounts AND inplan on RS carpet and door panels as well as removing the floor coating. I probably could have bought a 3.6 for the money I've spent already but then what would I have to look forward to
Capitalist and Patriot
Lots of great mods listed, but, I'd suggest the old tried and true philosophy of weight reduction and suspension upgrade before chasing HP through mods.
Check out ShakinJoe's thread ont weight reduction and there are numerous TB & sway bar upgrade threads. Removing 200 - 500 lbs and updating to larger torsion/sway bars + corner balance/alignment will feel like higher HP and planted on rails in the corners Probably the cheapest place to start as well. After the above I'd go with back date heat, A/C removal (if not already done), SSI, M&K, WEVO (or similar) etc... Then when that doesn't put a grin on your face anymore get a 3.6
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
Hard to say with so much done, but I lean towards really liking my big brakes and sticky tires on wider wheels.
![]() That said, as far as going faster, doing the SSIs, sport exhaust, gearbox with short 2,3,4,5th, and slightly shorter tires all at once was a big obvious difference. Bang for the buck: removing weight for sure.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
RETIRED
OK....I'll list my mods.
TRE glass front end 73 RS back date duck tail 7 and 8 Fuchs Carrera sway bars, 22/29 t-bars Sport engine and tranny mounts dual oil coolers 3.6 with injection Wevo shifter and trans upgrades RS carpets, Leather Recaros, dropped driver ride height 3 inches Konis R tail lights, LED back ups H4s, Cibie H1s Light relays 993 gauges Roll bar Wiper relocation/single wiper AC delete, heat backdate Euro ride height Corner balance 993 HEs, 3 inch single outlet No Bad Days performance chip Probably more....... Oh yeah, Ash canned crappy VDO clock, replaced with head Temp and Volt Meter Upgraded tunes with IPOD input dual marine blowers for heat ($20 bucks each, eh) ash canned crappy paper heater tubing with aircraft SCAT Optima Yellow Top, Marine fittings with kwik disconnects Permanent Battery Tender pigtail Elephant Racing finned oil lines with air assisted blow down de chromed, de badged 930 steering wheel
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 03-20-2011 at 06:28 PM.. |
tough to answer... changing out the shift bushings, adding a short shifter and fresh fluid made the car "feel" the most different (actually took me a good day of driivng to get used to the new setup vs the old). completely new interior (carpet, 993 seats, tar removed and modern sound damping material used, rear seat delete) made the biggest interior visual change. 28mm rear wheel spacers, lowering the front and adding a chin spoiler on the exterior.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
RETIRED
I doan follow directions well...
