LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average.
tof2.7's Avatar
A small quiet weekend, to start the inside.
first Dismantling of the tower of gearshift for the assembly of the carpet and I take advantage of it to redo it a beauty.
And we start the mounting of the light carpets (good quality from AppBiz)
I cross you all the mount, which was very "****ting" but it is especially necessary to take time not be speed.
And especially make it in an airly place, because the "neoprene" Glue
for an idea of the final result
I also started my driver door panel to drill fixing holes and handle RS.
.............................................. be back soon
www.2l7registry.com the Ultimate register website for all 911 2.7 for 74 to 77
Old 05-29-2011, 11:26 PM
tof2.7's Avatar
Yesterday i have make some work
end of the mounting of the carpet
Then I began to do a mask for the mechanism of the rear belt
like on this photo
I left existing sides among which one was complétement HOURS dismantling,
first cutting and cleaning.
The next stage, mounting the belts to visualize then indeed and finish the mask.
Old 06-03-2011, 05:01 AM
tof2.7's Avatar
Yesterday evening, I worked on handles (has base dog leash !!!)
Cutting of the end with the hook
Drilling and the necessary parts to make the tie
assembly with slice and nut
Side which is going to come in the hole of handle.
Soon the continuation.......
FANTASTIC PROJECT!
Keep up the good work!
Old 06-03-2011, 05:28 AM
onboost's Avatar
Nice..!
RGruppe #180
Old 06-03-2011, 07:26 AM
Horrido's Avatar
Thanks for sharing your project. You are inspiring me to work on my SC.
Dan
Old 06-03-2011, 08:11 AM
tof2.7's Avatar
Well always no wings, the carrier takes his time.
but today i have received a big piece of my Skai, I am going to be able to finish my doors panel.
today i have receive too, my shift linkage cover,
all dimensions are ok so now i have just to drill the 18 holes.
To obtain a thing like this but in black
Old 06-27-2011, 08:18 AM
tof2.7's Avatar
Well I finished my plate.
The first one drilling in 2mm after have punched every place
Then final drilling in 10mm (size for the passage of the turn of the screw of the tool allowing to make perfect holes)
Final tapping
The result with the small tool very practical.
Then a small blow of mallet blows up for the good finish and it is completed.
next stage before mounting , black paint.
Old 06-28-2011, 08:57 AM
tof2.7's Avatar
After a moment of "Farniente", i'll be back to continue the works on Froggy.
I always wait for my wings fronts (lost somewhere in Europe by DHL, investigation is launch to know where they are) and without them impossible to the exterior.
Wings rear will be weld the 22 july.
I thus continued the inside.
I keep my panel of "isorel" which I had redone not a long time, i keep the hole of the speaker who for the moment stays in the garage but if later I want to put it back i can.
Thus "test to white" of all the panel
Then preparation of the Skaď for fixation on the panel
Organized by the "non-weaved" which allows to have a "soft" effect on the panel but without having too much thickness.
We attack then the assembly:
And now an attractive panel :
I take advantage of it to change the joints which were of time !!!!!!
And assembly of the panel
I had painting the the rear cover for the Gear mechanism
Old 07-11-2011, 01:00 AM
tof2.7's Avatar
The inside begins to turn to what I wish
The next stages:
- Manufacturing of the support of electrical cut switch which will go instead of the ashtray
- Manufacturing of the support stopwatch which will go to the place of the radio set (but removable cause so later i want take some sound), it should look like that:
- Manufacturing of mats rubber for the front, I found the manufacturer of the rubber in plate he will not have there more than the cut to be made.
Then small break with my fellow Cyrille and his great toy ................. ah if I was rich!!!!
Then i start the cleaning of the over fenders for take it in paint and has to be finish for in 22 ..........
Vintage914Racer's Avatar
keep up the good work
Old 07-11-2011, 12:42 PM
FinallyGotOne's Avatar
This is very cool reading, and I like the pics. love following the projects! keep up this great work !
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 07-11-2011, 01:13 PM
tof2.7's Avatar
i have just found my switch cut-off but very cheap when we see the price of a real bosch
the replica
we have just to cut the red and the black cap and after the part we can see is similar.
Old 07-12-2011, 02:53 AM
tof2.7's Avatar
and good news i have found my chronometers ......
quickly some news pictures , you will love it
Old 07-12-2011, 04:38 AM
ratpiper71T's Avatar
Impressive work! I like your creative use of everyday materials, very resourceful indeed!
Old 07-12-2011, 05:29 AM
tof2.7's Avatar
Thus I have the photo of the dashboard of the RSR Martini in competition, I have the manual printer "Dymo" I could finally have this....
If somebody can indicate me the word which is under the pull,I believe to read "Zundung" but I miss the end of the word.
On a modern replica we see better but the end is always missing...
On the other hand we can notice the switch cut-off Bosch (an outside, an inside)!!!
Otherwise on this 14 July, (holiday in France) I prepared the rear fender for the weld
And the evening in front of the TV, the creation of the plate for carrying the stopwatch.
We leave an average plate cut in good dimension
We sand quickly to remove the paint
Then we rub, we rub, we rub with "belgom" and the various sandpaper.
We always finalize in the "belgom" and in the steel wool 0000
And in the end " we see each other of in !!! "
Old 07-15-2011, 01:05 AM
tof2.7's Avatar
now just to wait the stopwatch for the end ........
Good news I finalized my exhaust cap with beautiful springs all identical (I have it even early) for those that was interesting that is worth 5 - 10 cents in rummage sales because originally it is a complex assembly forming a magnificent "plate support " for the wall ......
Otherwise I am on the plans to make it!!!
Old 07-15-2011, 01:06 AM
your are absolutely right - the word is ZÜNDUNG !
on the road...
Old 07-15-2011, 01:11 AM
tof2.7's Avatar
Thanks Tom
Old 07-15-2011, 01:16 AM
I think it says "ZUNDUNG 1" and "ZUNDUNG 2"
(ignition 1 and ignition 2)
WWW.9GEAR.NL
Old 07-15-2011, 02:16 AM
