-   -   New 2.8 RSR Evocation (http://forums.pelicanparts.com/porsche-911-technical-forum/600186-new-2-8-rsr-evocation.html)
tof2.7 07-15-2011 03:10 AM
Yes i have some confirmation for Zundung1 and zundung2
thanks ;)
Tom Sch 07-15-2011 03:27 AM
Originally Posted by Jeroen (Post 6137258)
I think it says "ZUNDUNG 1" and "ZUNDUNG 2"
(ignition 1 and ignition 2)
the correct word in german for ignition is Zündung - not Zundung ;)
tof2.7 07-15-2011 05:36 AM
Thanks Tom , yes when we see in the detail the dymo sticker in the first picture we can see the ü with the deutsch umlaut ;)
Jeroen 07-15-2011 05:58 AM
Tom, I know, but I couldn't find the ü on my apple keyboard 8^)
tof2.7 07-15-2011 06:05 AM
Well until the lunch break ......
I start the cut of the skaï to cover masks mechanism of belt, this evening it's going to have workshop sewing at home :rolleyes:
http://img827.imageshack.us/img827/1...0715102647.jpg
http://img220.imageshack.us/img220/8...0715102714.jpg
And as I still had time I enjoied making that :cool:
http://img717.imageshack.us/img717/6...0715131658.jpg
http://img14.imageshack.us/img14/504...0715142920.jpg
Now it is just necessary to make out a will on the animal to verify quotes.
tof2.7 07-15-2011 07:47 AM
Withe the hole more big
http://img84.imageshack.us/img84/736...0715163625.jpg
all that to polish , should be long .............
jm58 07-15-2011 10:03 AM
Don't forget your gloves .... SmileWavy
tof2.7 07-15-2011 02:53 PM
Yes two choise, take the glove or said "good bye" to my fingers :)
tof2.7 07-16-2011 02:14 PM
Well today rain all day long.
And with the rain no luminosity thus excuse photos.
Then for the belts of preservation that gives it.
http://img194.imageshack.us/img194/7620/dsc0452c.jpg
Rest more than has to finalize quotes and to reproduce it alu more thick.
For support Stopwatches (who arrive next week)
Fixations of stalks for the drawer of the car radio. (As it so a long road we shall have some music I have to hide the HP under the dashboard)
http://img830.imageshack.us/img830/4506/dsc0456y.jpg
http://img535.imageshack.us/img535/4895/dsc0478ts.jpg
You have notice the size of the plate which is going to receive the switch cut-off , I expect for have it in hand and I could then determine the height.
Otherwise I have to work on the masks of the mechanisms of belt.
http://img269.imageshack.us/img269/4443/dsc0453l.jpg
Which did not produce, too long and not enough covering on the back.
Of the blow I made the following modification.
Cutting on the high plane
http://img818.imageshack.us/img818/7655/dsc0458y.jpg
tof2.7 07-16-2011 02:15 PM
We take out the piece and we found the length of the future flap.
http://img814.imageshack.us/img814/2033/dsc0461r.jpg
We cut in the good dimension
http://img705.imageshack.us/img705/3633/dsc0462r.jpg
We are then going to practise a heavy loss on all the height in approximately a 1/3 of the thickness of the plastic to be then able to fold it and pull down the back part.
http://img33.imageshack.us/img33/1665/dsc0463rb.jpg
We can then pull down and leak out to be able to fix the high and the back parts
http://img651.imageshack.us/img651/1489/dsc0468v.jpg
We fix the whole one is recover with the skaï and it gives us this
http://img844.imageshack.us/img844/4458/dsc0472z.jpg
http://img820.imageshack.us/img820/1963/dsc0473w.jpg
And with the mechanism of belt
http://img268.imageshack.us/img268/6426/dsc0474e.jpg
It is then necessary to make a small leg U which will be fix at the top by saw it back of the visible plastic passer-by on the photo. This leg comes to clip under the metallic plate which is on the support of the mechanism of belt (no photo because no luminosity for a photo with my GSM) and now the result :
http://img714.imageshack.us/img714/1624/dsc0482q.jpg
gt3racerich 07-16-2011 03:28 PM
I don't know if I missed it but where did you get the rear flairs from?
Thanks, Rich
tof2.7 07-16-2011 03:43 PM
Hi Rich, for flairs you said fenders, so they come from ebay deutschland, and the builder is Dansk. I think you can found it in US, possible on pelican Part.
gt3racerich 07-17-2011 04:58 AM
Thanks for the reply. Keep up the good work.
Rich
tof2.7 07-17-2011 11:46 AM
Today scratching, cleaning, and scratching and cleaning and then put in paint.
The front is finally finished:
http://img842.imageshack.us/img842/5641/dsc0485m.jpg
tof2.7 07-18-2011 02:22 AM
Today i have the visit of the postman with :
First the swith cutt of, i have take out the cap red and black and it's perfect just cut the key a little because too long i think
http://img37.imageshack.us/img37/9025/coupecircuit2.jpg
and in second time, the first chronograph (in 30 graduations, the second is in 60)
http://img842.imageshack.us/img842/326/chrono9.jpg
tof2.7 07-19-2011 01:21 AM
Thus yesterday evening not liking it any more I worked on the support of stopwatch,
It will look to that:
http://img89.imageshack.us/img89/6619/chrono10.jpg
The second is on the way in .......
I also prepared my mask lock of limps in gloves
Indeed there is no door on a RSR but a hole on the place of the hole of lock thus I am going to make a black plate screwed instead of this hole (in red)
http://img9.imageshack.us/img9/6391/bouchon1.jpg
http://img30.imageshack.us/img30/711/bouchon2.jpg
tof2.7 07-22-2011 08:09 AM
Well the crucial stage of the rear fenders is behind us. And it is a good thing because what a difficult job, fortunately my two friends JF and Fab was there, because only it would have been impossible mission. René, another friend and I served as "Arpettes" (little helping man) and we especially took a big lesson.
First of all the presentation of the extension:
http://img339.imageshack.us/img339/7623/carross17.jpg
Then the cutting to have just one centimeters necessary for the "soyage"
http://img28.imageshack.us/img28/6530/carross18.jpg
Put back in position to prepare the weld.
http://img691.imageshack.us/img691/5779/carross19.jpg
And it is gone for the weld, at first some point of weld.
http://img268.imageshack.us/img268/7313/carross20.jpg
Then the weld, with always JF in the hammer and in the heap
http://img220.imageshack.us/img220/5938/carross24.jpg
Then grinding of the weld.
http://img121.imageshack.us/img121/63/carross26.jpg
sanding.
http://img717.imageshack.us/img717/1229/carross40.jpg
Then application of a putty iron.
the same for the second side
http://img19.imageshack.us/img19/1566/carross35.jpg
With a break "pizza" always in the cheerfulness.
http://img691.imageshack.us/img691/4179/carross37.jpg
http://img59.imageshack.us/img59/7472/carross36.jpg
tof2.7 07-22-2011 08:13 AM
We took advantage of it to delete the holes of cashdesk.
http://img685.imageshack.us/img685/1152/carross38.jpg
And especially an excellent final result, the judge was the Bumper RSR.
Presentation of the "beast"
http://img825.imageshack.us/img825/3620/carross41.jpg
The ends of wings and bumper fall first-class
http://img59.imageshack.us/img59/458/carross42.jpg
http://img854.imageshack.us/img854/1438/carross43.jpg
We begin to see the end
http://img809.imageshack.us/img809/7535/carross44.jpg
jm58 07-22-2011 09:50 AM
SmileWavyThank's for sharing ,I am also going to drink a beer
Walt Fricke 07-22-2011 11:08 PM
For a perfectionist like you, mon ami, I think there can never be an end!
But it does look like you will have a car you can drive fairly soon.
What are the "holes of the cash deck" which pizza (et biere) allowed you to weld up? Are they where the sheet metal screws held the cosmetic sheet metal under the door from fender well to fender well? The one which has the hard to put back in rubber protective strip?
