Help Removing Stubborn Intake Studs
I'm trying to pull my intake studs to change them out for longer to accommodate a CIS to Weber conversion with thermal isolators. 5 of the studs will not budge while trying to spin them out using a double-nutted approach. I've flooded them with Kroil and hit them with MAP gas but they will not move. The nuts will eventually spin but not the studs. I'm somewhat nervous about snapping them off as well.
Is there another technique I should try?
Kev
Old 04-26-2011, 11:05 PM
Senior Advisor
James Brown's Avatar
Get a good stud puller like this one from snap-on.
Doesn't have to be a snap-on but it should be this type. Be carful, you still might brake some off. Use heat around the stud when pulling. Try to work the stud back and forth to help break the bond. Go slow and they should come out. The two nut technique doesn't always work with tight studs. Good luck. At least there intake studs!!!
08 Cayenne Turbo
Old 04-26-2011, 11:54 PM
Almost Banned Once
sc_rufctr's Avatar
These are good... Heat and one of these should do it but you've already tried heat.
WORSE Case >>> After you break the stud trying to get it out... You drill out the center of each stud and use an easy out.
- Peter
Old 04-27-2011, 12:04 AM
Wer bremst verliert
JohnJL's Avatar
You might try welding a nut to each one and use the nut to back the stud out while its still hot. That has been 95% successful for me (still had 1 break)
MAP gets it hot but not like welding. Stick, MIG or TIG, your choice. If it doesnt work the first time try it 2 or 3 times. The heating/cooling cycles can break the bond.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-27-2011, 05:01 AM
Use this tool plus an impact wrench.........
Kev,
You could almost prevent breaking any stud by using an impact wrench (modulated setting) with the stud extractor tool attached by JB. You got to be careful when using a cheater bar when extracting these studs. You could easily snap them by excessive torque. The extractor tool and impact wrench is an ideal set-up for extracting stubborn studs.
Tony
Old 04-27-2011, 10:33 AM
CaptainCalf's Avatar
Kev, would something like this work with an impact wrench?
Sears: Online department store featuring appliances, tools, fitness equipment and more
Good luck,
RC
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 04-27-2011, 11:41 AM
Grady Clay's Avatar
I use that SnapOn stud extractor.
On very difficult studs (and where you don’t want to risk brakeage), I have cooled the extractor, stud and head with dry ice.
Once very cold, I heat the head area around the stud with an oxy-acetylene torch while turning the extractor.
Differential expansion works every time.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-27-2011, 12:12 PM
Thanks for all the suggestions. I was finally able to get all of them out. I continued to use the double-nut/MAP gas heat/Kroil penetrant along with patience. Thankfully, nothing snapped. Hopefully I have the same luck with the exhaust! I think I will invest in the a stud puller should I run into any issues there.
Kev
Old 04-27-2011, 05:23 PM
Kev
Did you say, 'MAP gas'?
read this..
DEFECT
Old 04-27-2011, 06:10 PM
